Triumph Cub
  • Please log in to reply
24 replies to this topic
#1 danw43
danw43
    Member
  • Members
  • PipPip
  • 53 posts
  • Bike:triumph cub
  • Club:poachers pre65
Posted 24 April 2012 - 08:53 PM
after reading a lot of posts on here about lightening a cub clutch ive tonight lengthened the actuator lever on mine added a strengthening bar to it,and it works.
Just waiting for a new clutch cable then im gonna drill the inner case to reposition the cable, and all should be sorted.
The next job is to attach a engine breather but where does the end of the pipe on the engine breather run to,any help would be greatly appreciated.
Another job is going to be fitting a wider swing arm,i love this hobby already.
First trial on the 6th of may cant wait now.
Ads By Google User is online
Ads By Google
  • Ad Bots
Don't want these Ads? Why not help support TC and sign up as a Trials Central Supporter?
#2 totalshell
totalshell
    Advanced Member
  • Members
  • PipPipPip
  • 1,919 posts
  • Bike:in several boxes....
  • Club:Rossendale Harriers, Clarks Commando's
Posted 24 April 2012 - 09:23 PM
put the open end of the breather as high as possible to keep water etc out.. put a small air filter ( foam ) on it to be doubly sure.
plenty of thoughts of how to do a wide swing arm .. my preference is to keep the original spindle width but many like to chop it literally in half and add 20/25mm between the two lugs. one on ebay at the moment inc. sidestand and chain tensioner.
We few .. We happy few Yorkshiremen..
let Richard III rest in York..
#3 danw43
danw43
    Member
  • Members
  • PipPip
  • 53 posts
  • Bike:triumph cub
Posted 24 April 2012 - 10:07 PM
thanks totalshell,thats my thoughts too,im bidding on the e-bay item at mo,gonna use a offset front sprocket,and offset the rear cog to suit and leave everything else in the c/line of the bike then shim to suit,and use a 4.00 rear tyre,that should give me all the clearance i need,then have a good look at the clutch make sure its all set up properly,then a good look at the tappets carb and timing as it seems to be bogging down a bit,although its got a electronic kit on it,hopefully have it all sorted by the 6th may
#4 danw43
danw43
    Member
  • Members
  • PipPip
  • 53 posts
  • Bike:triumph cub
Posted 26 April 2012 - 09:14 AM
would it be possible to scollop out both arms and plate up with a thicker plate to get clearance for the tyre.
Then to lengthen it remove the axle plates off the end of the arm,get some 25mm longer slugs to fit in the arm and extend out by 25 mm then reweld new lugs onto the ends,a bit like the armac swing arm spindle lugs?
does that sound feasable,any pitfalls,problems any one can see
Dan
#5 old trials fanatic
old trials fanatic
    Advanced Member
  • Members
  • PipPipPip
  • 2,956 posts
  • Bike:James Bantam Majesty
  • Club:Peak Classic, AA, Tufty.
Posted 26 April 2012 - 09:36 AM
Dan
I like your thinking. Only problem i might see is falling fowl of a clubs eligability criteria? Be nice to see some piccys when you have it done. Not that any bike is ever "done" there's always something new to be modded eh? :thumbup:
The Victor Meldrew of Trials Central. Dont believe everything you read about me because the truth is much much worse !! LOL
#6 danw43
danw43
    Member
  • Members
  • PipPip
  • 53 posts
  • Bike:triumph cub
Posted 26 April 2012 - 11:10 AM
how would it affect club elegibilty,most run different classes,ie specials,and at the end of the day its a bit of fun for me on a sunday,dont think ill be at all competitive at first to be honest,as its my first off road bike in 28 yrs,lol
#7 danw43
danw43
    Member
  • Members
  • PipPip
  • 53 posts
  • Bike:triumph cub
Posted 26 April 2012 - 11:14 AM
totalshell,i got outbid unfortunately,so plan b now,alter the existing,cant be that hard,thats one advantage of working for a large military aircraft company lots of machines and stuff to play with lol
#8 brucey
brucey
    Advanced Member
  • Members
  • PipPipPip
  • 148 posts
  • Bike:Triumph Tiger Cub
  • Club:Sidcup MCC
Posted 26 April 2012 - 02:45 PM
There is lots you can do to a Cub with a modest workshop. I did the following to mine (see photo's on pre 65 forum):
Widened and lengthened swing arm.
