had a mikuni on a beamish that had amal jets in it worth a try ,you also need to make shore vyou use a 2 stroke carb not a 4stroke one, also is the slide correct ?
i would play with the mikuni a bit but only change one thing at a time cheers
lots of people here and in spain use BPS ormore recently Magicals you can get both from Stuart at BPS on france(0033) 687383530
I've recently fitted BPS alloy body shocksto my 247 which are a lot better than betors you can feel the back end following the ground over rocks instead of hopping from rock to rock;
they now supply these fitted with ball end swivel mounts you see lots of these fitted to hondas
247.348 have the same seals part no 0099.2540D (internal diameter 25 external 40) both sets that I have fitted have been single lipped and so where the old ones
part no changes for the 349 although the parts book I have is for the final version and is 0099.2540SDE (same sise)I haven't had to replace these but i guess that if double lipped are standard it would be to deal with increased crankcase compression
where did you get the 24 from? if it is from the company that ground down the crank? if so it would be to deal with the grind down perhaps but seems to be a bit tight
i'd see if anyone else can shed light on the double lip question or contact http://www.brt-bearings.com they say that they can manufature oil seals to individual requirements ie 24.85mm they would also now if "SDE" means double lips
check that you also have enough fuel getting to the carb, I have just fixed a bike for a friend who was told seals gone or piston gone etc ,when I looked in the petrol tap the rubber gasket with the three holes had disolved into a sticky gum and completly blocked it,also check petrol cap vent , assume you have cleaned jets and set float height etc
you don't need to remove the clutch arm, case should come right off ...you can download a manual and parts book from the TODO site,
when you set up the clutch make shore you have 2-3mm of play at the handle bar;;;
also when you take the cover off note which way round the the brass piston fits onto the arm there is a small recess on one side -if it goes in the wrong way the clutch will slip and the face of the clutch spider pressure plate will become worn
this perhaps spounds a bit complicated but is straight forward once you have the cover off
Montesa Cota 247 - Bultaco Piston?
in Twinshock
Hi try here in stock http://kevinbreedonracing.co.uk/profile.htm cheers helm
