Just stripped my front steering,to find the bottom bearing being very notchy,should there be a seal at the top,as the bottom bearing is very rusty?how do you remove bottom bearing from the bottom yoke?
I am going to attend this years SSDT,but want to make sure i get to see two sections,being:The pipeline and the other is one that is always featured on DVD's,it is were they go under a road bridge which is always full of spectators and climb up the stream over rocks.I hope this is good enough descripton.My main question is were are both of these sections so i can plan to see both,also are they at opposite ends of the trial,or by any good luck,within a couple of days of each other.Any help would be great.
Just bought a new 2010 EVO 250,i am experiencing the same problem i had with my REV3,when the engine running,when stationary with the engine running,it is very difficult to change gear,let alone find neutral,alot better with out engine running.On my old REV 3,i did the clutch mod,which made it alot better.Surley i should not have to do this to a two month old bike??????????????????
How can i find out the oil quanity level in the front forks of my 09 xispa ,i want to change the oil and stiffen them slightly,any recomendations on increase levels of oil?
I have a 09 XISPA 250,fitted with a OKI 28mm carb,it is not running well from pick up,ok when on 1/4 throttle and more,any set up hints,i have dropped the main et as advised by vince.
The bike is very poerful for my beginner status,any way of softening the power ?
I had the same problem after 6 rides on both boots,importers were not interested said normal wear and tear,i bought a pair of sidi boots and are superb and still as new today.
BETA EVO Head bearing replacement
in Beta
Hi all
Cheers
