Free Rider
rockdan
  • 3 weeks later...
Agreed, Very addictive, half an hour later im still playing.
-4c,-b,-40,-1u -40,-1u,-34,-2j -4c,l,-4c,-b -40,1s,-4c,l -30,3k,-3j,2m -3j,2m,-40,1s -24,-34,-18,-38 -34,-2j,-24,-34 -1k,1k,-1q,1c 1n,1h,-1k,1k -l,51,-1m,4g -1m,4g,-30,3k -1b,-3b,-1i,-37 -1a,-37,4c,-3h s,5b,-l,51 1g,1j,4m,12 6v,4g,s,5b 4d,14,5l,7 5l,7,6h,-f 6h,-f,7p,-1a 86,-1q,7o,-1a ea,4o,6v,4g 85,-1q,a2,-38 a1,-37,c7,-o a0,-37,c4,-4c c2,-4b,cq,-4i c7,-o,eq,1s cq,-4i,db,-4i db,-4i,du,-4f du,-4f,eb,-44 eb,-44,en,-3j en,-3j,f5,-2r f5,-2r,g2,-1e eq,1s,gt,3j pv,a1,ea,4o g2,-1e,go,-p go,-p,i4,k gt,3j,je,55 i4,k,hl,19 hl,19,je,30 je,30,ko,3p je,55,lo,5v ko,3p,m4,46 lo,5v,po,7b m4,46,p8,4o p8,4o,s7,4u po,7b,sq,7s 11c,be,pv,a1 s7,4u,uh,4p sq,7s,va,6s uh,4p,v8,47 10p,4p,1a2,4p va,6s,10p,4p 1ae,gv,11c,be 1a0,4q,1b3,54 1b3,54,1c6,5n 1b0,h7,1ae,gv 1bq,hi,1b0,h7 1c6,5n,1d0,6g 1d0,6g,1dr,7f 1fv,ht,1cf,hq 1cf,hq,1bq,hi 1dr,7f,1eg,7p 1eg,7p,1fp,7v 1fp,7v,1h6,81 1h0,gg,1fv,ht 1h6,81,1h7,93 1h7,93,1ju,95 1ia,gu,1hq,gt 1hq,gt,1h0,gg 1k2,ge,1j3,gq 1j3,gq,1ia,gu 1ju,95,1lu,95 1l9,g1,1kp,g4 1kp,g4,1k2,ge 1lu,95,1n0,8t 1ls,94,1sj,7g 1mm,fm,1m7,fo 1m7,fo,1lr,fp 1lr,fp,1l9,g1 1n0,8t,1o0,8m 1o0,8m,1oo,8u 1oh,g0,1nq,fo 1nq,fo,1n8,fm 1n8,fm,1mm,fm 1oo,8u,1pp,8l 1pn,8k,1qm,8r 1qb,g7,1pj,g7 1pj,g7,1oh,g0 1qm,8r,1rm,8m 1so,g4,1r0,g7 1r0,g7,1qb,g7 1sj,7g,21m,94 1st,91,1te,8j 1rm,8m,1sl,88 1sl,88,1st,8v 1tg,g2,1so,g4 1te,8j,1uj,8t 1un,fa,1u8,fm 1u8,fm,1tg,g2 1uj,8t,1v8,8j 1v8,8j,207,90 20b,8u,1vv,90 20b,cs,1vu,dg 1vu,dg,1vi,e9 1vi,e9,1v8,eo 1v8,eo,1un,fa 21g,95,23q,92 208,8v,21e,95 222,bi,21i,bs 21i,bs,212,c9 212,c9,20n,cj 20n,cj,20b,cs 23h,b1,22t,b5 23e,b0,22e,bc 22e,bc,222,bi 23r,92,24k,8u 23k,93,242,91 24n,8u,253,8q 24i,8u,257,8o 23i,b1,264,au 23f,b0,23p,b0 257,8o,26c,8f 264,au,271,at 28r,6u,277,89 26c,8f,27i,87 27h,85,2bh,7c 271,at,27m,an 27m,an,285,af 28o,72,29t,7m 285,af,28k,a2 28k,a2,294,9l 295,9j,2ef,9b 2bu,6g,2c9,60 2c9,60,2cg,5n 2cf,5n,2ib,5m 2bg,7d,2bp,6s 2bl,6v,2c0,6b 2mt,98,2ed,9b 2i9,5m,2jo,5l 2jm,5l,2mm,5k 2mm,5k,2uv,5g 2ri,99,2mt,98 2sr,a8,2ri,99 2vq,df,2sq,a9 2uv,5g,365,5h 2vl,9l,2tt,8s 34d,aa,2vl,9l 33s,dt,2vq,df 37n,aj,33s,dt 365,5h,3ci,63 3e1,bs,37n,aj 37t,ak,37d,ab 3ci,63,3kn,60 3kh,b6,3e1,bs 3ko,5t,3lr,5a 3kr,5s,3kg,60 3uu,65,3kh,b6 3rh,5s,3r4,67 3re,5u,3ru,7c 3th,5s,3rh,5u 3rh,5t,3tn,6o 3ri,5s,3t8,6t 3ri,5u,3sq,74 3rh,5v,3sc,79 3tc,5t,4a4,5t 3ur,66,3v9,5s 48p,-8u,47l,-7n 487,-8c,4cg,-5e 4bt,-8j,48d,-5b 485,-5l,497,-52 49v,5t,4b3,5j 4b6,-8u,4cq,-7m 4cp,-6a,4bl,-51 4c3,4o,4db,33 4b3,5j,4c3,4o 4e2,-6u,4gc,-6s 4db,33,4ht,-1f 4f7,-6p,4f3,-58 4gv,-6r,4gr,-50 4gr,-50,4ii,-5d 4ii,-5d,4ig,-6v 4ht,-1f,4kt,-1e 4j6,-73,4j6,-55 4jd,-6p,4k6,-6d 4k6,-6d,4j5,-60 4j5,-60,4ks,-5j 4l5,-5e,4lb,-79 4lb,-79,4mm,-5e 4kt,-1e,4l1,-4o 4mm,-5e,4n0,-6v #-p,-2u 1j,-33 a0,48 eq,-59 j4,s 10a,36 11m,37 1f4,fp 1ic,7s 1ub,e9 1uq,73 1vg,cq 20g,bj 26h,85 2h9,4s 316,92 35q,4m 3p2,44 4hg,-1o
Copy and paste that into the dialog box when you click open.
Post yours......
Conor
Guest DGShannon
I have avoided this game, until last night. Totally sucked in. As much with creating a course, as with riding it. Anyway, here is what I put together.
