Bolts
7 replies to this topic
#1 shercoman2k8
    Advanced Member
  • Members
  • PipPipPip
  • 601 posts
  • Bike:09 Paxau Sherco 125
  • Club:L&DMCC
Posted 13 February 2009 - 11:31 AM
If any of you know could you please post upp the length and thread required for the bolts on an 06 sherco, probably the same upto present!
Looking for;
Clutch Cover,
Flywheel Cover,
Water Pump Housing,
Clutch Master Cylinder,
Fork Cross Brace,
Yokes,
Clutch master cylinder.
Will I need to replace gaskets if the bolts are undone? the part will remain firmly in place as I will be doing one bolt at a time!
#2 1oldbanjo
    Advanced Member
  • Members
  • PipPipPip
  • 173 posts
  • Bike:2009 Sherco 3.2
  • Club:None
Posted 13 February 2009 - 12:45 PM
Here is the link to the Sherco Parts Manual. You can look up the bolts/screws that you need.
http://www.sherco.com/spare_parts.html
You may not find a manual for your exact year - but most parts are the same.
#3 shercoman2k8
    Advanced Member
  • Members
  • PipPipPip
  • 601 posts
  • Club:L&DMCC
Posted 26 February 2009 - 11:29 PM
Who said I was using alu? :(
Just doing a hot spray on the heads so decided on new bolts.... if you heat them up really, really hot and spray them with your desired polyurea coating, (steel bolts this is) chuck them in the freezer over night then shove them in the bike! Cant even scratch them with a stanley knife!
What kind of tit uses alu bolts in a high pressure area? Even titanium is a bit risky where you should have high tensile bolts!
Edited by shercoman2k8, 26 February 2009 - 11:30 PM.
#4 Andy
    Site Owner
  • Admin
  • PipPipPip
  • 5,949 posts
  • Club:Spearmint Rhino
Posted 26 February 2009 - 11:48 PM
Just so you don't look like you're talking to yourself, user "sherco25016" had his posts deleted because they contained so much text talk they looked like another language. :(
No text talk!
#5 shercoman2k8
    Advanced Member
  • Members
  • PipPipPip
  • 601 posts
  • Club:L&DMCC
Posted 27 February 2009 - 08:51 AM
Oh right, I thought I was going insane for a minute then :(
#6 Bark
    New Member
  • Members
  • Pip
  • 13 posts
  • Bike:06 Sherco ST 2.9
  • Club:Rocky Mountain Dirt Riders
Posted 09 March 2009 - 11:32 PM
Quote
Hi,
I'm new to the whole trials thing. I just picked up a beautiful 06 Sherco and I'm now basically clueless about what to do with it. Do I understand correctly from your post that the motor casing screws in these bikes are made from Aluminum? Or, did I understand that wrong?
Thanks,
Bark
#7 copemech
    Advanced Member
  • Site Supporter
  • 8,055 posts
  • Bike:Sherco
  • Club:NTTA, TXTC
Posted 10 March 2009 - 02:28 AM
View PostBark, on Mar 9 2009, 08:32 PM, said:
Hi,
Thanks,
Bark
No, the factory bolts are cadmium plated steel. They will corrode a bit over time, yet are cheap to replace.
The biggest potential problem comes not from appearance, but the corrosion on the thread portion due to water exposure. Treatment with a grease/ antisieze mix on all the threaded bolts you can access(not brake disc bolts) is advisable, although I usually replace all my common bolts with stainless steel and coat as stated. Coat axles with waterproof grease. ;)
Edited by copemech, 10 March 2009 - 02:41 AM.
Ride it Like it was one of your old Girlfriends, If you still remember how!
#8 Bark
    New Member
  • Members
  • Pip
  • 13 posts
Posted 10 March 2009 - 02:37 AM
Thanks, I was thinking 'Aluminum?!'
Stainless sounds like the way to go for sure if I need to replace anything.
Cheers,
Bark
