McRae inquest
Your link says nothing about whether he was certified to fly nor whether he had permission to take up his sons mate.
Edited by TooFastTim
You need to stop by here so I can take you flying! Good reasons I stay away from the whirly things! :rolleyes:
If you are dead, can they still revoke your license?
Edited by copemech
Them things with a Jesus nut?
More info Here......
and here
"The cause of the crash is clearly outlined in the report. Most of the flight was captured on video and it is clearly evident that unnecessary risks were taken and that the accident was completely avoidable."
So what is the cause? Mechanical failure? The gov will allways point to you as completely avoidable. Should hav avoided the bucket o' bolts!
Same time said this?
The AAIB said a phenomenon that can give an impression the controls are jammed may have led to the significant deviation in the flight path that the pilot was trying to recover from. Disorientation, misjudgment or other factors may have led to this deviation but the cause of the accident could not be positively determined.
So which is it? Early witness said the machine making unusual noise.
Total BS!
Edited by copemech
:agreed: Like most things in the courts there's a lot of professional mud-slinging to see what will stick :unsure:
Tech talk:-
Is this the modern equivalent to the old 'Jesus nut' legend that Tim pointed out?
Jack stall or servo transparency
That phrase seems to rear it's ugly head when dealing with helicopter crashes..especially in Squirrels
Then there's this to contend with:-
Toroidal wash
Edited by HAM2
Is this the modern equivalent to the old 'Jesus nut' legend that Tim pointed out?[/url]
The Jesus nut is the single nut that holds the rotor on to the 'copter. So called because when it falls off the pilot says: "oh J$%#@"....
Yup,the legend is he's the only one who can help you when it fails.
