May 21, 201016 yr I just found a nice montesa cota 247, I am trying to what year it is, this is what I know montesa cota 247 frame and engine # are the same. it is a 21m 5 speed, there is a #stamp on the block 69.
May 21, 201016 yr Hi Stinger Perhaps I am at risk of stating the obvious but:- All cota 247's were 5 speed All cota 247 frame numbers were prefixed 21M What do you mean by the block being stamped 69 ? Regards Sparks2 Edited May 21, 201016 yr by sparks2
May 21, 201016 yr I am looking to buy a little project for the winter, a 247 it has to be before 1972 as I would quite like to ride it in a couple of Spanish classic rounds. We had in the family a brand new one from John kersaw of Wickford around 78/79 but cant remember too much about it. With bultacos you have model numbers what do I look for in Montesas regarding dating it.. Hope this follows on from the original post. Thanks in advance
May 25, 201016 yr Author ok so that does not help, how can i tell if it's a mk 1 mk 2 mk 3 mk 4 mk 4b ? 69 is stamped on block at the rear of the motor on the mount i do not know if this will help, brake pedal on the right side shift on the left?
May 25, 201016 yr Very difficult to date a 247 as they look pretty much the same. About '73 on had left hand gear change so it's probably a 4, 4b or a 5. Could be an Ulf Karson, they had clutch arm on top of the casing, not underneath. MK5 may also have had that too, can't remember, but cases could have been changed over the years by previous owners so doesn't really confirm anything. Have a look here, these brochure photos may help http://www.ataq.qc.ca/galerie/index.php?fo...us%E9e/Montesa/
May 25, 201016 yr Author Thank you woody; It's looks like it's a 74. clutch arm is under the motor stinger.
June 16, 201016 yr I am looking to buy a little project for the winter, a 247 it has to be before 1972 as I would quite like to ride it in a couple of Spanish classic rounds. We had in the family a brand new one from John kersaw of Wickford around 78/79 but cant remember too much about it. With bultacos you have model numbers what do I look for in Montesas regarding dating it..Hope this follows on from the original post. Thanks in advance hi i have a 1971 montesa cota 247 i know the year because its been road registered and i have the log book
November 4, 201214 yr hi Does anyone know if they made a 247 in 1984 - looking at a project bike but it doesn;t look like the 70's bike the engine shape is abit different so is the seat?? Any ideas? thanks in advance
November 4, 201214 yr As far as I remember the last 247's were 1979 and after that they made the 248 which had the wavy fins like the 349's, when it came to 84 it would be the 242, alloy swingarm, hope this helps
November 5, 201214 yr You should find a picture of it here http://www.ataq.qc.ca/galerie/index.php?folder=/Mus%E9e/Montesa/