-1tm,1b,-1tm,-q -1tm,24,-1tm,1b -1t0,3d,-1tb,33 -1tb,33,-1tj,2l -1tj,2l,-1tm,24 -1sf,3i,-1t0,3d -1kj,47,-1sg,3i -1s8,43,-1p4,4c -1p4,4c,-1pj,3v -1p5,4b,-1pl,4j -1km,47,-1k3,46 -1k3,46,-1jc,40 -1jc,40,-1il,3l -1il,3l,-1hv,36 -1hv,36,-1gi,21 -1gi,21,-1fs,37 -1ft,36,-1fd,3q -1fd,3q,-1er,4b -1d9,1h,-1de,1p -1de,1p,-1df,20 -1df,20,-1db,28 -1db,28,-1d3,2d -1er,4b,-1e4,4t -1e4,4t,-1df,5a -1df,5a,-1ck,5o -1d8,1h,-18q,-11 -1d3,2d,-1cg,2l -1cg,2l,-1b4,3b -1ck,5o,-1bl,66 -1b4,3b,-1ac,3h -1ac,3h,-19j,3l -1bl,66,-1a6,6n -1a7,6n,-19g,6q -18q,-11,-182,-19 -19j,3l,-18q,3k -18q,3k,-12u,39 -19g,6q,-18n,6r -18n,6r,-137,75 -182,-19,-17i,-1b -17i,-1b,-16p,j -16p,i,-16j,12 -16j,12,-166,1n -166,1n,-15m,26 -15m,26,-153,2j -13p,9,-143,b -143,b,-14b,h -14b,h,-14e,o -14e,o,-148,t -148,t,-13n,10 -153,2j,-14h,2t -14h,2t,-140,32 -140,32,-13c,37 -13o,a,-11k,n -13n,10,-vc,p -12r,39,-12d,39 -12d,39,-11s,39 -13c,37,-12s,39 -11q,7f,-12l,78 -12l,78,-13b,74 -11k,n,-vf,q -11u,38,-tq,38 -111,7t,-11q,7f -10k,8a,-111,7t -vf,q,-ti,j -v9,9j,-vn,9a -vn,9a,-105,8s -105,8s,-10k,88 -ur,9o,-v9,9j -tq,38,-tc,2p -qn,9q,-ud,9q -ud,9q,-ur,9o -ti,k,-pg,-10 -tc,2p,-t1,35 -t2,34,-sh,3l -sh,3l,-rq,3q -rq,3q,-r9,3q -r9,3q,-qr,3n -qr,3n,-qe,3d -q1,9p,-qn,9q -pg,-10,-oo,-1i -q9,36,-pl,2h -pl,2h,-oe,31 -qe,3d,-q8,35 -ot,9f,-pe,9l -pe,9l,-q1,9p -oo,-1i,-oo,-n -nf,-22,-nb,-29 -oo,-n,-mf,-o -oe,31,-l4,3e -og,98,-ot,9f -oh,99,-ns,ah -ns,ah,-nl,ao -nl,ao,-nc,av -na,-1b,-nd,-1n -nd,-1n,-ne,-22 -nb,-29,-n3,-2g -n3,-2g,-mr,-2n -mr,-2n,-mg,-2p -mg,-2p,-md,-2u -md,-2u,-m6,-30 -mf,-o,-ms,-t -ms,-t,-n3,-13 -n3,-13,-na,-1b -lq,-v,-lt,-n -lt,-n,-m7,-k -m7,-k,-mh,-p -nc,av,-ms,b5 -ms,b5,-m8,b8 -m8,b8,-li,b8 -li,-2v,-l9,-34 -l9,-34,-kv,-2t -m1,-2t,-lp,-2t -lp,-2t,-lh,-2u -m7,-30,-lq,-2u -lq,-2u,-li,-2v -kv,-2t,-k7,-2m -js,-12,-ke,-q -ke,-q,-kv,-v -kv,-v,-lb,-r -lb,-r,-lk,-10 -lk,-10,-lq,-v -mh,-p,-k9,-n -l4,3e,-ka,3k -li,b8,-ld,bi -ld,bi,-ke,bh -ke,bh,-k7,ar -k7,-2m,-ju,-2f -ju,-2f,-jo,-24 -jo,-24,-jk,-1n -jk,-1n,-jl,-1c -jl,-1c,-js,-12 -k9,-n,-jm,-c -jm,-c,-j0,8 -j0,8,-i9,18 -ka,3k,-jq,3q -jq,3q,-jf,41 -jf,41,-j3,4c -j3,4c,-ij,4t -k7,ar,-jm,at -jm,at,-ja,at -ja,at,-j1,ar -j1,ar,-il,al -i9,18,-hp,1m -hp,1m,-h9,1t -h9,1t,-gl,23 -gu,99,-hh,8p -hi,8p,-hp,9q -il,al,-ia,ab -ia,ab,-ho,9o -gl,23,-g0,26 -g0,26,-fe,24 -g9,9k,-gu,99 -fi,9q,-g9,9k -ea,1i,-du,13 -fe,24,-eq,1u -eq,1u,-ea,1i -e2,a0,-ep,9u -ep,9u,-fi,9q -da,0,-cq,-h -cq,-h,-c3,-t -du,13,-dj,f -dj,f,-da,0 -5d,94,-da,a0 -da,a0,-e2,a0 -c3,-t,-ba,-13 -ba,-13,-ba,-e -ba,-e,-ai,-f -ai,-f,-ai,2 -ai,2,-9r,2 -9r,2,-9r,d -9r,d,-6e,e -6g,e,-4o,d -5m,5b,-6i,5j -6i,5j,-7d,5o -4o,d,-4a,9 -4g,4i,-4u,4t -4u,4t,-5m,5b -4b,96,-5d,96 -3v,2,-3i,-7 -3i,-7,-35,-c -35,-c,-2p,-f -4a,9,-3v,2 -32,2b,-3j,2s -3i,2q,-3s,3a -3s,3a,-45,40 -45,40,-4g,4i -35,8v,-35,95 -35,95,-4b,95 -2p,-f,-2u,-k -2u,-k,-31,-d -1h,1h,-20,1l -20,1l,-2f,1t -2f,1t,-32,2b -1c,8l,-26,8l -26,8l,-26,8v -26,8v,-35,8v -1i,1i,1i,1i 7,7v,-h,80 -h,80,-h,8c -h,8c,-1c,8c -1c,8c,-1c,8l 2s,7j,6,7j 7,7j,7,7v 1i,1i,5g,1g 3s,7j,2s,7j 5a,6t,4i,7d 4i,7d,49,7h 49,7h,3s,7j 5g,1g,71,36 6a,7l,5a,6t 71,36,97,3t 6l,8n,6a,7l 7g,9f,76,8u 76,8u,6l,8n 7r,9s,7g,9f 96,3t,9h,42 9g,78,90,74 90,74,8j,6s 8j,6s,8b,6i a7,a9,8r,a9 8r,a9,89,a4 89,a4,7r,9s a1,45,9j,46 a1,45,dt,19 9h,42,9l,45 9h,78,a4,77 a4,77,ak,72 ak,72,b6,6n dg,9d,a7,a9 b6,6n,bp,67 bp,67,c6,64 c6,64,ch,68 dt,19,dt,s dt,s,gl,s ch,68,cq,6g h4,7i,dg,9e gk,q,mb,2l gl,m,go,q gk,r,gk,m go,o,gs,t hj,68,h5,5u h5,5u,gn,5e gn,5e,gc,4r gb,4r,h3,7g i2,6e,hj,68 i1,6d,ie,6g ie,6g,iq,6h je,6d,jt,63 jt,63,kc,5k iq,6h,j5,6h j5,6h,je,6d l7,4m,ld,4k ld,4k,lk,4k lk,4k,lv,4m kc,5k,km,55 km,55,kt,4t kt,4t,l4,4n pk,4o,lv,4m pk,1k,pk,4o #-1j3,-39 -11j,3v -rm,3f -lr,-3q -kq,71 -kv,b6 -ig,3q -72,-7 -57,4k a5,12 9m,6c 9g,90 c6,5c au,5r cc,8c b0,8l eq,32 h2,-f k7,3q m7,24
By the way, if you click the little cube icon (2nd from bottom) the track becomes 3D, and look much nicer.
