- Past hour
I guess no "modern" bike has a similar lever? The fact it's on the left side makes things harder anyway.
- Today
The 350 MAR was produced from late 1975 so it has the later type shafts for kickstart and gear lever. It will be the same spline as the enduro engine, assuming no-one has changed parts on it at any time. Just count the number of splines and compare to double check
Holy cow! You are one lucky leprechaun! That cover looks pristine. Buy a lottery ticket.
Hei guys, got some good news for a change... Checked and the intake diameter is 36mm like on the other engine, so I was able to fit the carb manifold to the cylinder. Also found out the cylinder will take the Explorer exhaust, the flange is removable and in its place I fitted the Explorer header. So thankfully won't have to look for different exhaust/carb. Have found a guy breaking a MAR 350, so I should be able to get an original Motoplat coilpack... but can't say if the kickstarter lever will fit.
Thank you for the warm welcome, the cool story and the suggestions! My TY came with a thick enduro style seat, but when I pulled the seat cover and foam from the worn out seat I discovered the original seat still intact underneath it all! I will have to clean some glue off of the base,fill some rivet holes where they had attached the enduro seat base, and repaint it, but the seat still looks brand new. I lucked out!
Thank you for the response. I am no longer in need of a seat/pan. I found one. Thank you!
Ukb300 joined the community
Welcome to the forum! I had a 1974 TY250 myself when I was 15. I absolutely loved that bike. I had a crash on it and was hospitalized with a concussion and when I got home from the hospital I couldn’t find my TY in the garage. My mother sold it. She kept the money from the sale too! See your other post about a seat. I sent you some options.
I don’t know if you’d be interested in this but through the following links you could put one together. The seat pan will need new foam but it would be an economical way to get an OEM looking seat. I found another link on eBay that was selling, what they claim, is an original, new seat but they want over $9000 for it. Yes, $9000 is correct. Seat cover: https://www.ebay.com/itm/152173175811 Seat pan: https://www.ebay.com/itm/388685489803?chn=ps&mkevt=1&mkcid=28&google_free_listing_action=view_item&srsltid=AfmBOoowxMbSNwRd0_T2grI0G3cTK_SVgPjNh_PG14jIfwzm-IOkXYCXH1M Just for fun, below is the link for the $9000 seat. It’s rediculous, I know. https://www.ebay.com/itm/155945452638?chn=ps&mkevt=1&mkcid=28&google_free_listing_action=view_item&srsltid=AfmBOopsjTnPTsYqxoH5moPUHu_Beh0nkNb6Akoy1cUXrgTmKqSZjDRxZ2o
Ron75RL joined the community
Thanks, if the "stator" is broken I think I'll simply abort the project and will try to cut my losses... found a guy here in Italy who's breaking an Ossa MAR 350 but don't know the production year... was the MAR still around when they changed the teeth of the levers on the engine block?
If anyone has one that they'd like to sell at a reasonable price, please reach out. Thank you. Tbone.
Howdy everyone! I have been reading this forum for many many years. I am 60 years old and started riding motorcycles when I was five. I've owned just about everything you can think of. About 10 years ago my boys and I all had Gas Gas TXT 300s. At the time we lived in rural Kansas in the Kansas River Valley that had heavy woods and Rocky bluffs and lots of creeks etc. Those bikes were powerful and athletic, but I found them a bit too much at times. Fast forward to today, and I now live in Steamboat Springs Colorado with access to a lot of beautiful single track Mountain trails. I recently purchased a 1974 Yamaha TY250 which is much more my riding style at this point in my life. I am looking forward to getting back into some great trials riding.
