But now i can't get the seal in place. It is about 3mm below the surface of the bottom part of the fork, and it just wont go in any further! I am using a weighted steel hitting tube. I Have hit it down as hard as i possibly can and it just wont budge. Any one got any ideas, im presuming by now the seal in knackerd anyway, but i want to complete is and just use it as a dummy run for when i get another seal.
Would it work if i fitted the new seal before rebuilt the fork? is this even possible?
Thanks
Ryan
Ps. i am using the information off RYP, buy im still managing to get stuck.
In the process of doing the fork seals. I have them fully stripped, but there is one of the spacer/washers (about 1-2CM thick with a split in it)traped in the bottom part of the fork leg. Its about 5omm from the top, so i can reach it but cannot seem to get it out. All i can do is wobble it a little bit using a screwdriver and hammer. I have been trying for hours to get it out, but it is solid!
Any ideas???
I realy would like to have the whold bike finished this weekend
I have been looking at the RYP site and have seen that a special tool is needed to replace the fork seals. Is it necessary to buy one, or is there another item i can use as a replacment. (like a wiered tube hammer thingy!)
Also it says i may need an impact tool to undo the alley bolt at the bottom if the fork. Will i get away with using nornal allen keys?
Would it be too much trouble to put the cables through a switch or atleast a connector block. That way you can turn the fan on and off at regular intervals. The weather is cold at the minute, so a longish spell with no fan shouldn't be too much of a problem, just dont leave it too long
I got to the trial about 1pm. A lot different than what i expected. At first glance it looks like an unorganised mess!. But after walking round for 20 mins or so i found out exactly how it all worked (spoke to a guy on bike number 192) he was very helpful. I ended up leaving around 2.30pm
StuartC (if its you that owns Autowbars) You fitted a tow bar to my black fiat punto aswell as your bike rack. Yhen october-ish i bought a single bike trailer off you.
I am planning on going to the bingley trial just to spectate. Could someone please tell me where it is? and roughly how to get there?. I live local-ish to home farm at tong and bumpy, so directions form either of these two would be much appreciated.
Thanks for the replys. The blue caps are bone dry on the outside (i have never removed them so dunno about the inside) It is deffinatly the seals. When i push down on the bars you can see the oil gushing out!
The chrome shafts are in v.good condition although a bit mucky. Il clean them as Alan suggested.
But other than that i think i will just run it as it is, untill it starts clunking, then have a go at the seals.
Just thinking back, i was told to clean my forks with WD40, to get all of the dirt out from under the dust covers. I have recently been told that WD40 could damage the seals, is this true?
One of my fork seals burst just under a month ago, so i took it to DMS Trialsport tho have them both replaced. Both have now gone at the same time, not even a month after getting then sorted. I know i cannot get my money back, frankly im not bothered. But my question is, Will it be any detrement to the bike riding with very little (and still leaking) oil in the forks. I know its harder/different riding, but is it going to do a lot of damage to the forks. Im an amature rider and the biggest landing the front wheel has is from a wheelie. Not exactly 6' drop offs, but are hard'ish landings going to wreck the seals on a bike this light!
If i do need to sort them i will be having a go myself (cannot do any worse than the shop!) I know to use RYP's website for the how to. But does anyone have anyother usefull tips to help me on my way?
My 03 290 was making a tapping sound when reved in neutral or in gear, clutch in or out. I thought it was an engine problem, but turned out to be the waterpump shaft! The tapping/pinging sound was coming from the bike overheating. (it sounded a bit like an old diesel car) It cost about
I dont know about all events, but the recent event at Tong in leeds was in the Motor Cycle News paper. I did not look to see if there was any others, but it might be worth checking.
I have been pulling a 3 lane trailer with two sherco 2.9's on it in a Fiat punto 1.2 . It felt like normal driving with 3 passangers. A 1L should easily cope.
Help!
in Sherco
what/who is balla-cry?
