Anybody Else Struggle With 348 Exhaust?
Well, I'm starting to reassemble the 348. Have a new piston in a freshly bored cylinder, got the cylinder and head on today.
Now for the god-forsaken exhaust...... I struggled getting it off when dissassembling the engine, in fact, I couldn't remove the exhaust until I removed the clyinder first.
Today, I forgot to position it in place between the frame and back wheel, and between the front frame downtubes, before installing the cylinder. Can a guy get it on by first removing the rear wheel and rear fender [ thus allowing room to manouver it fore and aft whilst getting the front pipe aligned and bolted up ]?
I don't really want to have to remove the head / cylinder again just to get the exhaust back on.........I'd rather remove the rear wheel and fender if necessary. Anyone got an easier method? It's like a puzzle of sorts.
Also, I want to install an ignition condenser [ inline with the black wire going to coil ] up under the frame / fuel tank. Does the condenser on the stator have to be disconnected first, or will it hurt to have two condensers connected at once? What rating, or microfarad does a 348 require?
Thanks,
Spoke.....
Hi
pipe should feed in from the front fairly easily,
disconnect the original condensor and remove it
use any car type condensor the only criteria i look for is that it already has a bracket on it as i'm to lazy to make one
cheers helm
Hi
cheers helm
The exhaust is a bit of a bitch but it will go on with the head and barrel fitted because i did it on my malcolm Rathmell replica 348
Dave
Just make sure the tank/seat assembly is off the bike and with a few twists and turns (having your tongue out of your mouth and thinking of a few choice words) it will go in!!
Ah yes, it worked!
Not so sure I could do it again, but, all of the twists and turns I did added up to it slipping into place.
Thanks again for the tip!
No worries. Take it off again tomorrow and put it back in. You will be a wizbang on 348 exhausts in no time. See ya mate
Everyone says to remove the old condenser when you add one at the coil, but I didn't on my 349 and it starts and runs well!
I don't doubt that it can do that, but i would remove the old condenser. One way a condenser fails is to go into a "high leakage" mode, which can allow more of the ignition energy to leak out to ground instead of being used in the coil to produce a nice big spark. I would imagine that having 2 condensers in the circuit increases the total amount of leakage possible (i have not tested this, but am just guessing. I should dust off the oscilloscope and try to remember how to use it...screw it :dunce: ). When one of the 2 condensers fail (goes into high leakage mode) the second condenser is not going to help you.
I am just a hack that a number of years ago was a pretty pathetic physics student, so if i have misstated anything, someone please correct me!
I
Dont worry, someone will, if required.
I guess that is the beauty of the internet!
I removed the condenser wire from the points and just tucked the pig-tail end of the wire up out of the way, leaving the condenser in place on the stator. Wired a new condenser under the tank next to the coil on the 348. Seems to work.
