Hello Everyone. We finally got the the bottom of our Reving problem, after changing both crank shaft seals she is running a real treat. Thank you so much for all the help.
Hello all my mate need some help. He has a 2009 290 Sherco. When you start it up all it does is rev its self sky high. Throttle cable fine carbs been removed and clean including jets. We just don't know what's up with it. Hope someone has some ideas.
Went to the 1st British round today and saw Dougie Lampkin and the vertigo. He said there hoping the bike will be on sale September time but still no prices. What a bike Looked Great and sounded AMAZING. Just hope the rumours of the prices aren't true.
Went to the 1st British round today and saw Dougie Lampkin and the vertigo. He said there hoping the bike will be on sale September time but still no prices. Looked Great and sounded AMAZING.
Hello All. Just a quick bit of advice needed. Has anyone had a rattle sounds engine but goes away when the clutch is pulled?? Is it normal and what spark plug would you recommend running.
Hello all really need some help. I've bought some heavier springs for Evo. Thought I would start with the rear so I have taken the rear shock off but can't seem to find out how to get the shock apart to change the spring?? And how would I go about changing the front spring one too.
Thanks for all your help I'm very grateful. Its going to be a little Different to my Factory Evo but I'm sure after a few adjustment I'll get used to it and love it.
Hello all. Wonder if you can help me. I have just Bought a 2014 300 Jotagas after selling my Beta Evo 300. Is there anything you all would recommend me doing as I've been a Beta ride for 15 years and just wanted a change.
HI, I fitted one and managed to bleed the brake to ALMOST as it should be but was struggling to get lever pressure. After asking around someone told me to remove the master cyl cap and just"flick" the brake lever enough to move the piston about 2-3mm and watch for little bubbles, sure enough the last bit of air came out and now have pressure at the lever and the brake is perfect except for a bit squeaky from fluid on the pads. The only downside is it took a good half hour or more of fiddling with the lever but it's worth knowing. Good luck with yours.
Thanks I will try anything its driving me mad I have a master cylinder service kit coming so with that fitted and your advice I will hopefully get to the bottom of it and get it fixed....
.There was a build up of dirt in the reservoir. .The seals were beyond repair, Once new seals were fitted, the brake was easy to bleed and the lever soon started to .regain some bite,
I have had the same problem and have ordered a new seal kit from Beta UK...
Hello jes42 I am having the same problem and getting nowhere just covered in brake fluid. mine came with a bonjo bleed screw/bolt that replaces the normal bolt that goes though hose into the caliper hope thats any helps
2009 290 Sherco Gear Oil
in Sherco
Posted · Edited by evo boy
Thanks
