Gas Gas Thermo
13 replies to this topic
#1 bruce67
    New Member
  • Members
  • Pip
  • 21 posts
  • Bike:gas gas
  • Club:middlesbrough
Posted 19 October 2008 - 10:23 AM
please can any one help new on here , got a gas gas txt125 ,since i bought it had trouble with boiling dry had new fan fitted and 2 new relays which kept melting, since new fan fitted been great for 3 weeks ,yesterday radiator boiled dry, nothing melted but fan wont come on any ideas please. can,t find thermostat anywhere thanks bruce
#2 millerme
    Member
  • Members
  • PipPip
  • 99 posts
  • Bike:yamaha ty hybrid
  • Club:dulais valley south wales
Posted 19 October 2008 - 02:29 PM
hi mate you thermo should be on the hose going from the cylinder head to the bottom of your rad check that your rectifer is working
#3 bruce67
    New Member
  • Members
  • Pip
  • 21 posts
  • Bike:gas gas
Posted 19 October 2008 - 03:06 PM
hi ,no thermo on any pipes ,check them all its a 2005 model ,someone said dont have thermo but fan has been turning it self on and off great for last 3 weeks but now just runs till steam comes out of overflow pipe ,i don,t have a clue what to do now thanks bruce
#4 adamski90
    New Member
  • Members
  • Pip
  • 13 posts
  • Bike:GasGas 300 2008
Posted 19 October 2008 - 03:33 PM
From 2005 the thermostat is in the top of the radiator.
#5 bruce67
    New Member
  • Members
  • Pip
  • 21 posts
  • Bike:gas gas
Posted 19 October 2008 - 04:34 PM
thanks ,i will go and have a look at the top of the radiator
#6 bruce67
    New Member
  • Members
  • Pip
  • 21 posts
  • Bike:gas gas
Posted 19 October 2008 - 05:59 PM
hi,i found thermostat ,it was on top of radiator thanks, any idea how to change please as it looks sealed in and i dont want to bust radiator thanks bruce
#7 pandelboy
    Advanced Member
  • Members
  • PipPipPip
  • 157 posts
  • Bike:gas gas
  • Club:Berkhamsted mcc
Posted 19 October 2008 - 06:27 PM
go for the old style thermo that fits in the top hose and rewire from that back to existing wiring. the problem with the stats in the top of the rad is that the coolant must be visable from your filler cap hole so it surrounds the stat or it wont work. check also that your water pump is working correctly and circulating the coolant.
#8 bruce67
    New Member
  • Members
  • Pip
  • 21 posts
  • Bike:gas gas
Posted 19 October 2008 - 06:42 PM
thanks alot ,think i will go back to old way thanks again bruce
Edited by bruce67, 19 October 2008 - 07:36 PM.
#9 JanDyb
    Advanced Member
  • Members
  • PipPipPip
  • 244 posts
  • Bike:280 Pro Racing 2011
  • Club:Trøgstad Trialklubb, Norway
Posted 19 October 2008 - 09:54 PM
Hi
It is not sealed in. It is held in place by a "locking ring" (dont know exact english word), Unfortunatly You have to loosen the radiator to manage to get it out.
-Jan
#10 bruce67
    New Member
  • Members
  • Pip
  • 21 posts
  • Bike:gas gas
Posted 20 October 2008 - 12:43 PM
ok thanks jan looks like might have to take radiator out.Thanks for advice everyone ,first time on here deffo use again cheers bruce
#11 bigfoot
    Advanced Member
  • Admin
  • PipPipPip
  • 1,606 posts
  • Bike:Gas Gas 250 Pro 11
Posted 21 October 2008 - 07:19 AM
Bruce
I have a brand new thermo and hoses to allow you to change to inline rather than on tank sensing/switching. If you want it drop me a PM. There is no need to remove the rad one just move the wires to the the new one.
Sometimes I think the surest sign that intelligent life exists elsewhere in the universe is that none of it has tried to contact us.
#12 bruce67
    New Member
  • Members
  • Pip
  • 21 posts
  • Bike:gas gas
Posted 21 October 2008 - 04:15 PM
thanks for that bigfoot,but took in bike shop and found out water pump seal gone,did not notice gear box full of water cheers bruce
#13 PeterB
    Advanced Member
  • Members
  • PipPipPip
  • 650 posts
  • Bike:OSSA TR280i
  • Club:Waitemata
Posted 22 October 2008 - 07:37 AM
Hello bruce from the 'boro,
If you have melted 2 fan relays then the problem is with the supply voltage. If an 05 model 125, then I think the system is a Kokusan and you will therefore have a 12V voltage regulator which is probably the problem (for the relay melting). The regulator is encapsulated in a small black housing just under the headstock - check if it has an earth wire very firmly and cleanly connected to a piece of bare frame. If all connected properly, then the regulator is probably faulty and best to fit another to prevent further meltdowns. To electrically check this, use a volt meter set to AC and check the voltage between a still connected yellow wire, probably at the relay connector, and the frame, it should be approx 12v.
The relay, is a rectifier module to convert AC to DC voltage to drive the fan motor, this needs DC power.
If you find that your clutch action has become harder, then the water in the gearbox will have affected the plates (they swell) - let us know on the forums if this happens.
Ta ra, PeterB.
#14 bruce67
    New Member
  • Members
  • Pip
  • 21 posts
  • Bike:gas gas
Posted 23 October 2008 - 05:22 PM
thanks peter ,i will let you no when i get the bike back ,found out today water pump gone not seal,very dear hobbie at the moment,lol
