In the english text of the owners/service manual (downloadable from http://www.betamotor.com/en/support/manuals but probably supplied to you on CD) they incorrectly show pictures of the 2 stroke engine when talking about checking the oil level and refilling. The pictures included in other language texts are correct, however. The pictures for removing/refitting the filters mentioned by lineaway are correct within the english text.
As with earlier versions of the engine the lubricant appears to be shared between motor, gearbox and clutch, with only one drain plug and one refill plug.
Recommended by UK importer to use a fully synthetic oil.
Hi guys , think i may have head gasket gone , any tips on replacing would be very much appreciated. I do have a download of the workshop manual which is quite good as a start It m.entions about a tdc locking bolt but im not sure exactly where it is !.Do i need to remove water pump shaft or can i leave it in place and just drop chain off camshaft sprocket . Thanks Rob
The locking bolt is a normal allen headed set screw located on the lower right hand front of the crankcase. It is shown as item 7 on page 51 of the workshop manual. Under the head is a copper (or is it brass?) washer. Remove the washer and screw the bolt back in again and it will seat completely when at TDC as it's machined end sits in a recess in the crank. No force will be needed but you will have to jiggle the crank back and forth to get the right position. DO NOT LOSE THE WASHER as it will be needed when you've finished to ensure the screw doesn't contact the crank when running.
Don't remove the adjacent silver headed screw, that is the oil pressure relief valve.
Can't help with the specifics of head removal, but I think you have to remove the water pump shaft in order to get the chain loose.
I suppose we should be grateful for the coverage we can get, but I do find the commentator frustrating, and the coverage in general, poorly edited.
The commentator rattles off what riders have scored on various sections throughout the trial which I must admit I can't keep in my head (must be the age!). Meanwhile the pictures are not well linked to the commentary. For example we do not know what section number is being ridden so there's no way of telling if the threes (or twos, etc) we've heard about are what we're actually viewing.
Rather than successively showing each rider through a number of different sections I'd rather see the material that they've recorded edited differently to show each featured rider's attempts through the first recorded section, then showing the next recorded section and so on for each successive lap. Basically much as one would see if attending a trial. That would miss out some sections, as at present and as one typically would at a trial. The commentary could then focus much less on the individual section scores (as we would generally be seeing what each featured rider scored) and instead he could build the tension, such as comparing with what previous riders have been scoring on the section being viewed. He could also add background information (eg Dougie Bou is struggling with a left foot injury, or Sherta are trying out a new airbox).
I recognise that many fans will know the result before viewing the coverage but a re-jigged editing would still create a degree of tension and actually tell a story, unlike at present.
However there has been an improvement from previous coverage. We have fewer instances of a cut to a crowd scene just as a rider is attempting the most difficult part of the section!
I bought one last week from splat shop. I used it today at the Kia twinshock championship trial run by the zona1 club. I found it comfortable and a good fit. I weighed it to compare it to my old carbon fibre hebo it is 50grams heavier so very light also i had lots of good comments about it! And the price is fab.
Brought one Saturday, sounds strange but sits higher on your head then other helmets, its light and comfortable. I brought it as liked the shape and the price.
Now to work out how to remove the lining to wash it haha
Thanks for the information itakeafive. It seems as if there aren't many of them around yet!
Quote: "I’m pretty sure that once upon a time there was an ACU ruling which said that non-starters should always provide the club with a valid reason and if they didn’t then they would be reported to the sport’s governing body. However, as far as I can see that regulation no longer exists – though if it does I’m happy to be corrected...."
For info, Mike, the ACU National Sporting Code says
7.20 Absentees
1. Unless it can be justified, the absence of any competitor who has entered a competition and is not present at the start shall be in breach of this Code.
7.21 Withdrawal of Entry
1. The Entrant/Rider may only withdraw the entry with the permission of the organiser.
However I'm not aware if this rule is still enforced in practice.
Slightly off-topic but I believe non-starters are a particular concern for organisers of grass track, moto cross and road race events where paying spectators may be attracted by the advertised appearance of certain riders and very disappointed (or feeling cheated of their ticket price) if those riders don't turn up.
Lampkins could never find a part number so couldn't provide a replacement. I ended up using something I had in the workshop, although it seals off the tube completely.
