stilly Posted February 1, 2011 Share Posted February 1, 2011 Hi all, some time ago when I was out on the sherco I noticed a lad had a front mounted bottle in-between his forks then the number board over it, has any 1 seen these and any ideas were I can purchase 1, it looked perfect for a refreshing drink when out, any ideas cheers. Quote Link to comment Share on other sites More sharing options...
mikee Posted February 1, 2011 Share Posted February 1, 2011 (edited) sure it wasn't one of these ???? Hebo tank Edited February 1, 2011 by MIKEE Quote Link to comment Share on other sites More sharing options...
neo Posted February 2, 2011 Share Posted February 2, 2011 I suppose you could fill it full of water instead of petrol .... but why would you want all that extra weight up so high on the bike? If you use a bladder backpack (Camelbak) it's weight shifts with your weight. So can work with you rather than against you. Best of balance. Neo Quote Link to comment Share on other sites More sharing options...
firedfromthecircus Posted February 3, 2011 Share Posted February 3, 2011 I suppose you could fill it full of water instead of petrol .... but why would you want all that extra weight up so high on the bike? If you use a bladder backpack (Camelbak) it's weight shifts with your weight. So can work with you rather than against you. Best of balance. Neo What size of camelbak would you reccomend to carry what you need but not too big? Quote Link to comment Share on other sites More sharing options...
neo Posted February 3, 2011 Share Posted February 3, 2011 1.5 to 2.0 ltr should be good. Try and get one that has a horizontal strap that snap clips across your chest ... the lower the better. Best of balance. Neo Quote Link to comment Share on other sites More sharing options...
copemech Posted February 4, 2011 Share Posted February 4, 2011 1.5 to 2.0 ltr should be good. Try and get one that has a horizontal strap that snap clips across your chest ... the lower the better. Best of balance. Neo I run a Camelback ROGUE, which is a medium size, has a couple good pockets for small tools and will carry a decent quantity of water for hot or long outings. Cannot do without! The small ones, just for water, are better than nothing! And weigh nothing! Quote Link to comment Share on other sites More sharing options...
neo Posted February 4, 2011 Share Posted February 4, 2011 I run a Camelback ROGUE, which is a medium size, has a couple good pockets for small tools and will carry a decent quantity of water for hot or long outings. Cannot do without!...The small ones, just for water, are better than nothing! And weigh nothing! Yes good point Cope.... I guess I'm kinda spoilt riding at my own place all the time. Best of balance. Neo Quote Link to comment Share on other sites More sharing options...
firedfromthecircus Posted February 4, 2011 Share Posted February 4, 2011 Thanks for the advice chaps Quote Link to comment Share on other sites More sharing options...
b40rt Posted February 4, 2011 Share Posted February 4, 2011 Have a look at the Camelback Mule, slightly small but stops you carrying to much crap. Quote Link to comment Share on other sites More sharing options...
