4rt Tyre Pressures
i have had a case today of my back tyre coming off the rim, thoutht
it was a puncture but after taking the tyre off cleaning everything and
refitting it i cant find owt wrong with it, just wondered if i am running it
a bit on the low side 4.5psi.
jsp
FF its got a michelin on and its tubeless
You can run them at 2 or 3 psi without problems - they'll generally stay on the rim even when punctured.
Unless there is something wrong with your particular tyre you must have just been unlucky as there is nothing else I can think of that would cause it to come off the rim, unless maybe it was never seated properly in the first place
how offten do you check your pressure
if it had crept down yot may not have noticed
i run 4 psi back 7 psi front but check regularly
Take off the chain and spin the back wheel to make sure it is true and you havent got any dings in the rim. Maybe you caught it on something and didnt realise.
