lotus54
    672
Posts posted by lotus54
  1. If you still have it I'd be very interested in it-
    Be good to make up a full 'kit' to replace for if mine goes.
    Never got round to repairing old pump,sold bike a while ago, now on a 4rt.
    The actual pump once removed from plastic housing is just a cheap made in china part, available on ebay for about £30. I couldn't seperate the fuel pipe from the pump though, but if you could find a way or made new fuel lines it could be a cheap repair, i just needed bike running again so fit a full kit for piece of mind
  2. I certainly have that problem, both hands thought.
    Heated grips don't help me, since I try and keep a finger on each all the time.
    I've wrapped them with good results, shirk tubing works also.
    I wear nitrile gloves under my riding gloves when cold- much warmer.
    Once my hands warm up I don't like the movement inside, but better than cold fingers!
    I use a Clake 2- so that's my rear brake and clutch. I trial ride the bike most of the time and almost always have a finger of the lever.
    I also have Reynolds conditon, and that makes it all worse.
    Mark
  3. I don't have any issue at all with My fuel pump, but just thinking ahead to eventually needing one.
    So I can get a KTM pump?
    Anyone know which model?
    Since it is a fair amount of work to remove, I wouldn't mind sourcing one now to have on hand.
    Tom, have you don't anything toward working on your old pump?
    Mark
  4. Sorry- 2stroke EFI works flawlessly.
    I have one in my garage.
    Have you ever even ridden one?
    More complicated? I don't think so, but I find it very rare for people to really understand how a carburetor works. Even more so EFI of any sort.
    I'm very much sold for a trials bike.
    1. Packaging. Easier to get components in better locations.
    2. No fuel leakage/flooding when tipped over (let's not talk about crappy OSSA Explorer fuel cap)
    3. Multiple MAPs available. Easy switch to change how the bike runs.
    4. Automatically adjusts for temperature and elevation.
    5. Better running consistently (just my experience)
    I understand those that don't want it. That's ok- but it does work.
    • Like 1
  5. The trail between sections is something to consider for cross checking also.
    A trial I did last year one of the Marshall's knew me and mentioned he was glad I was there- for doing observing for the afternoon, higher grade riders.
    He knew some of the novice would have problems with done of the loop trail- but knew I would really enjoy it.
    Indeed, some guys had a very hard time even making the loop- I had a blast doing it, since it was like lists of the trails I like to ride. I certainly didn't clean them, but some were pushing....
    I guess I should really appreciate our club- they really consider the Novice and kids riders and make it fun for all. Plus all really helpful without a bunch of ego getting in the way.
    Mark
    • Like 1
  6. I just started last year.
    I rode all year in Novice, did very well. I didn't want to move, since I felt I wasn't getting the really tight turns right. Lots of times I noticed the intermediate had less tight turns and Geiger obsticles.
    I could clean lots of sections in novice and usually 1st or 2nd place.
    So this year I thought I'd give intermediate a go.
    Only one trial so far, I did struggle the first lap a lot. After that I started getting into the groove better and improved. I still was down the list and could have rides better- but I'm very cautious and don't lime to fall down (or perhaps get hurt).
    I think it was the right move- I'm feeling a lot better about tight turns (still need to work on it) and the obsticles are good practice.
    Loads of times I would put a foot down- just to be safe.
    But most importantly I had lots of fun.
    One of the guys I rode novice with last year also moved up, so it was fun to ride with him and talk about how we saw it.
    Our club does a very good job of keeping Novice safe and resonable for a Novice I think.
  7. Yes, if you look in the OSSA exhaust outlet on the cylinder it sweeps up to clear the transmission.
    The actual port is lower and like mentioned, works great.
    Having both EFI and carb two strokes, give me a good EFI any day.
    I think they have it down pretty well now. I remember when everyone said CDI was un-repairable in the field and better to stick with points. I remember points too well! (Still have one bike with them).
    OSSA was a pioneer in CDI. They got it to work with almost never a failure.
    Do CDI units fail? Sure!
    But points/condensers failed a LOT, LOT more.
    I certainly understand where those that are skeptical are coming from. I wasn't too sure either until I got one. Getting close to 160 hours, runs wonderfully !
    • Like 3
  8. Are are essentially describing the OSSA system.
    Add a small Rechargable batt (AAA in this case) and solves the start issue.
    It works very well.
    What could they do better?
    Have a BTWICE setup for idle adjustment.
    Have a cheap cable diagnostics setup, maybe even with a 'bare bones' version for people that don't really understand.
    I have setup a couple of them, they are very easy.
    There is a 'rich/lean' baseline adjustment you can do also. I've never changed it because the bike runs so well.
    Mark
  9. I have 4EEEE wide feet.
    The Gaerne oiled balance fit me really well.
    A LOT less protection and MX boot. Like not much more than walking boots.
