What was the final length of the spokes? I have a pair of akront tubeless rims from a 243 and I want to buy spokes for a rebuild using 240 type hubs.
I don't know the measured length of the spokes, I sent one short side and one long side samples to Buchanans and asked for the same length as stock,In retrospect I should have sent two short and two long samples,one from each direction just to make sure. I had chopped all the rest of the spokes so I couldn't measure once I started.It caused no trouble as I just ground off the protruding spoke ends.
Seems to be working,still holding air perfectly and I've abused it in rocks and it hasn't loosened any spokes up at all.
I'm gonna stick with a tube type front rim when I rebuild the front wheel.
You might check with the Grassroots Motorsports forums,no doubt some autocrossers havehitches on their Mister-twos to haul track tires on small trailers to the Gymkhanas to swap out when they get there.
The small diameter of the pipe would make it difficult to use the air pressure and heat method,plus who know what it would do to the titanium. I would recommend fabricating fittings to pump the pipe full of water with a pressure washer,I have not tried this myself,but I would do this before heating up a air pressurized pipe with a torch(Which I did do many times back when I rode hare scrambles)
Looks pretty solid , Does the packing screen slide out easily to replace the packing when needed ? Looks alot better than the WES I'm running now. I like the way the end caps come off for cleaning . And my Wes has a small whole rubbed in it ...
Glenn
I wonder if they are making more ? I'll have to contact them ...
Oh what the Hell,Glenn ask them if they'll make two...
Sherco 2007 290 is fouling plug, runs boggish, carb/airbox always clean. Could this be related to a failing stator plate or CDI box. I have a 2006 Sherco that I can swap parts from, but just wonder if this could be electrical/heat related. Engine seal?
Thanks.
sam
Pressure test costs nothing, gives peace of mind...
Runs a dream, it looks like the fuel valve and float height were the prob on the old one , but the 25 seems to make the littleun run smoother with cleaner bottom end.
Which jetting did you go with? My 240 never did clean up with a 25mm dellorto,CT Oko made it run great, alot like the 2009 Sherco I took a quick spin on last weekend.
BTW,when I took apart the Dell on my 309(249cc) it turned out not to have a idle jet in it at all,just the idle emulsion tube,will just stick in the 44 idle jet that was in my 240 and see how she does,only other idle jet I've got is a 33,gonna start rich.
... and then 249 engines....a keihin works best on that
L
I h
Which Keihin for the 249?(sorry for hijack,Lee,you can just P.M. Me if protocol call for it) As I've just begun to attempt to tune my 249 engine(In a 309) and would definitely shortcut to a Keihin if that's the ticket,have a CT Oko on my 240 works great,don't care which carb ends up on the 309,just would like the same response outa my AirMono bike as my twinshocker.
All done, Rim strip was kinda tough(my first tubeless experience) but I managed to get it in place.Tire mounted and inflated easily,took more than 50 psi to pop the bead(didn't feel like looking for my truck tire pressure gauge) No bubbles when sprayed with soapy water.
Also got my 1984 Beta forks on her.Had to drill out the sleeve in the left leg for the axle to slide through. Had to make a cable stop and mount it to the brace bolts as the Beta forks are disc brake.Made a new shorter brake stay.Had to clearance the backside of the upper caliper mount a bit to clear the brake cam as I didn't want to completely cut it off just in case I want to use the fork on my 309 later.
Here's the big news,the Beta upper clamp slid right onto the Fantic lower clamp,same offset and spacing,and the bar mounts are way forward compared to the 240.I have never seen 200 Fantic clamps but I don't see how they could move the bars any more forward without interfering with lowering the fork tube through the upper clamp. Note in the pic that I'm using the Fantic lower which is red and the Beta Upper which is black. So if'n yee cain't find a 200 clamp jus' rob some ol'junk Beta!
Got to put fork seals in The Beta fork,But just riding around the back yard they have a plush,well controlled feel.Managed to get good front brake action without much fuss,just holding the brake on while tightening the axle was good enough to duplicate all the braking action I had with the fantic forks.(fantic forks were cracked and the tubes were damaged to bad to hold a seal)
As soon as possable I want a set of these http://www.nuetech.com/index.shtml Wish I had known about them before I mounted up the michelins on the excel rims last spring ... Anything to shed a few pounds !
Glenn
I need to get a set of those for my KTM,it already has tubeless shinko tires(don't laugh,they are made from the old Yokohama molds with modern compounds,really good tires)
Years ago before Stans tubeless kits existed I converted my mountain bike to a barnyard tubeless with a tube for smaller rims by inflating the tube,slipping it over the rim,deflating it,cutting it around the outside edge,butterflying the cut tube out over the edge of the rim,slipping the tire over it,squirting a bunch of tire slime in,inflating with compressor then trimming off the excess tube laying outside of the tire.They've held air for years,and I haven't even rode it for two years.
