October 3, 200620 yr hi all just got a 06 270 beta what a bike i had a 05 270 and the power diffrence is great i llove the bike,what check should i do after every ride,i clean and oil air filter,check all bolts are tite,check the chain is there any thing else i should do any help would be great thanks:D
October 3, 200620 yr Nice one mate, keep a good eye on the disc bolts, have a habit of coming loose as well as the rear bash plates ones and exhaust bracket. Keep the carby nice and clean and may be worth changing the stock kill switch for an after market one, I was warned about it and its worked good for the past six months but let me down twice on the weekend so swapping it tonight. If you can save some notes get some Raptor pegs they make a big difference to the riding and plug up the hole in the rear mudguard where the loom used to go through for the lights. If its p***ing out petrol get BVM or Lampkins to do the carb mod, well worth it along with the float extension bowl.
October 3, 200620 yr why are the raptor pegs a better job. also i dont recommend cleaning the air filter every week, check the bolts every week nothing else.
October 3, 200620 yr Author cool thanks it has raptor hangers on it,needs carb mod doing tho went out on moor for 10mintues behind my house come home for a drink went out and there was more petrol on the floor than in the tank
October 3, 200620 yr Well worth getting the carb mod done mate, saves knocking the tap off and on everytime you stop. Eddy, have you ever tried the Raptor pegs? just about indestructable, dont fill with mud like the standard ones and seem to provide better stance and balance on the bike. Expensive but worth the money I recon
October 3, 200620 yr ANY pegs are better than those squishy bits of old bean tin that rust at the first sign of moisture that Beta put on there at the factory. As rev3 says, the standard switchgear sucks too. The kill button on my 06 worked ONCE from new (no joke). Bin it and stick a 2-wire YZ-type one on there. I clean the airfilter and carb after every ride as well as removing the flywheel cover and mopping out any moisture. Probably unnecessary but it makes me feel better (and the pilot jet seems to clog much quicker on this bike than any other Beta I've owned - no idea why).
October 3, 200620 yr Good points Neon, most of us clean the carb every ride, do notice them not quite running as they should if they arnt. Flywheel cover a must, usually loads of water or moisture in there. Eddy, why dont you recommend cleaning the filter regualry? if its dirty it needs cleaning, effects the fuel air mix quite abit if its full of *****
October 3, 200620 yr Author my killswitch is same stopped it 2day and it wouldn't start thought i had killed it all ready then i remberd that my mates did the same so a pulled it out with some grips and she started first kick
October 3, 200620 yr Very important to check when riding that both wheels have been off the ground at lest 3 times. If not very important you find a nice kick or hop some where. Nice. I do very much of the above posts but i know this is way over the top but i have to take off the throttle clean it, re-oil it and stick it back on after every ride. It is all most an addiction. Enjoy.
October 3, 200620 yr Ralph, Cant beleive I missed the most important thing with the Rev3, 3-20 hops on the back wheel and lots of nice flicks and kicks, bloody thing will fall apart tomorrow. Throttle! yer every ride give it a clean, makes a hell of a difference, few drops of oil down the cable as well. Sad day tomorrow, only me and Dad out, may not play at Ralphs corner out of respect Edited October 3, 200620 yr by Betarev3
October 3, 200620 yr Author why is it important that i lift there wheels?going out for a play on it tomorow see what shes like in sections thanks for all the help
October 3, 200620 yr why is it important that i lift there wheels? Sorry 07Betarev3 It is just me.I have just got to grips with Flick turns and Hoping on the back wheel so i can not go 10 yards without doing one or the other. It is why i go out at the moment not to clean a section but to do a flick or a hop. Edited October 3, 200620 yr by Ralph
October 3, 200620 yr 10 yards????? more like 10 feet, hes like a kangeroo on methamphetamine up here most of the time, that shockers been up and down more times than the piston. Edited October 3, 200620 yr by Betarev3