    So I wear them for trials (where I've already seen where potential toe jammers are) or sometimes for certain slow trails where I'll also be walking a lot.
    I trail ride my OSSA mostly, so use my Gaerne SG12s. Not much feel but I'm always hitting hidden stumps.
    I'm new also- just riding the bike taught me loads- it will tell you if you are wrong in a hurry.
    The local club members are really helpful- giving lots of good advice without making me feel like a dope. (Well, anymore than I usually am anyway)
  10. I have a 2014 OSSA Explorer (same bike as the TR with some more junk added on)
    FI has been wonderful, much less hassle than the carbs on my other bikes I've had/had.
    I did have to reset the TPS at around 100 hours- took about 5 mintues.
    Still trying to get the aftermarket cables (I have the software)- the factory ones are way too much $$$. I borrowed the dealers cables to reset it.
    I have around 150 hours on it, it always runs great, freezing, 90f, sea level to about 8k feet.
    It starts very well (unless you touch the throttle, it doesn't like that) and I like the way it wokrs better with a one step hotter sparking plug.
    On the OSSA, the injector goes directly into the crankcase- points right at the rod bearing. (So some call it 'semi-direct').
    Mine is street legal and works just fine on the road, quite smooth actually. Not much fun with 3psi in to be tyres and sitting- but for connectors and getting to the local trails I like it.
    I don't know how much the fuel pump costs, I've had no issues and I believe the importer has not sold any.
    Pain to get to it though.
    I know they has issues with some of the earlier bikes- but the map I have is quite nice.
    I've never has issues with my FI street bike (2005 Ducati Multi), or my cars since way back I the 70's. (My Lotus is due for new injectors, I have the ira box)
    I ran the APT Smart Carb on it 300 KTM, it took some fettling (I had a rather earlier one) but once sorted it worked really well (better mileage also). I think they have a 27mm also.
    The OSSA is very, very linear in power- I don't know how much the injection has to do with it.
    I'm quite happy with it.
    Mark
    • Like 1
  11. I lived right near there for a few winters - hoping to make it there. I've never seen a world trial. Heck, I've never even been to one before I competed in a club even a year ago.
    From what I remember, try to stay on the west side of 295 and 95 for least traffic.
    I see a number of motels listed.
  12. I forgot to mention I needed to replace the AAA rechargeable battery in the Easystart box.
    It was about shot, but another was cheap and easy to fine.
    Made it better.
  13. I have. 14 Explorer (same bike with extras)
    142 hours- great!
    See my recent post, but I trail ride mostly so perhaps some different impressions.
    A hotter plug and a good kick results in quick, easy starting.
    I did have to set the TPS at about 100 hours. It was running rich and harder to start.
    Mark
  14. I have not had anything like that experience.
    Bike has been great and only one part took a bit to get. And I think that was just because nobody else had broken that one.
    I understood parts were worse after thenGasGas deal. But seems getting better.
    I certainly hope they keep going- they are great bikes. Mine Is very well built- fit and finish is excellent and everything (except fuel cap) is top notch.
    I have 142 hours on it- still runs great (see my posts).
    I'd probably try and get a 15- but are they here?
  15. Update.
    142 hours. Still having a blast on the bike. It has been very good.
    Around 100 hours I did need to reset the TPS- it was running rich and herder to start. A reset solved it.
    I broke a suspension link- but my fault.
    A few things I've learned.
    1. I run a hotter plug, works much better.
    2. Run A mud flap over the spark arrester (aftermarket). Mud will clog it otherwise.
    3. Keep an eye on the fitting in the top of the main fuel tank cap. It can leak.
    4. Fuel cap is still crap.
    5. Clake 2 is fantastic!
    6. Fit the trials brake pedal stock is horrible.
    7. 100:1 Motorex has worked great.
    8. Zip tie the one corner of the side covers, they won't fall off and it works fine.
    9. Clean/lube rear suspension fairly often in the mud.
    10. Keep an eye on the kick start screws.
    11. Michelin x-11 Tubless with the Tubliss system works fantastic.
    12. Check and replace AAA rechargeable batt in Easystart box.
    Loads of fun!
    • Like 1
  16. Spoke with Lewisport today. Looks like my bike is leaving the factory this week and should be here by Mid August or end of August. Fingers crossed.
    Sounds great!
    Keep me posted. Do you have a copy of the manuals? I can send them to you.
    Mark
  17. It would be nice if the factory could get him more bikes. From what I understand almost all are pre-ordered or sold quite rapidly.
    I rode a TR300 that had the factory upgrades. Definately snappier power (even on the 'soft' power setting) over my 280 Explorer and the TR280 I've ridden. I liked the suspension also (rather short ride).
    I've changed my Explorer to an Ohlins from the TR- too much money but much improved. I would have liked to order it with the full TR suspension- but was in too big of a hurry. I think it should be a standard option.
    Mark
