Yam ty200 majesty - electronic ignition
simon0116
Fitted a electronic ignition as instructuons say.
Now ty will only start by putting a drip of petrol down bore.
Good spark,  new petrol, clean carb, reeds look ok.
Timing is 2-3mm measured with strobe.
Once running rev/ rides fine. Kicks back up ok. Only tried it for 10mins running
Any ideas before i put old ignition on to prove a point,   or is 200 majesty timed diffent to a ty175
Thanks
Are you trying to start it with the Carby choke on?
Will it start once it has been started and warmed up?
I would also check the plug lead is screwed in properly, if that was changed with the electronic ignition.
