Careful of filing the basket. I'm not sure if it is surface treated in any way. If it's anodized you may file through the harder aluminum to softer aluminum below.
You're straining at gnats Tim. Don't worry about the topping out. Much more important to have the suspension working properly for the usual maneuvers. If it's keeping traction and allowing you to do the tricks you've been working so hard on then it's fine. Start making adjustments for non-issues like topping out and you'll screw up the important settings.
Then again you can ride some big stuff with a very soft suspension. I've been watching Jareth ride 5' steps all summer and just a few weeks ago we swapped bikes for a day so he could get the feel of a Beta again since he's considering one. I could just slightly weight the pegs and the suspension on his Sherco went right to the stops. I still can't figure out how he rode the thing all year like that. I think I worried him when I went back to the truck, whipped out wrenches and readjusted his suspension. We went back out and he tried his bike on a log that he sometimes has trouble with and he just danced over it saying it was the easiest he's been able to ride it all year. Not surprised.
I've found I usually get 3-4 seasons out of a Beta top end before I need rings and in that case it's more a matter of loss of bottom grunt and slightly harder starting. I've never had to replace a piston. Just out of curiosity did this noise start when the weather got colder? It might be a matter of bad fuel or a different fuel. In the US the fuel companies change their fuel mixtures for the winter. The other thing that happens is the colder winter air changes the jetting requirements and for many of us it's necessary to go up at least 1 pilot and main jet size to prevent detonation. With the water-cooled chrome bore engines the carb jetting is very lean compared to the old air-cooled engines. This makes them run very crisp but also makes them more susceptible to atmospheric changes. The fact that the noise gets better with a warm engine sort of points in that direction as a cold engine needs a richer mixture.
If you do think it is piston slap have it measured. No point in spending money when it won't make a difference.
Oh yeah one other thing to check is the top engine mount. Sometimes they loosen up and make a noise.
There have been a few people asking about custom springs for Rev3s. A friend had a custom spring wound by Cannon Racecraft in Oklahoma for the rear of his 2005. He told them what bike and rider weight and is quite happy with the result. A heavier spring is not the same as cranking up the preload. With the preload cranked up there has to be more weight then the preload just to move the suspension. That means on small choppy stuff any suspension impacts that don't load the suspension above the preload weight don't compress the suspension so those small shocks are transferred directly to the frame. Not good for holding a line. Less preload on a heavier spring will compress on the small hits while still having the same response at high suspension load situations such as zaps.
... if memory serves, more than 108 decibles in a confined space is enough to make you ears bleed. Hence the little b***ards wont be able to stay in there long enough to nick your pride and joy
Hoaky smokes Bulwinkle! Sounds like somebody had the flywheel off before you and didn't torque it back on properly. Glad you found it though. There was some discussion on here a while back about tightening the flywheel nut and that it should be done with a proper holding tool or an air wrench. Trying to tighten it holding the back wheel won't hold for very long.
There was a previous thread on the subject here. Curiously enough also on a 2004. Hmmm.
Kill switch didn't get gronked. The Beta kill switch is notoriously bad any way. Should be replaced with a Yamaha switch.
Carb didn't get knocked of the mounting.
New plug.
Throttle cable isn't pulled.
Spark plug cap screwed on tight and on the plug correctly.
Ignition wiring didn't get pinched in fall.
Cylinder full of fuel. Seen it, done it , got the burned tee shirt.
Note I wrote to self after Bultaco fire. Don't kick it over looking for spark with the plug out is you suspect there is fuel in the cylinder. Fortunately nephew had extinguisher handy.
A fall shouldn't break the electrics unless wire is pinched or the flywheel key is sheared off in which case it was a crash you wouldn't be too anxious to ride after anyway.
It may be a little less obvious then Beta vs Montesa. Don't get me wrong, I love my Beta Rev3 but I've a healthy respect for the Montesa chassis design. I've observed in the past there are a few things that seem like issues with a certain bike that are more setup problems then inherent in the design.
