jonnyc Posted October 30, 2008 Share Posted October 30, 2008 should my front disc brake disc be a wee bit lose should it be?? i tryed tighting it but the screws are tight as they will go..!!! Quote Link to comment Share on other sites More sharing options...
feetupfun Posted October 31, 2008 Share Posted October 31, 2008 should my front disc brake disc be a wee bit lose should it be?? i tryed tighting it but the screws are tight as they will go..!!! Yes it should move a wee bit. Its called a floating disc and helps the disc stay nice and flat when it gets hot, and ensures that the disc can move to align with the pad surfaces when braking if there is any slight difference in alignment without flexing the disc. Quote Link to comment Share on other sites More sharing options...
dan williams Posted October 31, 2008 Share Posted October 31, 2008 Careful you don't break off a screw or crack the hub. All disks are now floating type and have some freeplay. Just as a rule of thumb, if you're nervous you're tightening too much you are. None of the modern machines has much metal behind that bolt no matter where it is on the bike with the possible exception of the crankshaft. Most disks have some type of finger washer on both sides to approximately center the disk. Quote Link to comment Share on other sites More sharing options...
biffsgasgas Posted November 1, 2008 Share Posted November 1, 2008 And they will rattle when the brakes are not applied. --Biff Quote Link to comment Share on other sites More sharing options...
