kevhenson Posted May 21, 2009 Share Posted May 21, 2009 (edited) Where is the cheapest place to get a flywheel puller? or does anyone know the thread and pitch i can trawl through ebay then Thanks Edited May 21, 2009 by kevhenson Quote Link to comment Share on other sites More sharing options...
jse Posted May 21, 2009 Share Posted May 21, 2009 Where is the cheapest place to get a flywheel puller? or does anyone know the thread and pitch i can trawl through ebay then Thanks Although I don't have the thread/pitch spec.'s right at hand, it's the same as the very common standard Japanese fine thread pullers for a majority of the two-stroke MX bikes. The kicker is that the GasGas is a right-hand thread and the standard Japanese flywheel puller is a left-hand thread. They look exactly the same, and I'm sure a lot of riders (including myself before I marked them so as to not grab the wrong one) have been quite puzzled why it wouldn't screw in correctly. I haven't found any other flywheel hub that uses that exact puller other than the GasGas. Jon Quote Link to comment Share on other sites More sharing options...
bigfoot Posted May 21, 2009 Share Posted May 21, 2009 I have one that I got from Gas Gas UK. It wasn't very expensive. I'd also add I have one that fits an older gasser and one that fits a pro so there is a difference. Quote Link to comment Share on other sites More sharing options...
b40rt Posted May 21, 2009 Share Posted May 21, 2009 Where is the cheapest place to get a flywheel puller? or does anyone know the thread and pitch i can trawl through ebay then Thanks Try here http://www.trialsbits.co.uk/index.php?cPat...t=2a&page=2 Quote Link to comment Share on other sites More sharing options...
kevhenson Posted May 22, 2009 Author Share Posted May 22, 2009 cheers... the prices are good there but still need to know the thread and pitch please Quote Link to comment Share on other sites More sharing options...
hrc1 Posted May 22, 2009 Share Posted May 22, 2009 M27 x 1. Same as TXT, but Pro needs longer bolt. As small socket does this - if you have the TXT puller. Quote Link to comment Share on other sites More sharing options...
b40rt Posted May 22, 2009 Share Posted May 22, 2009 cheers... the prices are good there but still need to know the thread and pitch please e-mail Amanda @ trialsbits, should get the answer. Quote Link to comment Share on other sites More sharing options...