Fitted chain tensioner and side stand.
Fitted Sammy Miller Swing Arm Bushes
Fitted plastic chain rub block to top of swing arm
Modified swing arm to fit snail cam adjusters
Made detachable front engine mount plates (with adjustable offset)
Made Ally Bashplate and mounts.
Fitted External Oil Filter (from e bay) as it adds 1/2l oil capacityMade and fitted Top Tube Oil Tank
Put inspection hole/push rod fitting hole in top of cyinder head.
Varoius rockershaft mods.
Put drilled sicencer bush inside exhaust (to create more back pressure and quieten it down a bit)
Fitted Taper head bearings with Montesa Yolkes and Forks (best improvement to date!)
Electronic ignition and delorto carb (Jury still out on this!)
Alloy tank and plastic mudguards
And plenty more. My point is you don't need to spend vast sums of money to make significant improvements yourself.................but it helps!
Look at as many other bikes as you can for ideas and inspiration. They don't even need to be Cubs!
Good luck with the build,
Bruce.
#9 danw43
danw43
    Member
  • Members
  • PipPip
  • 53 posts
  • Bike:triumph cub
Posted 26 April 2012 - 03:17 PM
I realise that its all possible and aim to do all the work myself,could you point me in the direction of the pre65 forum,as computers arent as strong a point as my fabrication skillls lol
Edited by danw43, 26 April 2012 - 03:18 PM.
#10 b40rt
b40rt
    Advanced Member
  • Members
  • PipPipPip
  • 4,517 posts
Posted 26 April 2012 - 04:05 PM
http://www.trialscen...4-pre-65-bikes/
Never argue with stupid people, they will drag you down to their level and then beat you with experience. Mark Twain
Ads By Google
  • Ad Bots
#11 brucey
brucey
    Advanced Member
  • Members
  • PipPipPip
  • 148 posts
  • Club:Sidcup MCC
Posted 26 April 2012 - 05:06 PM
just scroll down a bit from this forum!
#12 danw43
danw43
    Member
  • Members
  • PipPip
  • 53 posts
  • Bike:triumph cub
Posted 27 April 2012 - 07:23 AM
well the clutch cable arrived last night,unfortunately from what i can gather the levers on an original cub must have had a smaller nipple hole,than on newer replacement levers and as such doesnt fit,new cable ordered get that fitted and see how the mods have worked,pretty sure im gonna have to strip the clutch as it was dragging originally,but thats no biggy,ill try and get some pics up as soon as possible.
#13 danw43
danw43
    Member
  • Members
  • PipPip
  • 53 posts
  • Bike:triumph cub
Posted 27 April 2012 - 08:21 PM
well i finally managed to get in the garage tonight and solder the end nipple onto the clutch cable tonight,works a treat doesnt even drag any more so thats a bonus.
i hear i need to seal up the scavenge hole in the primary side and seal the clutch cable entry points old and new and theres an easy mod to primary case to do so any oil and water can be drained easily,
swing arm next i think a lot of measuring and fabrication,think i am just going to scallop the sides(for clearance)and get some slugs and plates made up to lengthen by 25 mm.lets see how that goes next week,wish me luck folks,so far it ows me for a clutch cable and thats it so far
Edited by danw43, 27 April 2012 - 08:23 PM.
#14 danw43
danw43
    Member
  • Members
  • PipPip
  • 53 posts
  • Bike:triumph cub
Posted 29 April 2012 - 07:50 PM
in the garage again tonight,tappets set runs a bit better but still bogging down under fast throttle,more investigation needed i think,but think itll have to wait a while,i think ive upset the missus enough for a while,and frst tial a week today!!!!! thats come around a bit quic,wish me luck folksi
#15 pierre66
pierre66
    Member
  • Members
  • PipPip
  • 37 posts
Posted 30 April 2012 - 01:47 PM
Hi, good luck :thumbup:
Where will you be riding? North Lincs?
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
