How To Stop Water Getting Into The Flywheel
gasgasian
My theory is that the water that appears on the inside of the flywheel is condensation from the inside of the motor. I have been through the 'sealing before every trial' route only to find water inside even after a 'dry' trial. Now the practice is to remove the cover after the bike has been washed, spray with a water repellant (WD40) and leave open until the next trial. It seems to work for me, but as usual I'm sure someone else will have a different theory!
... i have drilled a hole or two in the bottom of it and slotted them... anything gets in it goes straight back out again.
What do you mean "slotted them".... do you have a pic? I've never really had a problem with water in the flywheel cover myself but I'm all for preventative measures!
Please sign in to comment
Sign In Now