If you find your bike is unable to hold a line you may want to take a good look at your suspension setup. An unbalanced suspension front/rear can make it difficult to ride in the choppy stuff. Depending on how you like to ride most trials suspensions will eat up about 1/3 to 1/2 their travel with the rider static on the bike. You'll probably see mechanics off the bike loading and unloading a foot peg to compress the suspension and watching how it reacts. They're looking for a couple of things. Besides the obvious of spring strength they're looking to see how fast the suspension rebounds as well as the balance of the suspension front/rear. Balance of this type is often overlooked by inexperienced tuners even though is of tremendous importance. Think about having a perfectly tuned front fork. Every hit of the front wheel is absorbed properly. The initial compression involves only the wheel mass and the chassis and rider weight are slowly integrated into the system as the spring releases the stored energy. As the same hit passes under the back wheel the rear suspension with way too much preload transmits rather then absorbs the impact. This causes the rear wheel to lift a much greater percentage of the weight of the rider and bike in a much shorter time span then if the rear suspension was tuned properly. With a step of decent size the fact that the rear suspension is too stiff can transfer considerable energy to the forks as a rotational torque. The abruptness of this can make the handling of any bike tough to control.
The opposite situation can occur with a too soft rear suspension as the front wheel bounces off obstacles and by sheer compressive torque load and unload the rear suspension. With the front and rear suspensions balanced properly there is much less of the rocking horse effect that makes holding a line a full time job. Try the bounce on the peg test for yourself. If you push down on the peg with a foot and the front or back compresses noticeably more then the other you might want to spend a few minutes with the spanners to try to even them out. I think you'll be pleasantly surprised. Do note the starting position of the adjustments before you start though so you can return to zero if you really over do it. Once they're balanced then you can tweak the preload to taste keeping an eye on the balance.
The other thing I've noted is that when a bike is reputed to be too powerful it often isn't the power at all but the delivery that is an issue. As an example I had a '95 Beta Techno with the then "new" DelOrto carburetor. The way the bike came jetted from the factory the pilot jet was about two sizes too big and the main was about two sizes too small and the needle was just right. The bike ran OK and seemed to have plenty of power. In fact it seemed to have too much power and was always spitting me off. I found it was almost impossible to time an obstacle because the bike was bogging slightly off idle until it got to about 1/4 throttle. It would suddenly get very interested in the proceedings and make all kinds of power. This caused me to hit things way too hard as I was afraid to stall and subtle throttle corrections during a maneuver had no effect. At first I thought the bike just made too much power. Unfortunately it was impossible to get jets for that particular carb at the time so I replaced it with a Mikuni. Once jetted properly the bike was a different animal. The mid-range power was still impressive but the ramp up to it was butter smooth. It was possible to flow with the bike rather then hammer into obstacles and if I needed to feather the throttle halfway up a climb to regain traction it could be done without the inevitable wheelie and crash with the DelOrto. The same carb swap was done to a friends '95 with similar results.
There's a lot of very good Montesa tuners on here who can help get your bike where it should be. Every bike and rider can benefit from a little custom tuning. Don't settle for less then a properly tuned machine when you don't have to. Once it's setup properly you may still consider switching brands but it won't be because your bike isn't a "good beginners bike"
Note to all...some may not agree with these suspension and tuning beliefs but I'd rather try to help a fellow rider then get into a brand war even though I do appreciate the comments about my beloved Betas.
True enough but the BRC has done nothing around here and that is the problem. We have been divided and are being conquered. The heart of the issue is all politics are local. An organization like BRC and AMA are only as effective as they can be at getting the people they represent to get off their duffs and make themselves heard. Unfortunately as a group off-road riders are notoriously independent and getting them to work together is like trying to herd cats. This has worked in the favor of those who want us gone all too well.
I think this is a good move. AMA can't be promoter and service organization. It's almost impossible to be promoting the same sports you have to regulate. It's all too easy to start chasing the dollar. Now people usually sign up for the AMA because they need to for insurance coverage. The problem is that means a significant number of the non-racers don't sign up believing there's no reason to. If those people can be shown a real benefit to sign up such as a more active AMA political structure more will sign up and the clout of the AMA grows making it even more effective.
