Just got a 2002 Rev 3...
The idea was simple...
Buy a cheap used bike (done, see below), join Berkhamstead MC (application in post), ride as often as possible, see how I feel in 6 months, sell current bike (bought with no real knowledge of the model or the sport), buy something new/newer using gained insight (so it matches my level, enthusiasm and riding style).
So I bought this bike more or less blind... What have I done.... :(
can't post images??? maybe because i am green to this forum
Edited by photoboy
http://www.youtube.com/user/dh79couk#p/u/3/VE7DCdGS2rU
Ok it started and ran for all of 30 seconds of starting misfire before fouling... not the greatest of beginnings..
I think I better take it to the brilliant Martin Wittering in the week and get his opinion, I am sure "even" with my 10 years of variously knacked two stroke experience; I am just new to the idiosyncrasies of the Rev 3... and the unknown quantities of a well used one...
Can someone give me the basic Beta starting drill?
I was going on:
1 open fuel tap
2 open choke
3 full throttle
4 find compression on lever, kick hard as possible / repeat on full throttle until it fires
5 blip for 3/4 mins or until you can feel some heat in the water pipes and shut the choke.
6 it should idle on it's own for a few mins, but best to get going lest it foul...
7 as soon as it is stopped, shut fuel if not starting immediately.
Am I far out?
Edited by photoboy
Hi Photoboy,
The starting procedure i used for my rev3 was:
1 open fuel tap
2 open choke (only required on cold days, would often start without)
3 throttle closed (i think that full throttle shuts of the fuel completely - but i could be wrong)
4 find compression on lever, kick hard as possible / repeat - giving small blip on throttle until it fires
5 blip for couple of seconds and shut the choke (if used).
6 then ride...
If that doesn't work i would whip the carb off and give it a good clean.
Good luck.
Hi Photoboy,
1 open fuel tap
6 then ride...
Good luck.
I second that. also if you think its flooded then use full throttle.
