More Clutch Woes!
#1
Posted 23 February 2009 - 03:55 PM
after holding the lever in for some time both while running and not running, and while the clutch is under load (like described in the other thread) I found that no fluid was going back into the master cylinder.
So I decided to take the clutch casing off and have a good look at it all. I took the slave cylinder "top hat" off and looked at the seals, they both looked good, no tears, wear or anything like that.
However one problem I found after taking the clutch basket out was that all the fingers werent level. there was a couple that were about 1 - 2mm lower than the rest. could this be the cause of my problem?
Ive decided to fit a new clutch pack anyway while everything is out, im hoping somehow this will solve the problem. anyone else got any suggestions?
Thanks for all your help up to now =]
Tom
#2
Posted 23 February 2009 - 05:30 PM
#3
Posted 23 February 2009 - 06:14 PM
husky, on Feb 23 2009, 05:30 PM, said:
Ive ridden it for about 15 hours with this problem and ive not lost any fluid out of the master cylinder. could it still be the slave cylinder seals?
Tom
#4
Posted 23 February 2009 - 06:53 PM
Provided there is no scoring to the bore, should be an easy fix with a cylinder rebuild kit.
Tim
#5
Posted 23 February 2009 - 07:59 PM
Best of luck
Spencer
#6
Posted 23 February 2009 - 11:03 PM
Tim
If this was the problem, wouldnt the clutch start to pull after a while with the lever held in? I can hold the lever in for as long as I want but it only starts to pull if the clutch is having to work hard (like pushing it against a rock for balance), during normal riding theres no problem at all.
Tom
#7
Posted 24 February 2009 - 05:28 AM
edition model that the friction material lost its bond with the clutch disc after coming into contact with the coolant/trany fluid mix.
this caused the clutch action to become more inconsistent over time to the point where the clutch would no longer disengage.
I would inspect the friction discs closely for this.
Tim
#8
Posted 25 February 2009 - 06:05 PM
All the best
Tom
#9
Posted 25 February 2009 - 10:31 PM
tombo46, on Feb 25 2009, 06:05 PM, said:
All the best
Tom
from your photo of the bike you have red hoses fitted. check that the hose isnt expanding somewhere under pressure. It will be harder to spot the problem with the red hose and maybe thats why you havent noticed it ?
Had this on a montesa with a Venhill replacement brake hose a few years ago
#10
Posted 25 February 2009 - 11:14 PM
Ill swap it back for the original hose and see how it go's, the thing that baffles me is why does it only do it when im pushing the bike into a rock? why doesnt it cause any other problems!?
Tom
#11
Posted 11 July 2010 - 02:17 PM
There are two types of men in this world:-
1) Those who are Geordies and..
2) Those that want to be.
#12
Posted 20 July 2010 - 12:47 PM
#13
Posted 03 August 2010 - 02:13 PM
Help