Tough call - Satisfy your desire to win a competition or satisfy the people who pay your wages and provide the machinery and team that put you there in the first place! Unless they are rich, I think I know what most people would do!
According to the articles I read the other team riders were there solely to advance Broc to the championship. None of them was in contention for the overall and Yamaha "stacked the deck" by entering riders who had contested other series all year long. I find that more disturbing then just the team order to let Broc by.
This is exactly the reason why NETA does it's end of year trials scoring by recalculating the event points placement only by riders who qualify for year end points. It's a pain but it ensures the scores are rider to rider and can't be influenced by any third party unless they are also in contention for that class.
You can probably get used to a stock 250 or 270 and much of the difference from bike to bike has to do with the state of tune. I've ridden my friends 250 quite a bit and compared to my 270 his is more aggressive. Then again his bike was Donato Miglio's minder bike so I think it's a little... er tweaked. One thing that most will agree on is a bigger engine is more tiring. If you're not able to ride 2-3 days a week or work out the upper body in the gym then a stronger engine is not your friend. It may seem to be no problem in the parking lot but after a few hours you may find it getting ahead of you and that seriously can ruin your enthusiasm. Proof of that is any review of the 125-200cc bikes that usually end with a rave about how much fun the little bikes are.
There are very few novice obstacles that require even the power of a 250 as is demonstrated by my friend Bill who routinely cleans stuff I crash on with his little 200cc four stroke Scorpa. It's more important to find a bike in good shape that feels good to you.
Don't worry about being on the large side. You've got lots of company.
Ohhh the knocking ain't right. I think that's more then the clutch but I'm sure the dealer will straighten it out.
I polished both sides of the tabs. They get jammed into the basket one way under power and the other way when decelerating and I want them to slide easily in both situations. Besides I wasn't too picky about putting them back in the way they came out. Just to be sure we're on the same page here I'm talking about the sides of the tabs where they fit into the slots on the basket. I was looking into making a sort of UBER-clutch for the Beta with nickel plating the basket fingers and coating the tabs with some lubricant like teflon but I sort of ran out of interest once the polishing trick worked. I might still investigate it in the future.
I left the bolts out. They're in my toolbox next to my jet kit. I ordered an '08 but it won't be in for a month so I can't tell you if they have the same issues as my 05. Only way to know is to pull out the clutch pack and look at the tabs on the fiber plates. If they have the rough finish polish them, clean them and put them back and it's a world of difference. Don't just remove two springs without polishing the tabs. That would be a colossal mistake. My theory is the heavier springs are a stop gap fix for the poor bearing surfaces on the fiber plate tabs. If I'm correct then just removing the springs without polishing the tabs will cause clutch slippage.
I've been riding for two years now with four springs and the clutch shows no slippage yet. I thought I felt some yesterday but it was a patch of ice. I'm about 220lbs and ride the clutch constantly It is soooooo good now and my clutch finger doesn't get tired after four hours of riding unlike the the stock clutch. There is one thing that you may find with the clutch and that is the oil is particularly important to the engagement characteristics. A lot of guys will tell you to use automatic transmission fluid. I tried that once in a Beta and the clutch was so grabby it was almost impossible to ride. I use Spectro Golden-Gear oil now and I love the clutch on my '05. After you get a few hours on the bike for break in you might want to change out the gear oil. Sorry to say that if it is the gear oil making your clutch grabby it will take a few oil changes to purge the gearbox of the bad oil.
It's too bad you're not in my neighborhood. I'd have that clutch pack out of your bike and you lovin' that machine in no time. Let me know how it goes and If I can be of any help.
If you've found a bike that makes your heart beat a little faster and puts a smile on your face you win. I wish you many years of trouble free play and may you only need to pick up a wrench when you buy it a present like a titanium muffler. If you come to New England I hope we can go riding.
Really the heart of trials is the local club. That's where you'll find other people to ride with and places to ride. Nothing advances your ability faster then riding with more experienced riders. So the big question is what part of the US are you in.
Sherco Cabestany Stalling Problems......
in Sherco
If it's just suddenly shutting off I'd agree that it sounds electrical. A defective kill switch will do this.
