davidni Posted July 22, 2006 Share Posted July 22, 2006 I just bought a 2004 sherco 2.9 Could anyone give me there general opinion on the bike and also tell me what is the petrol/oil mixture i should be using? Quote Link to comment Share on other sites More sharing options...
bikespace Posted July 22, 2006 Share Posted July 22, 2006 (edited) Best bike I've ever had. I'm a heavyweight on the expert route giving mine a real good test, and it's been almost faultless. I'd like a new one, but it's so damned good I'm going to run it in to the ground. If it doesn't blow up soon I'm going to have to shove some new rings in it, just because I feel I should be doing something after three years of tireless service After washing it, strip off the airbox and drop the float bowl, then seal up between the silencer/mudguard/airbox and should run spot on every week, with the odd bit of general maintenance. I use around 75:1, so that's around 70ml in a 5litre petrol can (fully synthetic). Use the best fuel you can get - optimax for example. You'll hear the odd scare mongerer, usually for Sherco's someone's heard a rumour from a cousin of a friend about main bearings. The worst thing on the bike is keeping the stickers on - so how bad can that be I think it's sort of like the Beta - you'll hear people scare mongering about the electrics. Well not much else usually goes wrong with them so the main thing you ever hear about Betas is the electrics. A possible weak point, but nothing really in the grand scheme of things. Always an exception, but generally I rate the Sherco 290, especially the 04 pretty highly. Edited July 22, 2006 by bikespace Quote Link to comment Share on other sites More sharing options...
atomant Posted July 23, 2006 Share Posted July 23, 2006 And when Gaz talks about serious abuse this is what he means Quote Link to comment Share on other sites More sharing options...
davidni Posted July 23, 2006 Author Share Posted July 23, 2006 Cheers sounds like its gonna be a good job then It'll be some upgrade from my pinky for sure. I'll have to be careful because im not that used to the extra power of a modern bike and im only 10 and a half stone Thanks for the advice Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted July 23, 2006 Share Posted July 23, 2006 Best bike I've ever had. I'm a heavyweight on the expert route giving mine a real good test, and it's been almost faultless. I'd like a new one, but it's so damned good I'm going to run it in to the ground. If it doesn't blow up soon I'm going to have to shove some new rings in it, just because I feel I should be doing something after three years of tireless service After washing it, strip off the airbox and drop the float bowl, then seal up between the silencer/mudguard/airbox and should run spot on every week, with the odd bit of general maintenance. I use around 75:1, so that's around 70ml in a 5litre petrol can (fully synthetic). Use the best fuel you can get - optimax for example. You'll hear the odd scare mongerer, usually for Sherco's someone's heard a rumour from a cousin of a friend about main bearings. The worst thing on the bike is keeping the stickers on - so how bad can that be I think it's sort of like the Beta - you'll hear people scare mongering about the electrics. Well not much else usually goes wrong with them so the main thing you ever hear about Betas is the electrics. A possible weak point, but nothing really in the grand scheme of things. Always an exception, but generally I rate the Sherco 290, especially the 04 pretty highly. 05 was a fair bit better gaz imho Quote Link to comment Share on other sites More sharing options...
bikespace Posted July 24, 2006 Share Posted July 24, 2006 (edited) And when Gaz talks about serious abuse this is what he means You've had good value out of that photo ya bitch 05 was a fair bit better gaz imho Yeah - I'd concede that. My comment was just because of my experiences with the 04, and some other local 04's. Pretty solid. Can't remember what the differences were to be honest. Not massive. A new bike always seems better, but I reckon generally for a rider of our standard, it's not going to make a msiive difference - I'll go for reliability if I've got the choice. Edited July 24, 2006 by bikespace Quote Link to comment Share on other sites More sharing options...
