Evo Help ...
darrensn
Hi All, just got an 09 Beta 250cc Evo and need a bit of info please?
Is it best to use Normal or Super unleaded? (I think previous owner used normal)
Is Castrol TTS the best oil to premix with?
What spark plug is best for North West England running?
Should I fit an after market air filter or leave the factory one in?
Bike revs too high when on choke, but OK on tick-over?
Can I adjust this, or should I just pull the choke lever up less than normal (full)?
What way should the mapping switch be? Not sure what switching actually does?
Thanks in advance.
Definately super.Once its up and running you shouldn't need choke.That oil sounds good.Check with Beta UK about plug(lampkins).I would have a few spare filters to hand anyway.Get a good one,aftermarket ones generally seem better than originals.Have fun
How are you finding the Evo?Did you try a 4T Evo?Or consider one?
Edited by anyoldiron
Hi, I had a go on a new rev4 when they came out and didnt like it, it vibrated like hell ??
I just sold an 08 Montesa 4rt to go back to 2 stroke and the evo was the best I tried (for me) on test days.
When my evo is started on choke it revs too high, I know its only for a minute, but it needs altering (but not sure how to do it )
Not rode my evo yet, due to this snow, cant wait for better weather. Just trying to prep it for use, hence questions above ..
Cheers,
Hi yeah run super unleaded with the castrol tts and youll be right, i use 75ml of tts for every five litres of super unleaded.
The bike comes with a br7es ngk plug but Beta uk recommend using a br5es for the colder UK cilmate.
Only use the choke to start the bike up after that flick it off and let it warm up before you ride.
The map button in postion 1 is a softer map which should help with grip etc... map 2 is the full power map.
To be honest i dont bother with it as the powers not crazy anyways so i leave it on map 2 for alll conditions.
Hope this helps
Cheers
here is what ive done to mine in a works for me styley
super unleaded with ipone
leave switch at 1 for grip 2 for steps
air screw out to approx 1.5 turns ( sounds like thats been done on yours. re choke)
needle position 4 on carb
10 tooth on front
sxs white spring on rear ( im 80kgs as i love the beer)
changed to slow action throttle for winter
settled on flywheel weight in for now
suspension with no more than 1/3 travel (loaded) and a bit of rebound to suit
atf in the box
best of all (advice from the experienced boys on here) IRC on the rear AWSOME
check out dans clutch mod if you feel the need (great post)
im still crap but my bikes the best it can be
the above was the direct result of joining this forum thanks to all :huh:
Edited by jokerr
  • 4 months later...
I use normal unleaded and silkolene oil 70cc to 5 litres of petrol and never had a problem. Also I use a NGK BP5ES plug and a after market air filter are alot better than the standered one. hope that helps :rotfl:
Please sign in to comment
Sign In Now
