Are you running stock bars? I can tighten the levers on my '05 Rev3 with Renthal bars but Tommaselli bars won't properly hold the levers. The grips still fit though. Apparently doesn't take much for the lever perches to slip.
I need to buy a new chain for my BETA EVO,i have changed the front sprocket up a tooth,to a 12T.What would the ideal length be as the oringinal is a tad short.
Just stripped the headstock on my EVO,on reassembling,i notice the headstock collar that tightens the bearing cover down has a circular ridge on one side,should the ridget face down or up towards the handlebar clamp?
Just removed the R/H fork leg,to change oil,removed damper unit,was pumping it to remove oil,a very slim metal tube came out of the damper followed by a small silver bung/plug? i have checked beta service parts list,nothing shows these parts,help please???
I am interested in changing my standerd footrests on my EVO,looking for a wider footrest for comfort,cannot go to raptors but good value steel ones would be ideal,any info please?
I had a hard fall with the bike going down a 12ft drop,flipping over several times.I rode it today foe the first time to notice a clonking sound when i push the forks up and let them rebound,with the front brake applied,if the the brake is off there is no clonk,forks seem fast to rebound.
I have checked handlebars/top yoke,fork legs,triple clamps and front brake disc caliper,all are tight.
I keep having the same problem with my brakes on my evo.Everytime i wash my bike,leave it for a week,when i ride it the brakes have lost any bite,they squeal and groan but hardly stop,if i ride it with the brakes on,the front comes back about 75%,but the rear just rub with no real stopping power,i get them hot and squirt water on the disc,s when hot which helps but not cure.The only time i get good brakes is when i fit new pads.I do wash my bike with a pressure washer and finish it off with cleanng spray (muc off).Are they staying wet,should being damp effect to this degree?
How do you adjust the sag on my EVO 2010 250,i have read all the threads but still am struggling,i understand the measurement,but am struggling with the rest.
How do i adjust the rebound on my front forks?
How do i adjust the dammping on my front forks?
How do i adjust the rebound on my rear shock?
How do i adjust the damping on my rear shock?
How do i adjust the sag om my rear shock?
How do i adjust the sag on my front forks?
Sorry for the very basic questions,but i know if i ask you guys i will get the awnsers,please awnser in basic terms.
EVO Front Pipe Removal
in Beta
Hi all
I want to remove the front pipe on my EVO 250,the two fixing bolts seem blocked by the frame,is ther a easy way of getting at them?
Regards
