November 14, 200916 yr This totally new and revolutionary carb is based upon the popular Kiehin platform using a (cheap) OKO instead and incorporate a totally unique elliptical oval bore design exclusively for trials! It will offer a smooth low end, totally responsive and controllable, low end starting off with the 24mm bore and throttle crecent, and gradually transfer power into the larger bore diameter equal in size to to the great 30mm on the top end power and large bore diamiter! A bit of my own special rigging will incorporate TWO bowl vents, come hell or high water! When combined with the special progressive throttle tube, this thing will go from mild to wild in a twist if the wrist, so hang on! I will accept all deposits, expect delivery sometime next year if you are lucky, cause I do have other things to do.
November 14, 200916 yr your too late cope the fuel injected trials bike arrives next July OSSA OSSA OSSA !!
November 14, 200916 yr the fuel injected trials bike arrives next July Its been here since 05 mate Mont Mont Mont
November 14, 200916 yr Author As i constantly develop refinements : The ones set for converted montesa riders will not idle below 2000 rpm, and if you try it will pitch you on your head! The Beta adapter allowes the carb to spontainiously p*** on your feet! And the Gasgas version has a spring loaded mount, which allowes it to completely fall off when you least expect it!
November 14, 200916 yr Author Always thinking ahead, I am already working on a "special" carb for the Ossa! This will be a small, inexpensive unit based upon the WALBRO carb (weed wacker), you know ,those things that only run for one year! Easily mounted to the bike, it really does not do anything. Simply gives you something to fettle with other than your nuts!
November 14, 200916 yr The ones set for converted montesa riders will not idle below 2000 rpm, and if you try it will pitch you on your head! Edited November 14, 200916 yr by The Addict
November 14, 200916 yr Always thinking ahead, I am already working on a "special" carb for the Ossa!This will be a small, inexpensive unit based upon the WALBRO carb (weed wacker), you know ,those things that only run for one year! Easily mounted to the bike, it really does not do anything. Simply gives you something to fettle with other than your nuts! Those walbro and tillotson carbs are great!
November 15, 200916 yr Its been here since 05 mate Mont Mont Mont Now Now justin you know my views on this issue trials bikes are two stroke rebadged Harleys are 4 stroke.... just hope the ossa doesnt idle at 1850rpm