TYBone joined the community
Triad, below is a link to a US company that specializes in electrical components for older bikes. Not sure if it will have the right one for you, and if not, it’s still a very good source to bookmark. I believe they make everything in-house so it may be possible to get what you need built. They also have a CDI, ECU Repair Unit also. Good luck! https://www.regulatorrectifier.com/
Today I was away so couldn't check the gear lever and the exhaust compatibility... will try to do it in the weekend. Hopefully I'll find a solution for both
Same for all models, they changed the gear and kickstart shaft sizes around late 1973
Thumos joined the community
Uh, forgot to ask: the bigger shaft on the kickstart lever is on the enduro models only or it was also on other models and depends from the production year? I mean, the Gripper/Yellow etc. have this same bigger lever shaft?
Uhm... I think I'll invest the money for the coil, as I'd need it anyway. But the rest is definitely more expensive and harder to find. I'll check the exhaust later today and will report back... thanks a lot for the advice, I've been toying with this project for a year now and taking a short ride in my yard would already mean a lot to me LOL
1973 Ossa Explorer - issues with engine transplant
konrad replied to Triad's topic in Classic Trials
You can take stator resistance reading as woody suggested. Although that does not guarantee functionality, you can find some definitely-bad components that way. A peak-reading voltmeter is better, but again will not guarantee proper function. https://www.thumpertalk.com/forums/topic/1034259-build-your-own-peak-voltage-adapter/ I have used a drill motor and socket on the flywheel nut (or primary gear nut) to spin the motor for stator testing. This is best done with the head removed for easiest cranking, but just removing the spark plug may be adequate. -
The carb was fitted on a rubber manifold, no bolts... but yeah, it's smaller. Didn't check the exact diameter but I'd say it's something like a 24-26mm maybe? The biggest problem is that I'm missing the kickstarter lever and the coil... I could at least know if/how the engine runs if I had them. Is there anything that will fit when it comes to kickstart lever? Maybe from a newer bike from another brand? It's clear I'll have to gamble and buy a Motoplat coil without knowing if the engine runs, but for those old lever sellers tend to ask pretty unreasonable money and they're not easy to find. Even a borrowed one would be ok, I'd gladly pour more money into the project if I knew for sure the engine runs OK.
Yes, you'll need another kickstart and gear lever with the correct number of splines, the earlier engine shafts have more splines than post 1973 engines The exhaust won't be a straight fit, yours has a flange held in the cylinder by the threaded screw in collar. The exhaust on the enduro engine is a push fit held with springs. To get yours to fit you have to cut off the flange so it pushes into the cylinder and weld two hoops on it to locate the springs - as long as it is the right diameter to fit. But how the enduro motor will run with the trials exhaust I wouldn't know You also need a carburettor, yours won't fit as it is bolt on and probably also too small for the porting, whereas the enduro cylinder is a stub fitting
konrad started following Did Someone Say Trunk Monkey?
Trunk monkey theft retrieval system 👍
I didn't pay enough attention before buying the new engine, the owner didn't know much about it but... even the gear pedal is different? About the exhaust, I see they have a similar flange... maybe the Explorer one will fit? If I have to buy all these parts with the risk of the engine non even being completely fine I'm screwed big time.
The stator can be checked, you'll need the workshop manual which will give the expected readings, I've no idea, electrics are a mystery to me. In the UK we can get them repaired. The motoplat coil for the Ossa is a combined coil / cdi so you need the two connector type. New replacements are available (at least here in the UK they are) When I saw the picture of your replacement engine I assumed it was the same year as yours but someone had changed the cylinder head for a later one. It seems the chassis number list I have incorrectly lists the engine as a 1972 but it's actually a 1976 enduro version, so, the kickstart and gear shafts have a different number of splines from your explorer engine. I think that the exhaust fitting on the later enduro motor is push fit with springs, not threaded collar, so your exhaust header isn't a straightforward fit To be honest you're probably better off fixing your explorer engine, all parts are available.
Uh, so the coil integrates parts of the CDI? Damn, in this case won't work. Can I test the rotor/stator without a working coil? Today I finally managed to literally kick the engine in place, only to find out my kickstarter lever won't work... different shaft. 😭
I think all those red Motoplat "ignition coils" contain other CDI components too. Best source of Motoplat information I have found: https://motelek.net/motoplat/