See what you think.
Edited by DGShannon
Guest DGShannon
OK, now it is worse! Free Rider 2 (a MUCH enhanced version) is now online.
Link: http://www.onemorelevel.com/games.php?game=622
FreeRider 2 Track:
-18 1i 18 1i 2d 1n 3c 24 47 2o 9f 94 a2 9j au a2 bu ac d1 ah ea ah fc a8 gf 9m hd 8r i6 7n,ka 6k l3 6n lg 6u lt 7d m7 7v me 8h mj 95 mq 9p ne b8 o5 ck p4 du q8 ep rc fe,re ff s7 fu t8 gb uf gk vv gn 11e gl 12m gf 148 g0 183 e0 183 ga,i5 7n il 6c kc 6k,1h2 g9 1qk ga,1qj g9 1ug j0 20m k9 23l lg,3q2 ii 3qo i1 3s4 i1 3ss hf 423 hf,364 ns 385 nu 39s nr 3bc ne 3ch mt 3d9 mf 3eb ln,1af ga 1do k3 1e9 ki 1eu ks 1fm l5 1ge lc 1h5 lg 1ht li 1j9 li,183 g9 1ag ga,1h2 gb 1ga gv,1ja li 1p2 li 1ph lm 1ps lr 1q4 m2 1qc mc 1r3 nm,28s r7 29r ra 2gv rb 2hd rd 2hl rh 2hq rm 2i3 rs 2id ru 2il ru 2it rs 2j1 rn 2j7 re 2jd rb 2jl ra 2js rb 2k0 re 2k5 rk 2k7 rn 2ka rt 2kf ru 2ko s0 2l0 rt 2l7 rm 2lb rf 2lg rb 2lp r8 2m1 r8 2ma ra 2mi rd 2q7 re 2sv re 2t9 rg 2ti rk 2tp rq 2tv s5 2u6 sf 2uj sr 2vc t8 304 tg,3q2 ih 3oq ih 3j9 oh,3j8 oh 3fi rr 3eb sj 3ci t8 3ap tq 38f u6 36h u9 34k u6 324 ts 303 tg,4bq d7 4bq cj 4bl bq 4bc bb 4as av,4bq d7 4bm dp 4bg ea 4b3 eu 4ad fl 49i g7 48i gm 478 h4,462 ha 444 hf 421 hf,462 ha 477 h4,1r2 nm 1rs p4 1sa pl 1ss q1 1tl qd 1uk ql 1vs qq 28u r7,-19 1i -1n 1k -22 1r -2g 2a -2t 2u -39 3o -3h 4l -3m 5k -3u 6i -48 78,23k lg 24n lr 266 m6 27r mc 29c md 2b6 m8 2cj lr 2dc lc 2e6 kl 2f4 jm 2fn io 2fn mq 2g9 mr 2gk jg 2gm mq,2ri id 2rr iu 2s3 jd 2se js,2rh id 2rh n3 2g9 mr,2sc jr 2t4 ko 2u5 ln 2vb mg 30s n7 32i nn 344 nt 366 ns,2hf mr 2hp jf 2hs mr,2iq mr 2j2 jc 2j4 mr,2ju ms 2k7 jk 2k9 mt,2l4 mt 2lg j9 2li mt,2m9 mt 2mm iu 2mr mt,2nk n1 2nk im 2o1 mv,2od mt 2on ig 2oo n1,2pc n0 2pj ji 2pl mv,2q9 mv 2qd im 2qk n2,3p4 ig 3pf i3 3pn if,3r6 i0 3rg hi 3ro hu 3rr i1,3eb lm 3f1 l0,-47 79 -5b a1 -5q bv -6l dm -71 fb -8u k6,-cr p6 -fi r4 -i9 s5 -l9 sk,-v9 r0 -11p p9 -13b n8 -14d kq -15e gc,-15f gd -152 cu -13m a1 -11s 7m,-vb qv -s7 s2,-l9 sm -os sm -s7 s2,-8a il -al lt b ls h p5,-ct p5 -5l p6 i p6#-6v pj -5n pj,-6a pk -6b qc,-59 pj -59 qa,-4g pi -4g q9,-57 pu -4h pt,-3p pi -3o q8 -30 q7,-3n pt -3f pt,-3p pj -32 pi,-6v qu -71 rs -64 rr,-6v qu -63 qt,-6v rb -6f rb,-5c qr -5c rp,-5a qr -4i rn,-4j qq -4j rk,-3n qn -3n rm,-3t qn -35 ql -2r r0 -2r ra -31 rk -3r rm,-1s 2g -18 2g,-1s 2g -1s 34 -18 34 -18 3o -1s 3o,-u 2g -a 2g,-k 2g -k 3e -k 3o,0 2g 0 3o,0 2g k 2g k 3o,0 34 k 34,u 2g u 3o,u 2g 1i 2g 1i 34 u 34,18 34 1i 3o,1s 2g 2g 2g,26 2g 26 3o,-1s 4m 34 4m 2g 50,34 4m 2g 4c,3ou jm 3lg no 3m4 no,3lg no 3lg mq,3p8 jm 3q6 jm 3q6 ku 3p8 ku,3pi jm 3pi ku,3qg jm 3qg ku 3r4 ku 3r4 jm 3qg jm,3re jm 3ro ku 3s2 ka 3sc ku 3sm jm,3t0 jm 3t0 ku,3t0 jm 3tk ku 3tk jm,3ok li 3ok n4,3ok mg 3p8 mg 3p8 n4,3p8 mg 3p8 li,3ps li 3ps mq 3ps n4 3qg n4,3ps li 3qg li,3ps mg 3qg mg,3r4 li 3r4 n4,3r4 li 3s2 li 3s2 mg 3r4 mg,3re mg 3ro n4,3sc li 3sc n4 3t0 n4,3sc li 3t0 li,3sc mg 3t0 mg,2qu ne 2rs ne 2rs mq,2ri no 2s6 no 2s6 n4,1qc ie 1q6 i5 1pt hv 1pk hu 1p9 i2 1p1 ia 1os io 1ou j3 1p5 jg 1ph jo 1ps js,1qc ie 1pr i9,1qc id 1qd ht,-8e 25 -8e 3i,-73 49 -80 6u -85 61,-80 6r -7c 6a,-8e 26 -7q 26,-8e 2q -84 2q,-8e 3e -7q 3e,-76 26 -76 3e,-76 26 -6i 3e -6i 26,-5u 26 -50 26 -50 3e -5u 3e,-5k 26 -5k 3e#T -l ol,T -l4 7a,T -ns 5c,T -rd 4p,T -v0 5u,T -11f 7u,S 2ml qs,T 18o fj,T 3no iv,T 4a0 b1,T 2lv c6,T 1sp gq,T 1pa gr,T kp -1e
Guarantee it will take you awhile to beat this one!
