September 2Sep 2 Is it possible to get a different brake pedal that sits lower? Ideally i want my lever no higher than my peg, currently it bottoms out on the frame. I've filed an amount from the bottom of the lever, but i'm still not as low as i'd like. Has anyone else come across this?
September 3Sep 3 Author Sorry, yes I can adjust the piston, I’ve done that. But it’s the pedal physically hitting the frame that is stopping me from adjusting further.Do all TRS’s have a pedal that’s a lot higher than the peg? Do most people prefer this set-up?? On all my other Trials bikes I’ve been able to get the brake at the same height as the peg.
September 3Sep 3 I think you are stuck with raising the peg profile or lowering the lever profile aka bending it. The levers do bend before braking, I have a badly bent one on one of my TRS now.
September 10Sep 10 Search for pictures. Hmm yeah it does seem high on my 23 and I usually hate that, several bike recently I've readjusted down. But never noticed on TRS. Odd. Your pegs are quite worn.
September 23Sep 23 Well bugger me. Someone noticed that I was dragging the rear at times, oops. I could lower the lever and still not bottom out braking. If yours is spongy it might need bleeding properly. I've had to prop bikes at an angle with one wheel on a bench before so air not trapped at highest point.