Got the wheel tensioned and centered in the swingarm tonight,1/2 of the spokes on the left(long spoke) side protruded through the nipples by about 3mm,this was likely due to either me making the false assumption that all the long spokes were the same length(I only sent 1 long and 1 short out to Buccannon's for examples) or by the way the hub is drilled,doesn't cause any issue other than having to carefully grind off the excess. Saturday morning I'll fit the rim strip and valve and mount the tire.
Can't be worse than my old rim, It was bent every direction possible,only thing that could be said about it was the tubeless Dunlop never lost the bead on the tube type rim regardless of pressure.
Except for some large street bikes , I've never seen a bike with a t stat like a car , most are constant full flow systems , with the thermastat being a electrical temp sensor that controls the cooling fan circuit ...
My 640 LC4e has a T-stat, and so did the 380EXC I used to own, Since I have never owned or worked on a liquid cooled trials bike I did not want to assume.
"Rattly old air cooled 2-stroke" sounds like my 309( She's coming apart right after the 240 goes back together!) Check with Tryalshop,he likely has pistons if yours is hurt
You've confused me ... Are'nt the spoke holes in the rim punched to have a spoke nipple exiting them at a predetermined angle so the nipple seats correctly ?
Yep,that's why I moved the spokes over over 1 hole. The 305 hub has a shallower spoke angle but it's slight,I just reamed the holes a little bit and deburred plus used plenty of spoke prep,I'll tension,then prestress then retension and true,she'll be fine. If it fails I won't sweat it,there's plenty of used stuff out there to build another.
If you want the valve stem to come out between two groups of four spokes you'll see that they need to be shifted over,lay a 305 rim on top of a 240 rim and line up the valve stem holes,on one rim the holes will be angled up and away from the valve stem hole left of the valve stem and the other rim will be angled down and away from the valve stem(kinda hard to describe,You'll see what I'm talking about if you stack the rims)
I didn't notice this until I had already ordered the spoke,It may turn out that I do need shorter ones for half of the long spokes,won't know until I center and tension the wheel.The rim looks to have a deeper center but on my rims it seems to be a optical illusion due to the different cross sections. If you're not in a hurry wait a few days until I can get back on this and make sure I haven't screwed this all up and have to reorder spokes,I've only really built bicycle wheels and there's online spoke length generators to get your spoke length correct for bikes,I told Buccannons what lengths I wanted and sent them samples,and screwed that up and only sent them 1 short side and 1 long side,the short side has different inner and outer spokes,duh,I just bent the outers a bit more myself and the length was ok.
I'll take a picture with a camera instead of a phone for ya when I get back into the garage.
BTW,found a cracked sprocket mount ear on my 309 rear hub after I had dissassembled the good 305 wheel I had for it's rim,now I'll have to build a new wheel around the good 305 hub,I'll have to find another good 36 hole tubeless rim(or find a later model wheel that can be adapted to fit)
Got a 305 rim laced to my 240 hub.gotta tension and true it up yet.
had to shift the long spokes over one hole in the hub due to the rim being drilled opposite as far as the valve stem hole position.
Same length spokes as stock rim.
Rim strip and valve stem from Mike.
Cracked the original rim due to jumping up on rocks and smacking it where it was already dented
ebay wheel was actually fairly straight good enough to be worth lacing up.
Will replace the front rim later as it's beat to hell too.
Unfortunately I'll miss the first trial of the season this coming weekend,gotta trail building session tomorrow night(I've got about eight sections built at a friends property,room to make probably 30 more!) and then a club meeting thursday where we redirect the club back into trial riding from putting on races(kind of a little coup)
Damn Glenn,as I was reading this just before heading out to work this morning I thought the same thing,didn't have enough time to post it then,logged on here and you beat me to it.
Do Sections have a thermostat? cars have a spring in the suction side hose to prevent hose collapse when the t-stat is shut,maybe your t-stat is not opening? I dunno,I'm still a aircooled trials guy
Are you saying that on your bike once the cable is in place with the handle bar and fork leg adjusters in a "reasonable" position, the length of the inner strand from the bottom of the fork adjuster (ie where it comes out of the bottom of the fork leg adjuster) to the nipple (ie brake arm) is about 2 inches ??
Rob
I cannot measure mine as it's apart,I'm swapping on a Fork from a later model Beta and will have to fabricate a custom cable stop and build a cable to fit,You should verify that your brake anchor is the stock one,if it has been replaced with a fabricated one it could have repositioned the lever in relation to the cable stop.
Fantic 309
in Fantic
I have no info myself,I get my details from:
Bob Wright 305 manuals
some info here:
http://www.fantic.nl/
http://www.fanticmotor.asso.fr/
BMZ helps cross part numbers:
BMZ 309 parts
Google translator sometimes helps with the sites enough that I can speculate.