  • 2 weeks later...
  • 3 weeks later...
Not a Trials course - more a downhill MTB track but good for you adrenaline junkies!
-18 1i 18 1i,17 1i 1k 1i 1t 1m 26 1r,27 1t 2b 1v 2f 24 2i 2a 2p 2j 31 2o 3b 31 3o 3a 45 3n 4h 41,5p 55 67 5m 6p 69 76 6q 7r 7f 8c 85 8j 8e 8s 8n 98 92 9h 99 ac a6 ag af ak ao b4 ar b7 b6 b7 bf bf bm bk c5 bk ch,9g 99 9u 9i ab 9p,an 9t b4 a2 b9 a4 bd a4 bg a4,a0 9n ae 9u,b7 a7 bf a7 bg a4,a9 9n ap 9u,ac 9u b6 a6 b0 ap,b2 a6 at ao,ai a2 ae a9,ag a0 ab a9,ak a2 at ai,ag a4 at am,at a4 an a7,ak a9 ag ab,au a6 an a9,al ab ae ad,bi ch br d3,bt d3 c8 de ck e4,cm e4 d1 ee e5 ff el fq,en fq f9 ga fk ha fk hl ft hu gr il hc j9 ig kb j7 l1,j7 kt jn le ko ls ld m3 lj mc ls mc m6 mn,m8 mn mj ml,ml ml mo mp mu mp n3 mp n9 n0,na n2 ng n2,np n2 np n5 nl n4,nj n2 np n2 ns n2 nu n7 o4 n9,m3 me mf mn,m6 mi lq ma,lo ma lo m7,lk m5 lh ma,lh me ld mc,ld m9 lk m9 ls ma m6 mg,ma mg n0 ms,n3 mr mj mg m6 mi,m3 mc mj mg,mn mg n0 ml,n5 mn nc mp ne mu,ne n0 n7 n0,n1 mn nc mn nl mp nr mu,ns n0 o4 n9,o7 n9 og n9 p4 nn,4h 40 5p 54,p2 nj pk o3 q6 oj qr p9 ra pp s1 qm sh r4,m6 m8 mq mr,mf m9 mv mk,mi m9 m0 m2 ln m8,lm m6 li m2,li m0 m2 md,m8 md mo md n8 mi,n8 mk nf mt nq mo oa n3,o8 n4 o1 n4,nv mv o1 n8,oa n6 oc n3 nc mf na mk,n4 mf mt m8,mq m4 mf m0,m6 m4 mb m9,mi m9 mf m2,mb m0 m0 m0,m0 lv mb m4,mq m2 nh md mv mh,n8 m2 nl m6 nh mo,n8 md n3 m2,n4 m4 nm m9 n4 lv,n4 lt n6 m6,na m8 nl m8,nm m6 nu mk nv mh,nu mf nv mr,nv mt o3 n3 oa mo,o1 mm nq mf nu mf,nv mf o7 mr,se r1 te rg u2 rs uk s7 vb sl 108 t0,10a t0 11a t7 120 t7,122 t7 12k t6,12n t6 137 t4,139 t4 13r t2,13t t2 14d st,14h st 14v sn,15a sk 16g s0,14t sk 15a sl 148 su,14a su 14t sl,16i ru 17g r7,17m 139 14u 152 13f 15o,13e 15o 124 15v,112 16a 10r 16n 10r 170 10k 17c,10i 17c 10c 17g 107 17u 103 182,100 182 vs 189,vs 18b vs 18g,vs 18e v6 192 uh 19b ui 1a4 u0 1ai,tv 1ai tm 1ak ti 1am,ti 1ap tg 1b4,te 1b4 ss 1ba,sn 1ba sg 1bj rh 1cc qd 1d5 pb 1du o0 1en mc 1fh lk 1fr,lh 1ft kn 1gh k5 1h1,k2 1h5 j9 1hs ic 1ik i3 1il hm 1ik gi 1ig fn 1ir,fl 1in ec 1j4,fi 1il gi 1ie,fl 1il du 1j7 dh 1j7,dd 1j7 ct 1ji,d4 1j9 ct 1j9 c6 1jg ct 1ji,d1 1jf d4 1jb,d3 1j9 cb 1j9,c8 1jb bi 1ji,be 1ji br 1jo,c9 1jo ct 1jk,cv 1ji bg 1jo,bb 1jp bi 1k2,c8 1jg c0 1jg,bm 1jg b9 1jv be 1jp,ap 1jb a9 1kd,b9 1ji bk 1jd,b0 1jf bg 1jb,c2 1j4 cr 1j4 bv 1jb,b2 1j4 as 1j7,c4 1jb bp 1j4,be 1j2 b9 1j7 b4 1jm,bm 1j7 bg 1j7 a9 1jd,a7 1jg b5 1j6,bd 1j2 bk 1j7,b9 1jb a9 1jp,ac 1ji al 1k1,bm 1jr cr 1jp,cv 1jk aa 1kk,a0 1ka 9s 1kf,a1 1jr al 1k1,al 1jk a5 1k1,a1 1k2 9s 1jv,a9 1ji 9c 1jv,9a 1k4 9a 1k8 9n 1km,9u 1jr 9h 1k8,9l 1k8 b0 1k1 b4 1k1,9f 1kd 8f 1l1,8o 1km 95 1k1,96 1k1 95 1kk,9a 1kk 9n 1kq,9s 1kj 7g 1ll 82 1kq,93 1kb 8q 1kk,82 1ks 6r 1ma,8h 1ks 8q 1km,8j 1kk 7f 1l1,79 1la 6r 1m0,6k 1m5 6c 1mc,7g 1lh 7g 1l6,70 1l3 62 1m3,62 1m5 76 1ln,79 1la 6k 1ln,6c 1lo 58 1mr,57 1ms 57 1mn,53 1m0 5e 1m0,60 1lh 5s 1lh,5l 1lu 69 1ln,6k 1l5 7v 1ks,8b 1ks 8f 1kt,84 1kk 6n 1lf,6c 1ln 5c 1lu,5e 1lu 6l 1la,6n 1la 6i 1lc,6b 1la 5h 1m5,84 1kk 8a 1kj 8o 1kd 63 1lf,5h 1ls 4l 1mi,4h 1mj 3o 1ml,41 1m5 5g 1mc,5h 