January 19, 200719 yr My rev 3 kickstart has stopped returning to the top position after kicking up. is this a problem with a return spring ? cheers Leggins
January 19, 200719 yr this is of no use to you but my sherco kick start has started this. The little screw on the beta one, take it out and see if you can separate the two bits. if not i used to put 3 in one oil in there and wiggle Then fill with grease and replace screw
January 20, 200719 yr Leggins, chances are your kick start return problem is due to a bad gasket and or over tightened bolts on the primary cover. (clutch cover) I`ve never seen a bad return spring on a Beta.
January 20, 200719 yr leggins,moved this in here, hopefully you might get more answers. Cheers Not if you lock the topic he won't Unlocked and seperate topic merged with this one - I think!
January 21, 200719 yr Author Leggins, chances are your kick start return problem is due to a bad gasket and or over tightened bolts on the primary cover. (clutch cover) I`ve never seen a bad return spring on a Beta. Come to think of it I did tighten the bolts on the primary cover as one had worked loose. thanks lineaway Ill give that a try cheers Leggins
January 27, 200719 yr Author Leggins, chances are your kick start return problem is due to a bad gasket and or over tightened bolts on the primary cover. (clutch cover) I`ve never seen a bad return spring on a Beta. Come to think of it I did tighten the bolts on the primary cover as one had worked loose. thanks lineaway Ill give that a try cheers Leggins worked a treat kickstart back to normal working order.... thanks again
