shaun Posted April 28, 2007 Share Posted April 28, 2007 what is the best coolant to use in my 2003 rev 3 Quote Link to comment Share on other sites More sharing options...
tilertrialler Posted April 28, 2007 Share Posted April 28, 2007 water Quote Link to comment Share on other sites More sharing options...
fantic156 Posted April 28, 2007 Share Posted April 28, 2007 Distilled Water mixed with antifreeze. Just water can corrode the case around the water pump. There is a topic on this in the Beta forum that's worth a look. Quote Link to comment Share on other sites More sharing options...
gwrev3 Posted April 28, 2007 Share Posted April 28, 2007 Like fantic 156 says, use antifreeze and distilled water mixed. I had an '03 Rev 3 that managed to corode thro' the outer clutch housing. At the time, I went on to use the pink organic anti-freeze mixed 50/50 with distilled water. Always read what it says on the instructions though. Quote Link to comment Share on other sites More sharing options...
piercemcneal Posted April 30, 2007 Share Posted April 30, 2007 what is the best coolant to use in my 2003 rev 3 is this for all beta rev 3s or just the 03? i have a 2001 and i use the recomended coolant for it but would distilled water and antifreeze be better? Quote Link to comment Share on other sites More sharing options...
fantic156 Posted April 30, 2007 Share Posted April 30, 2007 I've used distilled water for years don't know who told me to or why, it's been to long. When ordering some parts off the British importers of Beta recently I checked with them about using distilled water and they confirmed distilled water mixed with anti-freeze is best. The worst thing to use is neat antifreeze as it doesn't dissipate the heat very well and I'm sure they said avoid using just water. Quote Link to comment Share on other sites More sharing options...
shercrazy Posted May 1, 2007 Share Posted May 1, 2007 maxima coolanol straight up, no water, works like a charm!......................john Quote Link to comment Share on other sites More sharing options...
subanator Posted May 2, 2007 Share Posted May 2, 2007 (edited) Hmmm.......I see distilled water, antifreeze mentioned but not Antiboil. This is the usual mix for pre-mixed off the shelf brands coolants. They are usually glycol based organic based. Then there is the synthetic versions. I tried both versions, and still rotted 2x magnesium casings. The problem with electolysis is not a simple one. The paint layer on a new casing does protect it long enough until a pinhole lets in the coolant to start erroding away the magnesium. I believe its not the coolant where the problem is, but happens with other bikes with magnesium covers/casings for water cooling systems. Its either the composition of the metal and needs a sacrificial anode or something to counter it. All twin pipe Rev3 models will be affected, for '03 onwards, the earlier '02 was twin pipe also but had the heavier aluminium casing. This is one alternative. The other alternative is to epoxy coat the inside of the waterpump housing. I will be doing this with a metal paste epoxy shortly. Other owners have used different products. Sure pure demineralised water is very low in conductivity and should slow the electrolysis, but once contaminated will be of no futher use. Unless you can flush the radiator and barrel with this as well, its cheap to replace regularly. It just needs the other goodies in it to make it worth while (antifreeze/antiboil). EDIT- did some googling and found out that zinc, aluminium and magnesium are the best sacrificial anodes. What is more sacrifical than magnesium alloy?????? Havent found that answer yet. Good explanation of this I found is : If two different metals are physically or electrically connected and immersed in electrolyte then some amount of current flows between the two metals. This current is supplied by one of the metals by emmiting metal ions to the conductive environment . This is known as galvanic corrosion which destroys base metals rapidly.Magnesium (Mg) alloy anodes are having greater driving potential than zinc (Zn) or aluminium (Al). So that magnesium anodes are suitable for the protection of pipeline, tanks, condensers, water boxes, heatexchangers, ship hulls, boilers and marine structures from corrosion. Edited May 2, 2007 by subanator Quote Link to comment Share on other sites More sharing options...
