79 -
Was there or is there discount on the "16 rr in the UK does anyone no? Cheers Marty
Where are you from? North or south? Trials practice ground in Newtownards "leadmines" Run by Moto-Trial NI Marty
I'll be up to see you shortly ken !!
Morning Apart from Dave Dawson Does anyone use the Maxton rear shocks Thoughts on them? Marty
Never thought about the valve clearance I havent checked it since fitting the 280 kit Must do that later Many thanks Marty
Thanks for the replies Easy started cold just a bit of s bugger yo start hot Marty
Is there a better plug than the std ngk for the 4rt? Iridium or the like? Cheers
Cheers Charlie Ill google it to see if i can get pics of it Many Thanks Marty
Guys i am after a modern Rigid frame for a villiers 8e Is there anyone making such a frame or is it just me thats mad!! Cheers
I use it but changed to dimple plates at the same time Made a super job of it!!
Thanks Woody I'll troll the net in search of a 305 parts book Cheers
Hopefully this makes it clearer
Thanks Woody I'll sort done photos tomorrow
Guys would anyone have a diagram of the dapmer rod assembley? Not sure which model as some has fitted them to Trick pre 65 forks Seems to be 2 different set ups Thanks Marty
Thanks Presume that there is little or no difference between the mitani and s3 kits/ Going to try a exhaust and remap first i think Marty
