4rt Doesn
Thanks for the info just ordered a hotter plug to try in mine. As I'm no stranger to being an idiot at times what does a hotter plug do differently and would you need to change back to the cooler plug when the weather warms up? :banana2:
  • Replies 36
  • Views 10.9k
mine starts fine thanks, and if it didnt i woulnt ask you ,obviously
Dictionaries define 'Guru' as:
"A Spiritual Parent, a Teacher, a Guide, a Leader in some field,
a Knowledge wizard, a Resource for others, and a Source of all good."
13 post are they all sarcastic ????????
Prehaps you should think about changing you name!!!!!!
a Knowledge wizard, a Resource for others.
both sound good ! but ill stick with guru,but dont judge too soon
regards
A previously banned user re-registered under another name? Big Brother is watching and knows lots more than you do...