1mc 5h 1ms,5a 1ml 4v 1mg,4s 1m9 4v 1m5,55 1lu 48 1mc,46 1me 4f 1ms,53 1mg 53 1mj,4q 1mr 3v 1mu,3r 1ms 3k 1ms,3d 1n0 43 1n2,17m 138 18p 12n 1a0 124 1ao 11i,1ap 11i 1bs 110 1cl 10l,1co 10l 1d3 10c,1cm 10f 1ec vd,1ef va 1fd um 1g4 u9 1hc to,1hg th 1ie st 1jm q7 1kd oe,1kd ob 1kk mp,1kn ng 1l8 jr 1lv hp,1lv hf 1lv g3,11i 161 120 161,124 161 11i 161,10l 16h 10q 16m,124 15s 11p 15v,124 15q 115 15v 10n 15v 105 161 vq 15u,vq 15v 101 163 10r 165 11i 163 115 167 110 168,vv 161 10f 177,103 163 10l 17b,10f 175 10f 17d,10j 165 10l 16i,10f 165 10h 16i 10o 16u,106 165 10h 16j,10d 16j 10j 16n,vr 15s 10m 15u,122 15q 13i 15l,10j 15u 122 15o,49 1m8 3e 1n8,3t 1md 32 1n3 49 1mk,4b 1mk 4o 1mk,48 1mf 2s 1na,2u 1na 27 1mt,21 1mv 3g 1na,3m 1mq 3b 1mk,2s 1mj 30 1n3,3r 1mj 2l 1mt,23 1n8 25 1o3 3d 1nh,3e 1n3 49 1n3,4b 1n6 34 1nq,2a 1o0 1e 1nq,1e 1no 20 1oc,2a 1na 11 1nu 16 1or,1c 1os 1h 1on,11 1o7 1f 1p2,1u 1o0 1o 1pk,21 1pb f 1os,-8 1p7 q 1pn,1e 1p4 1j 1oj,1f 1o7 a 1p4,h 1pb 15 1p5,15 1oe j 1pm,b 1pe 4 1pk,1 1pb 23 1oj,2j 1ns 2i 1nj,1h 1ne 1 1p7,-1 1p4 -e 1pt 15 1q6,1h 1og 1h 1o7,s 1oe j 1pk,t 1pi -h 1q0,-1r 1pp 11 1p5,1e 1on 1l 1or,o 1o0 4 1pk,-c 1p4 -p 1p2,-q 1or 4 1ou,f 1og q 1og,m 1oe -l 1pt,-24 1pb -u 1pg,-q 1pd -p 1p9,-q 1ou -1g 1pi -13 1pb,-n 1oe 1e 1o0,1l 1nq 1o 1nq,1a 1no -7 1pi,-5 1pi -j 1q8,-2o 1pi -13 1qr,-n 1qf -j 1qh,-1u 1pb -l 1q9,-2r 1pk -15 1ra,-12 1qr -38 1qr,-2v 1r6 -13 1r6,-7 1q9 -1l 1r1,-1r 1rd -2g 1rl -20 1rf,-24 1qb -34 1r6 -2t 1qq,-31 1qb -34 1rc -3b 1ro -29 1rh,-27 1rd -32 1sg -2v 1s5,-31 1ro -31 1r3,-2t 1qd -1i 1pv,-1g 1pn -2i 1qd,-2g 1pn -1l 1pe,-19 1p2 -p 1oj -1i 1os,-1u 1pb -1u 1pk,-1n 1p9 s 1oa,t 1o9 -u 1op,-1n 1p0 -2b 1pn,-2f 1pm -2i 1pv,-2m 1q8 -3d 1qk,-3o 1qh -3d 1rd,-2r 1pv -36 1q2,-36 1q8 -38 1r4,-38 1ra -3d 1rf -3k 1rm,-3d 1qm -3d 1r8 -3k 1sa -3j 1se,-3o 1ro -3t 1rq,-46 1rf -43 1rv,-3k 1qr -3j 1r4 -3s 1rm,-46 1r6 -4a 1s3 -48 1sa,-43 1sc -41 1sp,-4f 1sp -4e 1ss,-4o 1sa -4j 1su,-4h 1su -4e 1ss,-4c 1sc -4a 1t9 -4f 1te,-4h 1te -4h 1tp,-4f 1tp -3s 1t9,-3q 1rd -3o 1ra,-3q 1r6 -3s 1rd,-3q 1r1 -34 1qi,-31 1qi -31 1qd,-31 1q9 -3o 1qv,-3o 1r1 -41 1rj,-46 1rh -4e 1rv -4j 1sc -4n 1sq -4a 1t9,-48 1t9 -43 1t3,-3t 1sl -4c 1tl -4a 1tt,-4h 1tn -4j 1u2,-4o 1sq -4o 1tb,-4j 1sp -5e 1tr -4s 1ub,-4l 1u6 -4j 1tu,-4u 1tc -5a 1ug -57 1ub,-57 1u9 -5j 1v6,-5g 1uo -5r 1ut,-60 1up -59 1ud,-59 1u4 -5r 1uo -5j 1v4,-5g 1v1 -6d 1vm -6d 1vt,-69 1vt -5l 1vm,-5g 1v2 -55 1u4,-55 1tt -64 1vb -6b 20a -6v 20j -6i 20u,-67 20q -6e 20s,-6i 210 -6i 215,-6t 20a -6r 21a,-6p 21n -6m 215,-6r 210 -81 22i,-81 22m -79 230,-7h 22n -88 23d,-8c 23m -8q 241,-6d 1vs -6t 20a -6k 205,-6d 1vs -67 1vf,-60 1up -5n 1uf,-83 239 -8l 23q,-8m 23v -91 24l,-8a 22v -8u 23k,-93 241 -98 24s,-93 24q -a9 260 -br 27f -cj 28a -d5 28q,-d5 28o -do 29c -el 2ac,-en 2ac -ft 2bb,-fv 2bb -gk 2br,-gm 2br -hm 2c9,-hq 2cb -jb 2cv -k7 2dc,-k9 2dc -lm 2dv,-lq 2dv -ms 2e3,-mu 2e3 -nr 2ea,-nu 2ea -po 2eq,-pq 2eq -qm 2f5,-qs 2f7 -s7 2fr -sl 2g0 -t7 2g6,-t7 2g4 -uf 2gd -ve 2gg -115 2gm,-117 2gm -12k 2go -145 2gk,-148 2gm -164 2g6 -17s 2fk -18f 2fb -197 2f3 -19g 2eu -19g 2f5,-147 2gk -164 2h8 -16r 2hj -17a 2i1 -17o 2lk -18a 2pb -18u 2uf -19j 2tp,-19l 2tn -1an 2u8,-1ap 2u0 -1ap 2te,-1a7 2tb -19g 2t9,-195 2t9 -199 2u0,-19l 2tv -1ar 2u6,-1b6 2u2 -1bm 2tg,-1bo 2tg -1a5 2tr,-19s 2tb -1b8 2te,-1bq 2tb -1ch 2u9,-1cc 2u9 -1bt 2tp,-1bv 2tg -1d1 2tp,-1d5 2tp -1d5 2u0,-1d8 2u0 -1dl 2u0,-19e 2f5 -186 2fl -17s 2fr -14j 2go,-19f 2f6 -17e 2ig,-19a 2f8 -17d 2ic,-17r 2ft -16r 2hj,-17n 2ft -16p 2hg,-16i 2g8 -160 2h5,-16c 2ga -15q 2h3,-17v 2fq -18f 2gj,-17t 2fr -18d 2gm -177 2gv,-18b 2gq -175 2h3 -17k 2hq,-175 2h5 -17k 2hu,-17g 2hp -172 2hp,-17i 2hp -177 2hs,-17m 2ft -16e 2gf,-17k 2g1 -16a 2gl -16u 2h8,-169 2gq -16s 2ha,-15f 2gj -15q 2h3,-15c 2gj -15o 2h3,-1cs 2tj -1ei 2u1,-1ek 2u1 -1en 2uh,-1e7 2ts -1fd 2tq,-1gl 2tv -1h3 2us,-1go 2v0 -1ep 2uf,-1en 2u6 -1hh 2uf,-1hp 2ul -1ji 2ve -1gd 2uj,-1g3 2ua -1g8 2u8,-1ik 2tk -1l1 2uu,-1l6 2v5 -1ji 2vl,-1i9 2v7 -1kh 2us,-1le 2v3 -1lh 2vu,-1lo 2vn -1nm 2vn,-1o0 2vl -1kj 2vr -1jr 2vr,-1m7 2vc -1o4 30n,-1ks 2v0 -1m9 2v1,-1nv 2v7 -1q5 316,-1po 31d -1mb 30p,-1lu 30b -1pm 30i -1qa 31r,-1qc 31r -1re 32c,-1s2 33g -1t1 34l,-1r2 326 -1s0 33a,-1r0 31b -1tb 33g,-1qu 32s -1rt 31h,-1sb 31v -1ua 35b -1s0 34t,-1rp 340 -1ul 347,-1vn 352 -216 36k -1uj 361,-1u3 35b -1v5 35o,-20r 35p -1v7 36d,-1t8 349 -1sv 340,-1sp 33g -1tb 331,-1to 32s -21q 36o -1ve 35k,-1uo 34n -1rt 338,-1rp 333 -1s7 333,-1tv 33l -1vp 35i,-20m 368 -22f 37n -22u 389,-23a 383 -25b 38u,-25k 39d -23p 38u,-231 383 -24e 395,-252 39k -26t 3bl,-27q 3bl -28n 3ca,-261 3a6 -25o 39n,-26a 3a0 -28u 3bs -283 3cc,-273 3b8 -27a 3ah,-28g 3aq -2bf 3cu -2a0 3d7 -27u 3c3,-27o 3bo -29v 3cj,-2b3 3d0 -2ca 3e4 -2cj 3eg,-2cl 3ei -2d4 3ek,-2at 3d0 -2ca 3e9,-26h 397 -26s 3b4,-24u 392 -26s 3ah,-26k 3a6 -257 397,-243 38e -22j 37c,-22f 378 -224 36v,-223 36o -250 38i,-259 38p -275 39t,-27n 3ab -294 3b8,-29i 3bm -29b 3bs,-27l 3ar -27e 3ai,-27a 3ad -268 39d -25k 395,-21b 367 -26l 398 -2d6 3eh,-2d4 3eh -2hk 3gi,-2hm 3gi -2lr 3i4,-2lr 3i2 -2rf 3kc -2tu 3l0,-2tu 3l2 -31q 3lp -361 3mm,-363 3mm -380 3n4,-37t 3n4 -3ae 3n8,-3ag 3n8 -3e1 3n4,-3k5 3mm -3nc 3lu,-3nf 3lt -3pf 3kj,-3na 4hk -3lm 4ja,-3lt 4j5 -3kg 4l0 -3j5 4n3 -3hq 4o7,-3hr 4o5 -3gb 4pd,-3g9 4pd -3ej 4r6,-3eh 4r6 -3cr 4s7 -3be 4t9,-3be 4t7 -3a1 4uh,-39v 4uh -37t 505,-37p 508 -35l 51p,-380 503 -37e 50h,-35n 51n -336 53a,-3k7 3mn -3dv 3n5,-3qd 495 -3rd 48h -3sf 481,-3sj 481 -3tu 47c,-3ts 47a -3vo 468,-3vr 464 -427 449 -43p 42m,-43n 42k -44k 41g -467 3v1 -472 3t9 -48g 3pt,-48g 3pr -49o 3mn,-49o 3ms -49t 3kr -49s 3is -4a8 3gm,-4aa 3gj -4al 3ds -4ce 33m,-33a 538 -30a 557 -2u1 573,-2tv 573 -2q8 59b -2ne 5c1 -2ki 5e9 -2is 5fq -2i6 5g8 -2i3 5gl,-2i1 5gn -2hm 5gu,-2hk 5h0 -2hh 5h7,-2hh 5h9 -2hs 5h0,-2hs 5go -2hk 5h5 -2hk 5hc,-2hk 5hi -2hh 5hj,-2h6 5hj -2gv 5h9,-2hh 5gl -2i5 5gh,-2hs 5ge -2hm 5gf -2hf 5h3,-2hd 5h7 -2i6 5ga,-2i6 5gf -2hk 5h3 -2hb 5he,-2h2 5h7 -2h6 5h0,-2hd 5gu -2hf 5hc,-2hf 5gn -2hd 5gj,-2hb 5gn -2h4 5h7 -2h8 5h0,-2h4 5h7 -2gd 5hn -2hf 5hr,-2h4 5hc -2h1 5hi,-2gp 5he -2hd 5hj,-2hh 5hr -2hj 5hj,-2hk 5he -2ho 5gs,-2hq 5gs -2hs 5hi,-2hs 5hj -2h8 5hc,-2ht 5gs -2ht 5h0,-2jb 5fa -2hl 5ge,-2h6 5i0 -2gq 5i4,-2gv 5hg -2hd 5hr -2gq 5i5,-2go 5hn -2gm 5i9 -2gv 5ik -2g2 5ji,-2g9 5im -2gf 5id,-2gf 5ib -2h1 5j6,-2gk 5j6 -2gf 5ib,-2gk 5hr -2fv 5in -2ft 5ig,-2g9 5hs -2gb 5im,-2g2 5ip -2fp 5ip,-2fn 5ii -2ft 5in -2g7 5ji,-2g2 5ie -2fn 5j6 -2fl 5it,-2ft 5jr -2gf 5im,-2fu 5jf -2fp 5j6 -2f0 5jk,-2f2 5jf -2ft 5k3,-2fr 5k8 -2e5 5l1 -2f7 5jt,-2fe 5ji -2fe 5jf,-2g4 5ig -2fn 5ie,-2fl 5ik -2f3 5ji -2f3 5k3,-2fb 5k3 -2eh 5k3,-2eg 5jr -2eq 5jq,-2eq 5k8 -2ec 5ko,-2e5 5ks -2ea 5k4,-2ee 5jv -2es 5k8,-2fb 5jk -2ej 5jr,-2eg 5k4 -2ea 5ks,-2dv 5la -2bm 5nm -28o 5q0 -25q 5ri,-25p 5rk -23b 5si,-239 5si -20h 5to,-20e 5tq -1uk 5u5,-1uk 5u3 -1s5 5uu,-1s3 5uu -1pv 5ve,-1pk 5vg -1oi 5vr -1kt 60v -1ho 62a,-1hi 62f -1fu 635,-1fs 633 -1d1 647,-1d4 649 -1ah 656 -17b 66a -154 66m,-153 66l -116 673 -tl 671,-tj 671 -ro 668,-rt 66d -pn 65o,-pg 65i -na 647,-na 645 -md 637,-mb 639 -m2 644,-m7 63u -mf 647,-md 63r -mt 63u -mp 642,-mg 63c -n4 63l -mt 63r,-mi 63i -mi 63c -n1 63i,-n1 63l -n4 63s -na 640 -n8 63r,-n6 63u -n6 644 -n6 63u -mv 63n -mm 63a,-mt 63j -mm 63i,-mk 63g -mi 63a,-mg 639 -mp 63a -mr 63e,-mv 63i -mv 63l,-n1 63l -n4 63s,-nb 642 -nh 647,-nh 649 -nd 645,-n2 63n -n1 63j -na 63n,-nd 63s -nm 645 -nm 64b,-nm 64d -ns 64e -nh 640,-nf 640 -nb 63u,-nb 63r -n6 63j,-n4 63j -n1 63g,-mt 63g -mp 63e -nd 63u,-nf 644 -nt 64d -nt 64i -no 64e,-nf 645 -no 647,-nq 647 -nv 64e -mv 63n,-mg 637 -mk 639,-mm 637 -mb 633,-m4 62u -m2 62q -mb 630,-m2 630 -lu 62l -lr 62l -md 62u,-mf 631 -mi 639,-mg 639 -m2 630,-lu 62o -ke 61d -ir 5vn -h5 5u3 -eh 5rr,-9f 5qa -6a 5r7,-66 5rb -4n 5si,-4k 5sm -3i 5u3,-3qh 494 -3pk 49i -3og 4a4 -3ne 4ad -3mh 4ah,-3q6 49b -3o7 4a8 -3ne 4b5 -3n6 4e8,-3n6 4e4 -3na 4hk,-3mj 4ah -3mj 4ak -3no 4af -3o5 4aa,-3mm 4ak -3nc 4be,-3mt 4ah -3nc 4b8,-3nc 4ah -3nn 4as,-3nj 4ah -3nn 4am,-2iv 5fh -2ii 5fq,-2j3 5fh -2ja 5f8 -2jf 5fa,-2jd 5fe -2j4 5fe,-2j1 5fe -2it 5fh,-2ir 5fj -2io 5fp,-2im 5fp -2ii 5fq,-2if 5fq -2i9 5fq -2i2 5g0 -2hp 5ge -2hg 5gl,-2h9 5gp -2gu 5h4,-2gn 5hd -2gj 5hk,-2gi 5hr -2gg 5ia,-2hn 5g9 -2im 5fs,-2io 5fq -2ir 5fq,-2it 5fp -2jf 5fg,-2jh 5fe -2jj 5fa,-2jf 5f3 -2j4 5f3 -2it 5f5,-2ir 5fa -2im 5fh,-2ik 5fn -2ib 5g0 -2ir 5fc -2jh 5fa -2jf 5f5,-2jo 5eu -2jc 5ev,-2ja 5ev -2iv 5f5 -2im 5fe,-2ii 5fe -2if 5fg,-2if 5fh -2ii 5fg,-2j6 5f7 -2iv 5fh,-2ik 5fh -2i2 5fn -2hp 5g0,-2hp 5g2 -2hn 5ge,-1jr 61e -1ik 61l -1fm 634,-1ku 610 -1ie 61l,-ei 5rq -br 5pk,-d6 5qo -c6 5qb -a5 5qb -9h 5q9,-br 5pn -cv 5qk,-br 5pp -bt 5q9,-c1 5pt -c1 5q9,-3k 5u0 -1r 5v6 -10 5v6 6 5vt,8 601 l 60c,o 60f 1a 60n,1c 60n 20 611,27 613 4q 62b,4t 62b 6l 63b,72 63q 82 648,86 648 bk 676 ea 68q,ea 68t gn 6a1,h4 6a7 iu 6b2,ir 6b3 ll 6ch,lp 6cl kf 6bu,lp 6cg ov 6ed,pg 6ed ta 6g3,ou 6e9 r7 6et,rg 6f2 up 6hi 12l 6j6,12s 6jd 14p 6k6,14g 6k8 180 6m9,182 6mc 1a4 6n0,1aa 6n2 1d0 6no,1d4 6nr 1g1 6pj,1g7 6pl 1i4 6q3 1kl 6rg,1k9 6r5 1lv 6sb,1m0 6sb 1ns 6t8,1nv 6t8 1rj 6ul,1rk 6up 1s8 6us,1sh 6v2 1ut 70g,1uv 70i 20d 71d 22u 72u,22t 72n 24b 740 26c 754,26e 754 270 75b,26u 758 29c 75k 2cr 75r,2d1 75v 2d4 75v,2cp 75r 