I couldn't detect a difference in the performance (save that the backfiring problem mostly disappeared) but perhaps it explains why I still ride like a wuss!
All of this implies you could use a motor cycle helmet made without any specific approval from a recognised safety body - but surely no one would be so daft?
If there is any road work your helmet will obviously need to comply with local road traffic requirements.
When they were in business I obtained just a boot from BVM in Stroud. I think it was for an AJP master cylinder but do not have the part number. Although they had advised it was suitable for the Beta it was a slightly smaller diameter where it fitted into the master cylinder casting recess. This meant that as the clutch lever was used it popped out of the recess, rather defeating the object! BVM adised further that people used a drop or two of super glue to hold in place.
As I wanted to have some grease inside the boot (to help prevent the premature perishing) and grease and glue don't work well together I returned the item and went the full Grimeca overhaul kit route.
This little rubber part goes over the atmospheric equaliazation tube for the slide diaphragm on the carb. Otherwise known as the angled shiny part at the tops side of the carb.
This angled spigot tubes job is to let the slide breath/move freely as it adjusts to the pressure differential as the slide moves up and down.
If one where to block this angled spigot's hole up completely (epoxying it) the slide would not move up and down correctly.
With that being said, leaving it completely open lets it breath properly, Caveat: If it was left completely open because it points straight up it is VERY prone to water getting into (washing the bike) and also dirt. It is best to take a rubber hose put it on the spigot and let it arc or bend over gently facing downwards. The little rubber cap installed from Beta just lets it breath enough for it to function. In the normal application of this CV carb i.e. dirt bikes, quads etc it would have hose attached to it.
Cheers
Billy T
Just trying to clarify what you are saying.
You say the angled tube lets the slide diaphragm breathe enough, but there's no hole in the cap, and it is a tight fit. If the tube should be left open to allow for the equalisation of pressures then why do Beta fit a cap which seals off the tube?
Is this a Beta 4T. If so this part is an important little part.
Yes, it's a 4T BillyT.
You say important so do you know what are the consequences of it not being fitted? Just that the bike was recently intermittently backfiring on overrun when it had not done so before. That was why I took the carb off to check it over.
99% sure it blanks a pipe off on the top part of the carb poss on right side think its a shinny right angled pipe
Thanks Zero.
I thought about that but the inner diameter of the rubber cap was too small meaning it was really stretched to go over the shiny right angled pipe (called oil breather joint in the parts manual, but I'm certain there was no oil breather pipe connected to it). Perhaps its split because the diameters are wrong.
At the moment the pipe is open to atmosphere and I did think that strange.
Couldn't see anything listed in the parts manual which looked close.
I took the carb off the other day and didn't initially notice this rubber "cap" had fallen off from somewhere. It was lying on the top of the crankcase when I went to put the carb back. It was lying just under where the carb sits.
It has a hollow interior, just as if it fits over a spigot of some sort.
I cannot see where it has come from. The only possible place I can see is that it fits over where the mixture screw is, just under the engine side of the carb venturi.
Can anyone help with its proper location?
Incidentally the rubber has already perished, hence the split which can be seen in the photo.
Portman, your year might be different. My manual says
"The capacity of the fuel tank is approximately 2.2 litres, of which 0.35 litres is reserve" - it also lists this amoun in the specs.
But I notice your 2012 EVO 4T manual says (on page 50)
"The capacity of the fuel tank is approximately 2.5 litres."
No mention of reserve anywhere in the manual.
So in this case you might want to consider a fuel valve. Another option is to put an electrical switch going to the electric fuel valve. If having both tanks "on" the fuel would likely pull from both depending on fuel height in the tanks - although I have never experimented with this.
TT, thanks for your research. I think the best way to make this work on the Evo 4T is to initially have the fuel tap on the auxiliary tank OFF which will mean that the main tank will drain first. Once the main tank is dry/nearly dry then the aux tank can be turned ON to then use that fuel supply as well.
Incidentally, does the long ride tank have a reserve setting on it's tap or is it just an ON/OFF tap?
GEAR AND CLUTCH OIL - Beta Evo 4T
in Beta
Betasweden
