manxmann3 Posted March 5, 2010 Share Posted March 5, 2010 Hello. 1999 315r. Started second kick no probs. Was out on road riding to meet mates. Prob ridden for 10 mins and just died while i was riding. Then nothing. Theres no spark. Have tried another plug and still nothing. It was ridden for about an hour in snow week before, no probs. Washed, wd40 on bike. Now this carry on. Has anyone any ideas? Thanks Quote Link to comment Share on other sites More sharing options...
bambam_n_chunx Posted March 5, 2010 Share Posted March 5, 2010 You`ve already tried disconnecting the kill button and still no spark???? thats the first place I would look. Quote Link to comment Share on other sites More sharing options...
manxmann3 Posted March 5, 2010 Author Share Posted March 5, 2010 How do you mean? Disconnect kill switch at connectors under tank then check for spark? Quote Link to comment Share on other sites More sharing options...
bambam_n_chunx Posted March 5, 2010 Share Posted March 5, 2010 Yes thats what I would try first, its a possibility that some water has earthed the kill switch. I had a 99 mont with a similar problem that would run for 10 mins then no spark, half an hour later the spark would reappear for another 10 mins, that turned out to be the stator coils breaking down. New coils fixed that but cost a fortune. Good luck Quote Link to comment Share on other sites More sharing options...
jimmyl Posted March 5, 2010 Share Posted March 5, 2010 Had at least one Mont need stator coils rewinding - very similar symptoms - don't buy new but get them rewound. If you look in the manual it gives resistance vales to check Quote Link to comment Share on other sites More sharing options...
manxmann3 Posted March 5, 2010 Author Share Posted March 5, 2010 is there anyway of testing to see which part is goosed? multimeter? if stator needs work then who does this? thanks Quote Link to comment Share on other sites More sharing options...
jimmyl Posted March 6, 2010 Share Posted March 6, 2010 Look in manual or download pages from one of the threads on here. Tells you what to check with a multimeter and go from there. Look for people rewinding stators in TMX or on the web - Ive used somebody in the west county a few years ago. Good luck Quote Link to comment Share on other sites More sharing options...
manxmann3 Posted March 8, 2010 Author Share Posted March 8, 2010 Turns out it is the plug cap thats knackered. Thank god. Cheers for advice. Quote Link to comment Share on other sites More sharing options...
ham2 Posted March 9, 2010 Share Posted March 9, 2010 Doesn't get much cheaper than that! You lucky git Quote Link to comment Share on other sites More sharing options...
manxmann Posted January 23, 2011 Share Posted January 23, 2011 Hello again. Have just decided to start riding my 99 montesa again, have only ridden a couple of times since posting my problems with no spark. Well its playing up again. This might sound stupid but should it be a really bright clear spark to look at? The spark is really feint! It wont start at all. Tried the same plug in my ktm lead and it sparks like mad. Can anyone shed some light on this problem? Once i get this sorted this time then ill defo sell, time for something newer and hopefully ore reliable. Thanks. Quote Link to comment Share on other sites More sharing options...
honda_freak Posted January 23, 2011 Share Posted January 23, 2011 Firstly - have you tried disconnecting the wires to the stop switch and then tested whether it can start or not. If there is still no spark, or it will not start, try to measure the resistance of primary / secondary winding of ignition coil. Quote Link to comment Share on other sites More sharing options...
manxmann3 Posted January 23, 2011 Author Share Posted January 23, 2011 Thanks for reply. It is sparking but really feintly. Not bright like my ktm sparks. Is this normal? Doesnt seem good enough to start the bike. Quote Link to comment Share on other sites More sharing options...
neil king Posted January 25, 2011 Share Posted January 25, 2011 Thanks for reply. It is sparking but really feintly. Not bright like my ktm sparks. Is this normal? Doesnt seem good enough to start the bike. I've never had trouble with the Montesa but on some Shercos you cant even see the spark in the daytime. Quote Link to comment Share on other sites More sharing options...
manofsteele Posted January 30, 2011 Share Posted January 30, 2011 Check the earth lead from coil to frame - clean it right up. I had similar problems to you a while back, cured by cleaning that wire. Quote Link to comment Share on other sites More sharing options...
