February 18, 200917 yr where can these be had. i keep getting jets that have a larger lower barrels & thread sizes... thanks for your help! dean deanyoungiii@att.net old hickory, tn
February 18, 200917 yr I have had to drill my own pilot jets for the TLR200. If I remember correctly, the #40 is .4 mm or 0.0157". A 1/64 drill is 0.0156" and a #78 drill is 0.016". You can get small drill sets at: http://www.mcmaster.com/#31055a64/=npars I did once see a link for carb parts that suggested the #40 jet from some year CB750 would fit but never tried that one. The TLR200 main jets are the same as XR100 mains but the pilots are different.
February 18, 200917 yr They're hard to come by. This guy has them but hold onto your wallet! www.motorcyclecarbs.com You're better off drilling... It helps with the off-idle stumble but doesn't cure it completely.
March 5, 200917 yr Author found a honda part # that works. 99124-076-0400 from a 1975/76 cb400F. DEAN
March 6, 200917 yr where can these be had. i keep getting jets that have a larger lower barrels & thread sizes...thanks for your help! dean deanyoungiii@att.net old hickory, tn Dean, I'm not quite sure if the TLR has a Keihin carb, but take a look at this early Keihin pilot to see if that's the type you need. If so, PM me with your address and I'll send you a big bunch of #38's free so you can drill them and experiment without worrying about making a mistake. I have a lot of them for some unknown reason in my jet boxes and never use them. Jon
March 6, 200917 yr found a honda part # that works. 99124-076-0400 from a 1975/76 cb400F.DEAN If they work, Dave Silver should have some - 01728 833020. David Silver Spares. They were Edited March 6, 200917 yr by Wherry
March 7, 200917 yr Had the same problem on my cub, had to have the air screw out 2 turns further than the best idle setting to get rid of the off idle stutter. I drilled out the jet using the mini drill set below.. http://www.rdgtools.co.uk/acatalog/DRILL_SETS.html I took the jet out to 0.4 and then 0.45, now ticks over with the screw 2.5 half turns out and no stutter.. fixed for less than a fiver and 1/2 an hours work.
