These are the overall ratios with standard gearing as delivered from the factory 11/46 [M159] 11/39[199A & B]
M159 M199A M199B
1st 37.7:1 37.7:1 37.7:1
2nd 29:1 29.3:1 29.3:1
3rd 22.4:1 22.3:1 22.35:1
4th 13.7:1 13.7:1 16.4:1
5th 9.9:1 8.4:1 11.4:1
6th 8.4:1
You can see 5th is taller on the 199A gearbox and all other ratios are near identical on the 5 speed boxes. Fourth and fifth are different on the six speed box
The reason the bikes have a higher top speed is the changing of the final ratio from 11/46 to 11/39 which still keeps the first four gears the same overall ratio, but allows an overall taller top gear. The change also obviously uses a smaller rear sprocket as well, so less likely to be damaged.
11/46 is the correct gearing for your bike and should be fine, never seen a 10t front sprocket and I certainly wouldn't recommend gearing the bike up by putting a smaller rear sprocket on it, would make the bike a nightmare in any tight sections.
You can get equal enjoyment out of either type of bike, so I would suggest you buy what your friends are riding or what bike is better catered for in the area / club you intend to ride at. Having said that there differences in riding both types of bikes, the newer type all require the use of the clutch to control the bike whereas the older twinshocks can be ridden without the clutch and have less power and in some respects this can make them less of a handful.
I had the same experience with my brand new 199- paint washed off in places,swinging arm mainly, after riding in muddy conditions and I didn't even use a pressure hose! Ah those were the days
Do any of these ignitions have an advance built into them and provide a performance improvement or are they just to do away with the points and provide reliability?
Thanks Mark that sounds like the one he has. As I said this was talking to him on the phone, not actually seeing the problem. I would think it would be next to impossible to fix by the sounds of it. Found this photo.
Hi, just talking to a friend on the phone and he has a 198 red plastic tank that is leaking around the fuel tap area. I know these are different to the later A and B models which have the two 6mm screws, but we are not sure what the actual tap screws onto, plastic or a metal insert? and he is reluctant to try to over tighten it without knowing what he is dealing with.
Although they will run within a large range of timing settings, it is quite alarming to see how much difference a small adjustment to the points gap can have on this timing. For the bike to run at its best you really need to make sure the timing is done first before looking for other problems.
This may be a long shot, but I had a freshly rebuilt bike do something similar, points, condenser, kill switch all new but I couldn't get it to run correctly. Swapped a carb off another bike but the problem persisted -very similar to the dreaded condenser failure. So out of frustration I decided to replace the brand new condenser, thinking it could have been faulty, with a spare I had. Well during this exercise I uncovered the problem, on the points there is a threaded hole where the two wires are attached, this hole was not threaded all the way through and so the screw was bottoming out without actually putting a lot of pressure on the two wires, so under load all these problems would arise due to this poor connection. I guess I should have picked this up when putting the bike together back I'm blaming old age and not so new eyes.
Cheers Greg
PS I should mention that sometimes the bike would run fine for a short while, so very frustrating and difficult to track down
Nice looking bike,rare in Australia. The only thing I could suggest is that it was a replacement frame, for whatever reason, and therefore had no numbers. No ideas other than that. I know recently a friend purchased a new Aprilia road bike frame and it was not stamped also I know of a recent purchase of a Gas Gas frame that also wasn't stamped.
2850 trucks leave our plants a day with significantly more complexity. Average days on dealer lot is less than you would assume. Buy a ticket to Detroit and I will show you. Impossible is a word for the weak.
--Biff
Not sure what you are implying here, there is no point making more bikes than you can sell? Surely to be competitive they need to keep the workforce gainfully employed all year round and this would dictate how many are employed and how many bikes per day fits that equation.
Bultacos are relatively easy to restore in that they are a very simple bike to work on and you can buy just about any part for them. The cost of the restoration is down to a number of things, firstly is the bike complete - it will generally be easier to recondition/ refurbish parts than to source and purchase second hand or new parts that are missing. Also the amount of the work can you do yourself, or are prepared to do yourself will have a huge affect on the final price of the restoration. Another consideration is what standard do you want the bike completed to - concourse or a bike to compete on and enjoy. I am biased but all the sherpas in my opinion look great and are great to ride when set up correctly.
Back when I stared riding in 72 Sammy Miller was the Toni Bou of trials and he had a great range of products that were highly sort after out here in Australia. He sold mufflers, air boxes, fork braces, handlebars, hubs, lighter tanks and of course frames. I vaguely remember something about pistons as well. There were two miller framed bikes where I lived but I never rode them as I was only a mug back then and was not game to ask for a ride on them. This miller mystique for his products began to fade as he stopped riding bullys and the younger riders like Lampkin Rathmell and Vesty took over and the Bultaco bike itself improved with each model.
Yes the backbone can bend if the head steady is broken or bent as was pretty common in the late 70's. The miller frames were the bees knees so to speak in the early seventies as they had improved geometry [shorter, quicker steering, more ground clearance] were lighter as well as they were made from reynolds chrome moly tubing. Also the tubes were removed from under the engine, another emerging problem area. However the model 125 released in 1974 pretty much copied the miller dimensions and was also made from chrome moly. The only real difference was the tubes still remained under the engine. So by the mid seventies the miller frames became rarer and rarer as the factory frames narrowed the gap. I would imagine there would be not a lot of difference strength wise between the two.
Trials gearing 191 Sherpa 350
in Bultaco
M159 M199A M199B
6th 8.4:1
