2010 Pro Squeaky Forks
seems like a lot of the new bikes are doing it around here and it is pretty annoying. no body has been able to tell me what is it though.
Devon
Ive got an 09 Raga and mine does the same. The problem is that the dust seals are very tight to the sliders and it causes them to squeak. If you spray either a bit of wd40 or silicone spray on the forl stantions and rub it with a cloth it will stop the squeaking! Hope this helps
I agree with tricky dicky, on my sons 09 Raga 125 it did the same thing till I removed the springs from the dust seals and put Race Tech seal grease on the dust seals
