August 11, 200719 yr Ok so I was reading the owners manual for my 9.9 yamaha outboard and they suggested using Yamaha Brand Ring Free. Apparently i cleans up the ring grooves of 2 strokes very nicely. 2 strokes as most of you know carbon up pretty easily and since they run at low speeds in the ring groove. Have any of you in the trials world used anything like this? It seems to shock the system but is their a price fo using outside of a marine enviroment? Hmmmm http://www.pws9.com/Merchant2/merchant.mvc...ACC-RNGFR-12-00 And its expensive too.... But if its less evasive then pulling off a jug and giving it a new set of rings it might be a thought. Thanks in advance. --Biff
August 11, 200719 yr Author wow my gramar stinks today.... I need to proof read more! hahaha Thanks --Biff
August 12, 200719 yr Hi Biff, I've never heard of the "Ring Free" stuff before. No doubt it may well work, but then usually an outboard motor is revved/worked pretty hard and may respond better to this additive than a trials motor. In my experience, I never really had any ring sticking/gumming up problems except for the older Villiers motors that were old and worn out anyway and used next to no good 2 stroke oil from the garage. (Times were hard then) For all my 2 strokes, I run 50:1 fuel/oil with Pennzoil mineral 2T outboard oil, always runs fine, smokes a little and doesn't gum anything up. Yeah, I agree, bit of a grammar slip! Bye, PeterB.
August 12, 200719 yr Ring free works in two cycle and four cycle engines. It will also clean out the exhaust. Be aware the exhaust will get VERY HOT while the carbon is burning out. This product was developed by Chevron, I believe their name is Techrilene. I would not use more than 1/2 an ounce per gallon in a trials bike. 2 ounces is what is recomended for treatment. I know of street bike exhausts that have burned out internal baffles at that mixture. So..... aluminum muffler with supply of oil in fiberglas packing.......cherynoble! It works really well. But be careful what you wish for! Edited August 15, 200719 yr by paul_thistle
August 14, 200719 yr Author Thanks guys, At least I am warned before melting down the ole middle muffler on the gasgas. I think we will try this come october when the bike will be unused for a short while. --Biff
August 15, 200719 yr Hmm. I once made the mistake of using lawnmower 2S (it was all they had) in my enduro bike. After 10 minutes I packed up and went home because it was pinking so much. Moral of story: buy good quality 2S oil.
