Inlet manifold information
#1
Posted 02 February 2011 - 01:42 PM
#2
Posted 02 February 2011 - 03:17 PM
mrpj6, on 02 February 2011 - 01:42 PM, said:
Lengthing the intake will have an effect of tract resonance but this will probably tend to improve lower RPM torque which should not be too big a problem. You will probably need to tune the carb as there will undoubtedly be other modifications in the project's intake/exhaust. This should not be a big problem and they big thing to remember is to try to keep the intake tube diameter as uniform as possible.
Jon
#3
Posted 02 February 2011 - 03:58 PM
Andy
#4
Posted 02 February 2011 - 06:58 PM
JSE, on 02 February 2011 - 03:17 PM, said:
Jon
#5
Posted 02 February 2011 - 07:04 PM
andyrothers, on 02 February 2011 - 03:58 PM, said:
Andy
#6
Posted 02 February 2011 - 09:01 PM
mrpj6, on 02 February 2011 - 06:58 PM, said:
You may need to change the jetting a little but probably not much from stock. Mainly to tune the off-idle response but you can post how the engine is running and someone here will be able to give you some good advice.
Jon
#7
Posted 02 February 2011 - 09:11 PM
Sounds an interesting project.
#8
Posted 03 February 2011 - 12:54 AM
It was smooth enough, not sure I could tell any difference in torque but the real surprise and bonus was that it virtually cured the spit stall when opening the throttle too quickly. I have to be pretty savage to make it cough now.
In my case no jet changes were needed, carb is MK1 Amal.
#9
Posted 03 February 2011 - 01:32 AM
My guess is that the slightly longer intake, with the added stored volume of air/fuel, acted as a sort of small "boost bottle", allowing the engine to draw just a little more fuel at the start of the intake phase/opening throttle. Interesting side effect and it would be fun to do some testing.
Jon
#10
Posted 03 February 2011 - 12:58 PM
#11
Posted 03 February 2011 - 03:23 PM
One mistake I did make was although I (thought) had thoroughly cleaned the carb out, the donor bike had been stood for couple of years and took me ages to figure out why the bike wouldn't run on more than 1/4 throttle. Cleaned the carb out several times, still no joy then finally cleaned it 'properly' and suddenly the bike ran cleanly....
Good luck!
Andy
ps. you'll never stop tinkering either....
#12
Posted 12 February 2011 - 06:53 AM
I am back mate. You seem like a determined little bugger so go for it. Will do you an email soon. See ya mate
#13
Posted 12 February 2011 - 01:49 PM
Ever seen the length of the inlet tract on a Rotax disc valve motor ?
Must be 150mm.
#14
Posted 13 February 2011 - 01:28 AM
#15
Posted 13 February 2011 - 01:42 AM
B40RT, on 12 February 2011 - 01:49 PM, said:
Must be 150mm.
