Report View From Kinlochleven in Pre-65 Bikes Posted May 6, 2010 It was my first Scottish and a week later still amazed how well organized it was The sections where i thought very tricky but enjoyable Thanks again for a great weekend Marty D
Report Fuel Tank in Classic Trials Posted April 17, 2010 Thanks Dave i am at the moment using a SWM steel tank the shap and fit are quite good Just that empty its 5kilos!!!! Someone decided to take the dents out with solder rather that a modern lightweight filler Marty
Report Fuel Tank in Classic Trials Posted April 15, 2010 Thanks they look like a nice shape but wasnt sure about the durability is there a off the shelf alloy tank that can be bought? Marty
Report Fuel Tank in Classic Trials Posted April 13, 2010 Has anyone tried the tank from D and c Motorcycles? It is a fiberglass tank Im Looking for a low narrow ish one http://www.dcclassicmotorcycles.co.uk/part..._fuel_tanks.htm Thanks Marty D
Report C & D Results in Sherco Posted April 11, 2010 Well done to all But GREAT result for Reece Gazzard from N.Ireland Marty D
Report 240 Shock Length in Fantic Posted April 6, 2010 Thanks for that !! Go now and find them Marty D
Report 240 Shock Length in Fantic Posted April 5, 2010 · Edited April 11, 2010 by MartyD Can anyone tell me what lenght they are using on the 240?? Took them off and placed them carefully in a pile more shock and i diny know which is which Thanks Marty D
Report Michelin Tybe Tyre in Classic Trials Posted January 17, 2010 What do you mean usually your own fault when you get a pinch puncture? Do you double tube?? Marty
Report Michelin Tybe Tyre in Classic Trials Posted January 17, 2010 Have been running one of the newer Michelin tube type tyres I think they are crossply construction Been out three times and 2 Nip punctures so not a good ratio Running 6 psi and its on a B40 I also have the same tyre on a Tlr 250 and it seems ok Could it be a combination of heavy(ish)bike and softer sidewalls? Anyone else have the same probs? Marty D
Report Amal Carbs in Classic Trials Posted December 6, 2009 Thanks i thought that the 28mm was a bit big it is a bit( Woofy) of the bottom Marty D
Report Amal Carbs in Classic Trials Posted December 5, 2009 thanks for the fast replies it was that i have 2 b40s one is running a 626 (26mm) and the other a 928 (28mm) i new there was a size difference but was unsure of the difference between the 600 and 900 series carbs What size does everyone else use on b40 trials?? Marty D
Report Amal Carbs in Classic Trials Posted December 4, 2009 · Edited December 4, 2009 by MartyD Can any one (im sure you can)tell me the difference between the 600 and 900 series carbs?? Thanks Marty Drennan
Report Rear Brake Pedal in Classic Trials Posted November 22, 2009 Thanks for that info BUT Had a better look today and dont think it can be done when you get the brake pedal in the right position the kickstart fouls it I think ive tied a lot of different pedal shapes but no good Any ideas or pics?Marty D?
Report Rear Brake Pedal in Classic Trials Posted November 21, 2009 Does anyone have any suggestions how to move the brake padal to the( proper) Right hand side of my B40 Have tried now for 3 months and just cant get onto it in the left What lever /cable set up do you think?? Jackson frame and cub hubs Marty D
Report Irc Tyres in General Trials Talk Posted November 20, 2009 I ran the Mitas on a 250 tlr thought it was hard but griped Real well in all conditions but as said dont think it would be the job for a new bike But in saying that i am running a pair of Michelins on both Tlr and B40 Marty D
Report Irc Tyres in General Trials Talk Posted November 15, 2009 I have used the Mitas here in both mud and rocks on a Tlr 250 Great tyre in the mud as the profile is rounded ,meanig that you have still a good tread while leaning the bike over Found it also good on rock as you were getting good grip on the mud before Great wear rate Marty D
Report Bantam/cub Brake Shoes in Pre-65 Bikes Posted September 27, 2009 Thanks Charlie What do you mean elongate the pivot did you file a larger "Hole" in the shoes?? I think that i am getting closer to a alloy hub Is it Alan witton that does these? Alsois there a alloy brake plate aswell? Marty D
Report Tlr 200 Spares in Honda Posted September 23, 2009 Dave silvers ( i use them for myTLR250 )have a lot of origional honda parts as do Appleyards MartyD
Report Bantam/cub Brake Shoes in Pre-65 Bikes Posted September 16, 2009 Got the hubs back into the bike to night after getting them back from the machine shop And what do you know,even with .75mm clearence still SPONGY!! Anyone tried very small discs inside the hubs????? i hope that when bedded in for longer they improve Marty D P.S what oil do i use in the B40 and what quantity?
Report Bantam/cub Brake Shoes in Pre-65 Bikes Posted September 8, 2009 Will hope to ahve the hub back from the machine shop by the weekend think that all the adviceso far is great A lot of different ideas to give the right end result The frint hub was 140mm I/D and the rear 142mm Obviously the rear badly worn As im (new) to this mad world of Classic \Trials im not sure on a lot of things ( Have a 4rt as well) What else does Tricky Micky do?? Marty D
Report Bantam/cub Brake Shoes in Pre-65 Bikes Posted September 7, 2009 I think that by spacing the cams/pivots out the diameter is possibly wrong?? Have taken the hubs to a engineering shop and hes going to sleve the hub to 138mm id think that if this is done the brake shoes will be (Off the shelf) fit The easest way was just to find a set of 140mm O/D shoes but i cant find them Thanks for all your help Marty D
Report Colley Gas Gas in Gas Gas Posted September 6, 2009 Not sure if the right place but, the Steve Colley TXT Gassers can anyone remember when they where made would really like one and I know going to be hard to find one Does anyone know of any for sale? Marty D
Report Bantam/cub Brake Shoes in Pre-65 Bikes Posted September 6, 2009 Std brake shoes are 138mm o/d x 25 width Does anyone do a set of 140mmo/d x 25 mm shoes The i/d of the hub is slightly below 140mm(139.8) The brake is very vague and spongy so i thought a larger dia set would be better Any advice?? Marty D
Report Best Upgrade Footrests? in General Trials Talk Posted September 5, 2009 Think that BVM Moto have 3 sets of raptors in stock Marty D
Report Bsa B40 in Classic Trials Posted August 11, 2009 Will have to do a plug test i advanced the timing that helped with the punch What type of yokes is best ? And how much am i likly to exchange for a billet set Are they worth it? Is the billet clutch that burtons sells(200 odd) worth the weight saving and does it let the engine rev quicker thanks again Marty D
in Pre-65 Bikes
Marty D
