Sign in to follow this
Followers 0
clay
315 Swing Arm Movement
11 posts in this topic
When my bikes on the stand, should there be any vertical movement with the swing arm, as mine has about 3/4" play. ive replaced the dog bone bearings, and it does look like the plays coming from the bottom of the shock,,, (Thanks in advance)
Share this post
Link to post
There are bearings in the shock - top and bottom. There should be minimal if no play vertically.
Share this post
Link to post
The bottom 'eye-ball' bearing gets a bit sloppy with age ,unfortunately it seems to be an unusual size and I couldn't source one cheaply from the mainstream bearing stockists :wall: .Good luck,I think you're in the dealers' hands.
Share this post
Link to post
It is rare for the bottom "heim joint" bearing to fail. Check the bolts or the holes on the triangle plates to see if the have ovaled out. Did you replace the bearing on the swing arm where the linkage connects?
Share this post
Link to post
Replaced the underside bearings of the swing arm, at same time as i did the dog bones,,
will check for wear on the bolts / plates at weak end.
but think ham2 right, (more over time needed)
Share this post
Link to post
Most likely to be the plates. Just a smidge of play there will relate to loads at t'other end of the swingarm.
If it is a shock bearing, check the price and give me a shout - pretty sure I have one or two here I'm never going to use, I'll do you a deal.
Share this post
Link to post
Hi bud, ive sent you a pm
Share this post
Link to post
Got round to checking the lower suspension, And your right lads,
The plates are slightly worn, so ive ordered the uprated plates, (not sure if there worth the extra cost)
Thanks again for the input
Share this post
Link to post
i think they are worth it personnally
Share this post
Link to post
yes i am
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
