December 20, 200916 yr Hi, I need a 12mm swinging arm spindle to complete my 1972 Bultaco Sherpa. Bultaco UK don't have any and don't know when they will make any? Alternativley, any one know someone who could turn down a 14mm spindle?
December 20, 200916 yr Options 1 Buy some 12mm threaded rod from the hardware/building supply shop 2 Theres a person making stainless steel replicas of many old Bultaco screws, plugs, axles, nuts etc and advertises on eBay 3 Any machining business could thread the ends of a piece of 12mm steel rod for you
December 20, 200916 yr Which model? from M10 to M80 used the same part. After that a headed type and then changed to 14mm but forget which model the change over was. Wayne....
December 20, 200916 yr post the dimensions up here I haver loads and don t know which bike they are from L
December 20, 200916 yr Bultaco Swingarm Spindles M91 Early Style - Two Nuts Length – 240mm Threaded length – 12mm either end Thread Pitch – M12x1.5 Thickness – 12mm M91 Later Style - Headed type Length – 235mm Threaded length – 10mm Thread Pitch – M12x1.5 Fixed head end Head OD – 17.8mm Head thickness – 4mm Flat - 10mm Measured on my own bikes. Edited December 20, 200916 yr by rcgods
December 20, 200916 yr you could try ellastone off road(01889 590186)the y recently brought 70 bultacos plus lots of spares in from the states
December 20, 200916 yr Author Thanks all I brought one of Wayne Weedon who sells on ebay as fdosdisign. Just need him to finsh a needle roller bearing conversion for it.
December 20, 200916 yr Didn't know littleblackflash was you Duncan! But then I do keep my social activities on here and my business totally separate. Wayne.....
