17 -
Thank you very much. This means that there is a chance that basic service can be carried out using them. Thanks to this, I will be able to use them in my fantic project. I don't have high expectations for them. after service, they should fulfill their purpose.
I have the same Explorer forks and since you disassembled it, I wanted to ask if standard dust and oil seal from marzocchi 40 mm fit to it ?
I was thinking more about consumable parts such as dust or oil seal, springs, bush kit, etc I can't find information or parts anywhere and I wanted to use them in my built Fantic Mono.
I wanted to ask if any of you know if parts from the original Marzocchi 40 mm fit into the Ossa Explorer Ollé Fornt Forks?
I would like to ask for help in 2 matters 🙂 one is what is the exact model of the carburetor? It is Mikuni 3M2 ? second, where can I get a repair kit for this carburetor 🙂?
I own TRS 300 2016. Last year in January my CDI died. I bought a new one and since then the motorcycle has been working normally. I never came to what caused the CDI module to be damaged. You can find the history of damaged CDIs in this thread "Trs 300 rr backfire then loss of power?"
This week in my TRS 300 2016 I had exactly the same problem I checked the carburetor and the entire electrics. After reading this topic I decided to check the CDI unit. I switched CDI from my friend's motorcycle. Unfortunately, I will also have to order a new CDI module. Thank you for your topic !
I have TRS one 2016 and I drive to this day without any problems. I changed from Sherco ST 300 2013 so TRS is still a great motorcycle for me. The only thing I could criticize is hard-working clutch rest works perfectly. I have no objections to the durability and quality of construction.
I checked in parts manual 2018 and there are actually three types of clutch spring support soft, hard and med. The only question is whether it will fit my 2016 clutch.
gleiwitz changed their profile photo
Unfortunately I have a problem with hard working clutch. I am a hobby rider and I compete in the hobby class. My TRS is from the first hundred that was produced. I absolutely love my TRS it is a great bike but my finger suffers a lot during competitions or longer training. I wanted to ask if anyone has already found a specific solution that will solve my problem? I would like to get an answer which part I have had to exchange to make it work easier and where to get it?
Heheh It will be funny when I will instal new pump and it turns out that it still does not work hehehe
Today I was practice and unfortunately the pump stopped working again I got upset and ordered a new pompe. I hope this will resolve the problem definitively.
Problem solved The cause of the problem was vacuum pipe. It was not visible but when I disassembled the vacuum pipe I noticed that hose/pipe clip was badly mounted at the very end which caused the hose to deform and consequently leak / catch the air. I mounted a new vacuum pipe on the lef side of carburetor where I my opinion is more space and pipe will not bends Thanks a lot for your help.
Thanks a lot guys for all tips. I will check the vacuum pipe carefully today. Just to be sure I will put on a new pipe and we will see
Thank you very much for your help. I will check it and if vacuum pipe will be ok then I will order a new pump because I am slowly losing patience
