phbl versus vhst carb
#1
Posted 10 February 2011 - 08:12 PM
#2
Posted 10 February 2011 - 08:35 PM
I bought a VHST 26 some time back and I intend to fit it to my 06 250 but in-between waiting for the new jets to arrive I did a mod on my OKO 26 which makes the tuning just prefect (lively) for me. So I'm kinda reluctant to change it and tune it now.
I rode a 2010 250 a few weeks back (which had a phbl) ... nice and soft down low but still with plenty up top too.
Some say the 2011 250 has lots of power. I noticed that it has a base cylinder gasket of 0.4mm (Standard is 1mm). So if it's power you're looking for you might want to try that simple mod first.
Thanks for starting this thread rockyrider. I hope many others join on in this one.
Best of balance.
Neo
TRIALS....It's not life or death....It's much more serious than that!!
#3
Posted 10 February 2011 - 08:57 PM
Got the VHST on my 2011, and im not a huge fan just yet. Ive tinkered with various settings which seem to work, but then will start running lean or rich for no apparent reason.
Biggest problem i have is it runs very week between an 8th to half throttle. Ive just put a 55 slide in to richen it, which seems to have helped a little.
I think it has the potential to perform very well. Just hasnt reached it yet in my case.
Whilst on the subject, this is a very good guide to tuning: CLICK ME CLICK ME CLICK ME !!!!
I cant remember if it has already been posted on here or not, but there it is anyway!
#4
Posted 10 February 2011 - 09:20 PM
#5
Posted 10 February 2011 - 09:34 PM
coriolis, on 10 February 2011 - 08:57 PM, said:
Which slide did you have in your VHST previously?... is that a 26 or a 28mm VHST?
Best of balance.
Neo
#6
Posted 10 February 2011 - 09:37 PM
Best of balance.
Neo
Its the 28mm and i think it was a 50 slide in there before hand.
Thinking about it, a 55 would weaken it over a 50.
Deffinatley wasnt hunting for fuel as much though.
Go figure !
Edited by coriolis, 10 February 2011 - 09:40 PM.
#7
Posted 10 February 2011 - 10:31 PM
I had a bit of hunting but it was also a touch rich on initial throttle opening. So I ground the slide myself then adjusted the airmix richer...now things are much better.
Best of balance.
Neo
#8
Posted 10 February 2011 - 11:16 PM
In general. the 28mm carb will have less throttle response down low than your buddies 26mm. I personally think the 250's run better with the 26's. Conversely, the 28mm will have alot more up top. (not very meaningful to a novice)
I think that there are 2 other things going for the "simple" PHBL. One is that it has been used on alot of OEM bikes (GG and Sherco) and the best jetting has been very well established. The other is that the Pilot circuit of the VHST is much easier to clog or get restricted from dirt, whereas the simplier PHBL just (seemingly) passes everything (no small atomizer holes to deal with) and also has the fuel inlet screen filter that the VHST doesnt have.
I would verify the jetting with RYP. Clean the carb (ultra sonic if you can) and put on a clean fuel filter, air filter and good gas. If you cant get the bike to run to your liking, the PHBL's are inexpensive.
I run a 26mm VHST on my 250 GG and really like it when its "clean". I need to strip it and clean it every now and then though to keep it optimized. I never did that with my PHBL. I can see why the PHBL makes a good OEM carb.
#9
Posted 11 February 2011 - 12:25 AM
#10
Posted 11 February 2011 - 02:01 AM
So do you find the VHST well powered up high on your 250?
laser1, on 10 February 2011 - 11:16 PM, said:
Best of balance.
Neo
#11
Posted 11 February 2011 - 03:45 AM
Am a bit surprized to see what carbs are winding up on what bikes. Seems to me that although the VHST shares most the attributes of the Kiehin carb, is is simply not as well refined. Add seems they can both be more fiddly, yet I do not find the personal desire, time or money to try to polish a VHST, in either 26 or 28 version.
All said, I did not seem to find a particular complaint in Rockyrider's post, so if it is working for him as well as anything, well just go on. If not, then I would likely just find a good phbl and put it on for the sake of (simple just works)and leave it alone.
I got a good working Phbl here in front of me, but even though I got an OKO oon the bike, I'd rather keep the Phbl than trade it off for a Vhst, because it just works!
#12
Posted 11 February 2011 - 06:38 AM
Anyways if I am not happy with the PWK I am going to try out the VHST 26mm before resorting back to the PHBL.
#13
Posted 11 February 2011 - 09:52 AM
I think you'd love the way I've tuned my OKO26 ...sounds just up your street to me
But just to add another twist to this does anyone know anything about the Racing (Red) VHST's?...How are they better (or different) and why would they only be suited to racing? I would have thought that they're not suited to trials at all but I've seen some on Trials bikes...so what's the story?
Best of balance.
Neo
#14
Posted 11 February 2011 - 10:55 AM
#15
Posted 11 February 2011 - 11:36 AM