2fn 75v 2jj 75i 2md 74p,2mc 74r 2q1 73n,2q2 73n 2tv 72a,2tv 72c 2v3 71v 30s 70t 31l 700,31l 6vu 333 6tt 341 6ru,341 6s2 35e 6pd,375 6ph 380 6r3 39q 6tb 3a9 6u0 3ao 6un 3b4 6vh 3bc 70c 3bf 714 3be 724 3bn 73d 3c4 74m 3cm 761 3da 772 3e2 77q 3es 78c 3g0 791 3h8 79p 3id 7af 3jk 7b7 3ks 7c1 3m2 7d0 3n7 7e1 3ob 7f4 3pf 7g4 3qh 7go 3rm 7h8 3se 7i3 3t0 7j0 3tq 7jq 3ut 7kl 3vi 7li 408 7mg 417 7na 42f 7o5 43k 7om 44t 7p1 46a 7p9 47q 7pc 49b 7pa 4aq 7p3 4bu 7oo 4cs 7oa 4do 7o2 4ej 7ng 4f7 7me 4g0 7ls 4gv 7l9 4hv 7ka 4in 7jb 4j9 7if 4jt 7hl,4rt 7ju 4rk 7l3 4r4 7m5 4qc 7nd 4pj 7og 4ol 7pl 4nl 7qs 4mj 7s4 4le 7t3 4k5 7tq 4j0 7uh 4ho 7vj 4gt 80k 4ft 81o 4eh 82e 4da 82p 4c1 834 4an 83j 498 841 47t 84a,47r 849 465 849 448 83p,448 83q 413 82o 413 82s 442 83s 454 845 45u 84c 467 84k 47b 84g,442 83s 44v 85g,47t 849 44b 85m,41c 82v 42g 86m,44o 85i 42g 86j,41f 82v 42i 86h,43p 83s 44m 85f,43p 83s 42l 86f,43m 83q 42i 86b,42j 83e 41s 849,42l 83e 41u 84e,45j 84b 44t 85d,45m 84c 44v 85d,4rt 7k3 4so 7he,4sr 7hc 4uc 7f4,4ue 7f2 4ve 7cg 4vt 7bh,509 7bf 506 7bh,504 7bh 509 7a0 50p 78e,50g 7a8 4vr 7bq,4vr 7bm 509 7a2,42f 86e 3vo 88n,3vq 88n 3v3 89c 3ub 8a3 3tb 8aj 3sd 8b2 3re 8ba 3qf 8b9 3pb 8b9 3o5 8be 3n8 8bq 3mf 8cd 3lp 8cv 3l9 8dk 3ki 8ek 3jl 8fg 3ih 8g4 3hi 8gj 3ge 8h4 3f1 8hu 3dp 8in 3cg 8ji 3b6 8kg 39q 8lf 38a 8m8 36p 8mo 35b 8n4 33u 8nr 32e 8oo 30t 8pk 2vb 8qa 2tq 8r5 2sd 8s3 2r5 8sv 2pp 8ts 2o9 8ul 2mo 8vb 2l6 902 2ji 90u 2i0 91v 2gd 931 2en 941 2cu 94p 2b4 95a 29a 95o 27e 964 25h 96n 23i 97a 21k 97m 1vl 97r 1tr 97t 1s5 97s 1qo 97p 1p9 97r 1o2 987 1n2 98h 1ls 98j 1ki 98t 1j7 99i 1hs 9ac 1gm 9b1 1fg 9bc 1eb 9be 1d7 9bh 1c3 9c1 1au 9ck 19i 9d6 183 9df 16g 9dm 152 9e3 13k 9em 128 9fd 10p 9g6 v7 9gn tj 9h0 rt 9hg q9 9i6 oi 9iq mo 9j5 kv 9ja j6 9jb h9 9jh fa 9k1 dd 9kn bh 9lh 9m 9mf 7s 9nf 66 9oj 4j 9pq 31 9r2 1d 9sa -c 9tb -23 9uk -3j a02 -54 a1h -6t a2n -87 a3m -9e a4q -ai a60 -c2 a7j -dc a8m -en a9n -fu aas -hk ac2 -j3 ada -kh ae2 -lk aet -mr afd -ni agc -og ah0 -pb ai0 -q9 aiq -rb ajf -s7 ak8 -t9 alc -tv amf -v7 ank -10f aoq -11h aq7 -12b ark -13a at2 -14e auh -15f b02 -16c b1j -17m b2t -191 b47 -1a4 b5p -1b3 b6u -1c9 b7v -1df b99 -1eg baj -1fb bbh -1ft bcp -1gk bdv -1hm bf9 -1ij bgq -1j5 bid -1jh bk0 -1jj bli -1jt bn7 -1km bor -1lp bq2 -1mq br0 -1nv bs7 -1p6 btk -1qg buo -1ru bvg -1th c06 -1v4 c18 -20c c2g -21l c3n -23a c4l -250 c5a -26p c5p -28g c61 -2a4 c64 -2bg c66 -2ct c67 -2e0 c64 -2f3 c5t -2g5 c5c -2he c4j -2ii c3r -2jp c33 -2l4 c2g -2mh c22 -2nv c1m -2pg c1a -2r3 c0o -2sn c07 -2u8 c06 -2vi c0c -30e c11 -30i c2a -30e c3k -30j c52 -315 c5t -323 c6b -335 c6j -34a c6m -35n c6r -370 c77 -38d c7p -39u c8d -3bi c8r -3d8 c91 -3f0 c9f -3go ca8 -3ih cb6 -3kc cc4 -3m8 ccr -3o0 cd3 -3pf cd1 -3qo ccq -3rr cce -3sp cbp -3tk cao -3ug ca1 -3vl c9t -40h ca7 -40i cb3 -40u cc2 -423 cc0 -433 cbm -44b cbm -45v cbv -47d cc9 -48u ccl -4ah ccu -4c2 cct -4dj ccm -4fc ccm -4h9 cd5 -4j7 cdr -4l5 ceh -4n3 ceu -4p2 cf5 -4r0 cf6 -4su cf5 -4uu cf3 -50u cf2 -530 cf0 -551 cet -574 ceq -596 cem,-6ma 11va -6ma 1231##T -58d ce2
