beta rev 3 Posted May 28, 2007 Share Posted May 28, 2007 Hi, now i've heard that rev 3's are prone for letting water into the flywheel casing,causing stator problems, now i've had my stator fixed (motoplat) plug hehe,,, . How do you stop water getting into flywheel casing., i've tried silicon sealer ect but when i remove flywheel cover there is always water in there.My mate has a 04 270 gas gas and has never had this problem. Please help me sort this problem once and for all. Quote Link to comment Share on other sites More sharing options...
kinell Posted May 28, 2007 Share Posted May 28, 2007 Forget the silicone, whip the cover off and snip a small "V" shape out of the bottom edge with a pair of side cut snips. If (when) the water gets in, it gets out too - simple... Quote Link to comment Share on other sites More sharing options...
eddie_lejeune Posted May 28, 2007 Share Posted May 28, 2007 seal it up and leave it on. Quote Link to comment Share on other sites More sharing options...
kinell Posted May 28, 2007 Share Posted May 28, 2007 seal it up and leave it on. How do you know it's sealed 100%, do you open it up and check or leave it and hope for the best? Quote Link to comment Share on other sites More sharing options...
mad4it Posted May 29, 2007 Share Posted May 29, 2007 You are very unlikely to seal it up completely to make it stay totaly watertight as said put holes in it this is what mine is like, remove it now and then to spray in some corrosion inhibitor .It will stay dry and rust free believe it or not you will not suffer any problems in corrosion terms! Quote Link to comment Share on other sites More sharing options...
eddie_lejeune Posted May 30, 2007 Share Posted May 30, 2007 This is our 11th year with betas, (up until recently is was 2 new ones each year) and ours were sealed up and left on, it wasnt silicone seal, i will get the name of it and post it here just in case anyone wants to go down that route anyway. Quote Link to comment Share on other sites More sharing options...
beta rev 3 Posted May 30, 2007 Author Share Posted May 30, 2007 Nice one, would appriecate that Eddie. Regards Phil... Quote Link to comment Share on other sites More sharing options...
fastandy Posted May 31, 2007 Share Posted May 31, 2007 if you get any of the bonding adhesives that are used when your joining crankcases,they should seal her up! Quote Link to comment Share on other sites More sharing options...
jetset Posted June 1, 2007 Share Posted June 1, 2007 If you don't want to cut a "V" in the casing just drill a small hole at the bottom and that will let the water out. Quote Link to comment Share on other sites More sharing options...
