Piston Size
samo
Hi.
I have to change piston. It has marks on and cilinder is also in bad shape. Could someone tell me which piston I have? On top is written 03-20, 7595. Is it second or third one? If it is third one then I must change cilinder. Am I right, or is there one biger then third?
Samo
Edited by samo
There are 2 grades of piston there should be A or B stamped on it! this is stamped on when manufactured depending on early or late production! as for cyl it will after be replated and bored to the size of piston! was told all this by lampkins when i got a old techno piston and cyl replated!
My bike is running again :) I put 250 Cylinder on and didn't have to change anything.
Cylinder i got has a B Piston and was pretty black on top. Dealer who sell me this assure that this is a new Cylinder with Piston running just an hour..
Is it possibile that you can get B Piston in new Cylinder?
