How Do You Change A Tyre?
On 22/02/2018 at 1:14 PM, jimmyl said:
DID rim and X light don't even need a beader  -just pop it on a blow it up.
Full tank of air and no valve 100% with a used tyre - might need two goes now and again with a brand new one.
Try and store the tyres with the bead turned out -helps get a mechanical seal with the rims so compressor can blow it up.
theres numerous ways to get tyres on, but as a simple device the beader cant be beaten. Any other method requires this or that, we have put a michelin on a rim with a foot pump using a beader.
  • Replies 31
  • Views 22.5k
Most Popular Posts
  • I've changed dozens of tyres over the years, for tubeless one of the easiest ways is to use cable ties. Not kidding here, look it up on youtube. You basically cable tie the tyre into one ring. It work
  • nigel dabster
    nigel dabster
    Cable ties easy? Not as easy as a beader.
  • section swept
    section swept
    Get someone who knows what they are doing to actually show you! There’s no better way to learn than to actually do the job with guidance. Everyone has told you good information, but you sound like you
Just watched the zip tie method on you tube .
if that’s the easy way I don’t want to see the hard way ?
as part of our 2 day trials training camp I do a tyre change and some basic maintenance .
its surprising what as well travelled riders we take fiir granted that the newcomer has no idea about .
remeber y&g having a tyre change comp in club night - it was a tubed  rear off the bike .
think glen scholey or maybe john Lampkin doing it in under 3 mins - security bolts and all!!
