Stock sprocket size TXT 250 '06
peet
ok thanks. I bought this bike second hand. It currently had a 10 - 41 sprockets. What will be the effects when I chance to 11-42?
GreetZ
Changing from 10-41 to 11-42 you will make it slightly higher geared,
Less aggressive in lower gears and slightly higher speeds?
Yes that right, you probably won't notice much difference, but if you just change the front to 11-41 that would be even higher geared.
It's personal preference, I use 10-42 and so do most people I know here.
