March 15, 201115 yr Fed up with getting water, crud and debris in the top of the airfilter, from the rear wheel, I bought one of these rear mudguard/airbox covers from Feet-Up at SCARBORO', via Ebay I think they're originally made by H&D @ Malton ABS Moulded plastic and cost £15 Easy to fit Hope it works, can't be any worse than Honda's ommission of getting it right The problem - hole between mudguard and airbox The solution Edited March 15, 201115 yr by Johnnyboxer
March 15, 201115 yr Honda didn't omit anything in that area. Your supplying dealer or the previous owner did though. When the bike was supplied new, it came with a large thick rigid plastic 'liner' for the rear mudguard, full length, it also carried the rear number plate holder and the rear lights and indicators. The hole you indicate was for the wiring loom, and since it was sandwiched between the 2 layers of mudguard and liner, no crud passed through it. The best mod in my opinion is to use the supplied liner but cut short. I cut mine roughly in line with the back of the silencer, that way it keeps the crud out and reinforces the mudguard so if you regularly sit / land on it, it doesn't crack at the rear mountings
March 15, 201115 yr Author Honda didn't omit anything in that area. Your supplying dealer or the previous owner did though. When the bike was supplied new, it came with a large thick rigid plastic 'liner' for the rear mudguard, full length, it also carried the rear number plate holder and the rear lights and indicators. The hole you indicate was for the wiring loom, and since it was sandwiched between the 2 layers of mudguard and liner, no crud passed through it. The best mod in my opinion is to use the supplied liner but cut short. I cut mine roughly in line with the back of the silencer, that way it keeps the crud out and reinforces the mudguard so if you regularly sit / land on it, it doesn't crack at the rear mountings I've had it from new, the huge plastic inner support is in a box somewhere.................even cut down it's still huge This H&D item, I've added is just as good in every way for crap reduction, but maybe the added mudguard support point of view So it'll do for me
March 16, 201115 yr Author Tha can buy a fair bit of duct tape for 15 quid Tha can, but it's tacky and my fingers stick together like webbed ones
March 18, 201115 yr I've had it from new, the huge plastic inner support is in a box somewhere.................even cut down it's still huge This H&D item, I've added is just as good in every way for crap reduction, but maybe the added mudguard support point of view So it'll do for me I cut mine down with a hacksaw the day I got it, I find it does the job perfectly and also gives a bit more stability to the rear mudguard, and have also found it a lot easier to snap a fender without that black piece on.
June 25, 201115 yr You don't need the liner, add a strip of closed cell foam weather strip across the top of the air box to seal the gap to the fender, also an extra piece in the wiring slot.
June 28, 201115 yr For true "bling" you need this version...... It is a little more expensive though (3X).
